Old 07-12-2010, 11:01 AM   #1
trizzuth
My Ride: 228k, 16yr old B3AST
Bleeding Clutch?
Whats the easiest way to do this? I've searched and searched and don't see any real solid answers, other than disconnecting the clutch line down by where the clutch delay valve is (or was). Since the brakes and clutch line use the same fluid from the same reservoir, would bleeding the brakes consequently also bleed the clutch line? Plan on bleeding both soon and have 2 containers of nice OEM fluid sitting in my garage waiting for me. Someone help me find a nice easy answer to this, thanks!
trizzuth is offline   Reply With Quote
Old 07-12-2010, 11:17 AM   #2
Cinna
My Ride: M3C
Send a message via AIM to Cinna
there is a bleed valve on the transmission, drivers side.
E46 M3
Cinna is offline   Reply With Quote
Old 07-12-2010, 11:27 AM   #3
trizzuth
hmm, interesting. And this is not a valve for the transmission, it is for the clutch? Anyone have a pic of this?
Old 07-12-2010, 01:13 PM   #4
Cinna
My Ride: M3C
It's about 1/2 down the page, http://www.madrussian.net/m3/diy_brake_bleed.shtml
E46 M3
Old 07-13-2010, 12:00 PM   #5
John 330i
My Ride: 02 330i
can you bleed the clutch without a pressure bleeder?
2002 330I
John 330i is offline   Reply With Quote
Old 07-13-2010, 04:55 PM   #6
Young Gun
My Ride: 05 330ci
The clutch bleed nipple is on the d/s of the transmission.
Because it is on the same system, the ONLY way to do this is through bleeding your brakes also.
Start at the furthest line, p/s rear , d/s rear , clutch, p/s front, d/s front
The madrussian diy is perfect, and it is what I used while doing mine.
Also 2 other things to note:
* you can remove the cdv valve if you want while you are down there to improve pedal feel
* while I was bleeding the clutch, I lost ALL resistance in the pedal, it was not back completely until I finished bleeding the front breaks.
Don't freak out if your pedal has NO feel while you are bleeding it.
Young Gun is offline   Reply With Quote
Old 07-16-2010, 02:39 PM   #7
trizzuth
hmm, interesting and wierd. just did all 4 brakes today, didn't do the clutch and it still feels like it has some bubbles in there, FFFF brakes feel exactly the same, but some of the fluid that came out was indeed dirty..
Old 07-16-2010, 03:17 PM   #8
Scott87
My Ride: 325ci 2001
Check my sig for the brake bleed DIY (clutch in there also).
Bleeding your clutch is exactly the same method as bleeding your brakes which ever method it is that you choose to use (power bleeder right down to piece of tube and a glass jar). You don't HAVE to bleed your clutch if you touch the brakes. Just like you can bleed the rear and not bleed the front. You wouldn't do half of the system and not the other half because it doesn't make sense but there is no reason you have to.
Hope that helps.
Scott87 is offline   Reply With Quote
Old 07-16-2010, 05:32 PM   #9
Ottis325i
My Ride: 2001 325i Sedan
The Clutch and Brakes share the same reservoir (Use DOT 4 Brake fluid).
The Clutch has its own separate Master Cylinder.
There is no return spring (to push back the pedal) in a Clutch Master Cylinder.
Best way to bleed without a pressure bleeder is;
First recognize that each time the pedal comes back up it will suck in air or fluid depending on if the bleeder valve is open or closed. The Master Cylinder is a one way valve, sucking from the reservoir then pushing pressure on to the Clutch Slave Cylinder.
My method (your results may vary), takes 2 people. 1 on the Clutch Pedal, and 1 on the Bleeder Valve at the Clutch Slave Cylinder.
1. Make sure the Reservoir stays as close to the full line as possible. If you do a lot of bleeding, you will have to check and fill more often.
2. The person on the Bleeder Valve has all the communication control. The commands are as simple as "Up" and "Down". Remember there is no Pumping in these steps, just Up and hold, then Down and hold. Basics are; Up = Bleeder Closed, Down = Bleeder Open.
3. The person on the Bleeder Valve starts with the Bleeder closed, then shouts out to the person on the Clutch Pedal "Down". When the Pedal is down open the Bleeder, let it bubble and drip some, then close the Bleeder.
4. After the Bleeder is closed, the person on the Bleeder Valve now shouts out to the person on the Clutch Pedal "Up" (they will have to actually pull the pedal back up, it won't come back by itself). This draws the fluid in to the Clutch Slave Cylinder. The person on the Bleeder shouts out to the person on the Clutch Pedal "Down". When the Pedal is down open the Bleeder, let it bubble and drip some, then close the Bleeder. Repeat until there are no bubbles.
5. Pump (push up and down) the Clutch Pedal until you feel some resistance and the Pedal comes back by itself. It should be good to go at this point. If you want to throw in another "Down" and open the Bleeder go ahead. You will have to pull back the Pedal manually again and pump it some to get the resistance back for normal clutch feel.
