Sponsored by BimmerWorld
Old 07-15-2010, 10:19 AM   #1
///AZNSLVR
My Ride: Is F*ing old
Send a message via AIM to ///AZNSLVR Send a message via MSN to ///AZNSLVR
Suspension Upgrade | SwayBar Questions
Hi all,
I'm looking to finally upgrade my swaybars after 9 years of OEM stock.
Going to purchase TMS swaybars and looking into TMS Adjustable Front Swaybar and Rear Adjustable Length Sway Bar End Links.
Question is it really necessary to change the end links?
Sorry don't know much about these parts and what they exactly do.
Please chime in.
///AZNSLVR is offline   Reply With Quote
Old 07-15-2010, 10:22 AM   #2
mystert
My Ride: 2003 330Ci
No its not necessary to use adjustable end links. If your stock endlinks are worn out, replace them with new ones. You dont need to adjust the swaybars if your just driving to work everyday in the car. Since you dont know what they do anyhow, adjusting them probably wouldnt be a good idea either.
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 07-15-2010, 10:42 AM   #3
///AZNSLVR
Okay but I also failed to mention I have Tein SS coilovers and car has been dropped. Was wondering if the adjustable sway links would be sturdier as opposed to stock.
Old 07-15-2010, 01:34 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
If you're not currently using adjustable links with your lowered Tein suspension, you won't need them just because you upgrade your sway bars. Unless your struts have adjustable end link mounting tabs though (my AST suspension has this feature), I'm surprised you haven't already found the need for shorter end links. You typically only run into problems when the end links are too long for your ride height and they cause the ends of the bar to contact the control arms.
Old 07-15-2010, 05:44 PM   #5
BMW_Matt
My Ride: 135
Precisely.
BMW_Matt is offline   Reply With Quote