6. Top off the Brake Fluid Reservoir. Happy Clutching.
After thoughts.... a Brake Fluid flush through the Calipers does not flush out the Clutch Master or Slave Cylinders. Brake Fluid is rated on the temperature it boils (DOT 4 is better than DOT 3) that is why brakes fail if you keep your foot on the pedal to long (friction equals heat). Brake Fluid captures moisture from the air and brakes down over time, lowering its boiling point. The interval for flushing out the Brake Fluid varies. If the Brake Fluid is a dark color, its time to flush it out. When I was working for VW - Audi - Porsche, they recommended Brake Fluid change every 2 years regardless of how many miles were driven.
"I look for things; things that go."
Ottis325i is offline   Reply With Quote
Old 02-14-2014, 06:04 PM   #10
werdstrave
My Ride: 2001 330ci
Looking to bleed my clutch this weekend to trouble shoot a sticky clutch I've been having during the up stroke. While I'm down there I will be checking for leaks, etc. Has anyone bled it using the method below? The physics behind it seems legit to me. I was just wondering if anyone has tried this way or has any objections. Looks like you can do it all with one person and by only investing in an oil can and flex line!
werdstrave is offline   Reply With Quote
Old 02-14-2014, 06:46 PM   #11
Ottis325i
Great video. Great method. I would like to give this a try myself.
Some comments - observations:
- Brake Fluid Leaks: One of the best methods for determining if it is actually Brake Fluid is to taste it (yup, like Cheech & Chong). It will taste bitter. Don't guzzle the stuff, just touch it with your finger and then touch it to your tongue. Probably don't want to do this at the Slave Cylinder, the boot will be covered in Clutch/Brake dust and I don't want to know what that taste like.
- The Method: If only your car looked like his bench set up. Sometimes the tubing and hoses run lower than the Slave Cylinder. Do not introduce dirt back into the lines. Clean the area around the bleeder thoroughly before you put on the wrench or hose. Besides a clean new pump style oil can, you may want to make sure the pump works the way you want it to under pressure. The pump style oil can, hoses and turkey baster might as well be disposable because over time the material they are made of are not compatible with brake fluid. Brake fluid will damage paint finishes.
Old 02-17-2014, 06:37 AM   #12
anonymous_coward
My Ride: 2000 320Ci
I bled the entire hydraulic system last weekend after a major service on the brakes (new disks, pads, sensors, e-brake shoes, etc). Just thought I'd share my experience, in case someone runs into similar problems.
The procedure that I followed was from the Bentley manual and required use of a pressure bleeder. Bleeding the brakes went well, but then I got to bleeding the clutch...
In short, the procedure in the Bentley manual goes something along the lines of:
1. Pressurise the hydraulic system using a power-bleeder
2. Bleed the slave cylinder (as you would with brakes) in situ, until clean fluid comes out.
3. Close bleeder valve and remove pressure bleeder
4. Slowly press the clutch 10 x times
5. Unbolt the slave cylinder from the transmission and fit BMW special tool 21-5-030 (slave cylinder pushrod compressor) and compress the pushrod all the way into the slave cylinder.
6. Re-fit the pressure bleeder and pressurise the system
7. Hold the slave cylinder so that the bleeder valve is located at the highest point
8. Open bleeder valve
a. Once fluid appears without bubbles, use the special tool to withdraw the pushrod completely
b. Press pushrod all the way into the cylinder
c. if brake fluid appears without bubbles, close bleeder valve and release pushrod. Repeat procedure until runs clear and without bubbles
9. Remove pressure bleeding equipment
10. Re-attach the slave cylinder to the transmission
When I first read the Bentley procedure, although I understood the intent, I thought that the procedure from item 4 downwards sounded unnecessary, so figured I'd short-cut it there (I'll be due for a clutch change soon, so planned to do the clutch bleed properly at a later date). When I went to move the car at (what I thought was the end of the job), the clutch pedal was completely limp and (needless to say) would not go into gear. I didn't think there would be any way that I could've got air into the system when bleeding the slave cylinder in situ, but I guess it must've happened. So I ended up having to get the car back on the stands and running through the entire Bentley procedure. The next problem was the BMW special tool - I had no way of getting my hands on one and needed to get the job finished in 1 day. At that point in time I switched to "ghetto mode" and used a spring compressor and a steel plate to compress the pushrod and complete the Bentley procedure.
The clutch pedal only came good after I went through the entire Bentley procedure (I also didn't realise how sticky the clutch felt, until I got the new fluid through the lines). I've been driving it for a week now without further problems.
As a side note, BMW Australia only keep DOT 4 Low Viscosity hydraulic fluid in stock for the E46.
anonymous_coward is offline   Reply With Quote
Old 02-17-2014, 08:45 PM   #13
Ottis325i
It would appear from the above post and the Bentley manual method, that there is some kind of check valve or orifice that has to be manipulated inside the Slave Cylinder or Clutch Master Cylinder as part of the bleeding process. I noticed the guy in the video give the Clutch Master Cylinder a push while bleeding with the "pump style oil can" to get it going. I still think I'll stick with the 2 person method. It works for me every time and doesn't require more tools or a pressure bleeder.
DOT 4: Yes, BMW specified, kind of like the higher octane fuel/petrol recommendations. Higher is better. It has nothing to do with Viscosity, just the temperature it boils at. Boiling = gas = no brakes . You can mix DOT 3 and DOT 4 in a pinch. Do not mix DOT 5 with any other type of Brake Fluid, it is Silicone-based. I don't know the rating on the Brake Fluid in the Video. Sure is a pretty blue can though .
Old 02-18-2014, 03:47 AM   #14
anonymous_coward
My Ride: 2000 320Ci
Thanks for the input, Ottis325i.
Sorry, I should have been a bit more specific with my comment on the OEM brake fluid availability in my earlier post. According to the Bentley manual, there are two specifications of brake fluid that are available, depending on the type of stability control system (refer page 340-7 of the Bentley manual).
ABS / ASC = DOT 4 brake fluid
ABS / DSC = DOT 4 Low Viscosity brake fluid
My E46 is equipped with ASC, but BMW Australia insist that there is only one type of OEM brake fluid for the E46; which is DOT 4 Low Viscosity. Although I can't imagine it would make a huge amount of difference...
Old 02-18-2014, 10:18 AM   #15
Ottis325i
No worries anonymous.
It would seem that BMW (where Bentley gets its raw material) has a special recipe for its Brake Fluid that us regular blokes don't have access to. And it would seem that the BMW dealership actually has one that identifies it as "Low Viscosity". Their version of ignore the specs and take our word for it.
It's all Hydraulic Fluid. I would not do this, but in a pinch you could use Water in your Brake/Clutch Hydraulic system. Maybe I saw MacGyver do this on TV once.
If only we had something on the bottle that would identify its Viscosity, like motor oil. Even more interesting is the rating for Brake Fluid is based on a United States, Department of Transportation (DOT) system. Kind of like US wine or cigarettes, they only have to identify what it is, not the ratios or recipe. If the recipe is off and someone dies, well... talk to the US Department of Transportation.
We "Clutcher's" are the minority here in the US. Way to many large bottom, automatic transmission, driving to slow in the fast lane, people here
Old 04-29-2015, 09:18 AM   #16
RCase
My Ride: 2001 325i Touring
Has anyone noticed a smoother, more linear feel with less pedal effort after bleeding? My wife has a low mileage 05 M3 with functionally a very similar to clutch in my E90 (and my 325 touring) - the pedal is extremely hard for her to push which I would like to make easier (so she stops stealing my E90 )
2000 E46 323i Touring / JB / "BW"
2001 E46 "M3" Touring / Alpine / "WW1"
2008 E90 M3 / Jerez/ 6 Speed / FBO / "M3"
2015 F31 328d / MSport / Alpine/ "WW2"
RCase is offline   Reply With Quote
Old 04-29-2015, 09:51 AM   #17
Ottis325i
RCase
Hydraulically the E46 (M) and the E90 should be the same. There could be a difference in fluid (see Viscosity above), or if your E90 is softer/easier to push there could be air in the lines, but I doubt it. The likely reason is the 'M3' (E46) has a stiffer competition Pressure Plate on the Clutch. I felt the same when I test drove an older 'Z3' (E36/7), it gave my left leg a work out
Old 04-29-2015, 10:47 AM   #18
Richardlance
My Ride: 01 325I sport
personally I just did my brake and clutch with the old school me and my friend and it was very easy and fast. I tried to vacuum pump but I still say the two-man method is the easiest. I pumped my brake and clutch the same way always closing the valve on the downward stroke. brakes are tighter than ever clutch tighter than ever. sometimes the old ways are the best ways. by the way if there are any air bubbles the clutch will self bleed overnight after left alone for the most part. and you only need to remove the slave cylinder if you have one of the nipples the points down. and even if it is one that points down you only need to remove it if you are very anal about wanting to get all the old fluid out. personally mine pointed straight out so is very easy.
Richardlance is offline   Reply With Quote
Old 05-05-2015, 12:53 PM   #19
metallikatz3
My Ride: E46 ZHP Coupe
I did my friend's e90 clutch bleeding the other day by following the video above. I used a large syringe with plastic tubing to push up the fluid from the clutch bleeder and filled the master cylinder that way to make sure that no air got trapped in the line.
This method is a little messier but worked great and can be one by a single person without expensive tools
metallikatz3 is offline   Reply With Quote
Old 05-05-2015, 12:53 PM   #20
metallikatz3
