E46 Xi Forum
Old 07-15-2010, 02:48 PM   #1
xecure
My Ride: 2002 325xi, 5MT Swap
how can i separate outer balljoint from steering arm? (E46 Xi)
I was in the middle of replacing my control arms for my XI and kind of got stuck removing my control from where the outer ball joint connects to the steering arm. I tried banging it with a hammer and sticking a chisel in there and banging that with a hammer. No luck.
Please give me some more ideas, thanks guys.
** Too much for a sig - tim330i **
OMG LOOK AN E46!
xecure is offline   Reply With Quote
Old 07-15-2010, 02:49 PM   #2
joeski3d
My Ride: 2000 323i
Don't you need a specialized tool for that?
Ballbusters Inc.
DISCLAIMER: No balls were physically hurt during the reading of this post. Should redness and/or swelling occur consult your gynecologist immediately.
joeski3d is offline   Reply With Quote
Old 07-15-2010, 03:44 PM   #3
IxNay
My Ride: 2000 328Ci 5sp SP
Use a tool called a "pickle fork" and a hammer.
IxNay is offline   Reply With Quote
Old 07-15-2010, 03:56 PM   #4
enzo_the_baker
My Ride: 328Ci, 328iC, X3
You need one of these and a big hammer:
http://www.autozone.com/autozone/acc...rator/_/N-264r
Got Miles?
2000 328Ci Steptronic
Original Engine & Transmission
Original Transmission Fluid
15K Oil Changes
So there!
enzo_the_baker is offline   Reply With Quote
Old 07-15-2010, 04:15 PM   #5
xecure
just rented one of those been banging on it but no luck, I'm gonna go back out and bang it a few more itmes and see what happens.
OMG LOOK AN E46!
Old 07-15-2010, 04:31 PM   #6
IxNay
Use a very heavy hammer and whack the crap out of it. It will come apart.
Old 07-15-2010, 04:59 PM   #7
xecure
Alright guys, after whacking a few times I noticed that my front strut is completely detached from the mount. did whacking it make that come off?
OMG LOOK AN E46!
Old 07-15-2010, 05:17 PM   #8
Toad21
My Ride: 00' 328CI
um, wtf? You tore the upper strut tower attachment off? wow.
Ok, you will need a new Strut Tower now unless you can weld those bolts back on (not reccomended).
Sry dude, should have read the instructions, you were supposed to keep everything bolted on while using the pickle fork.
Start shopping for a whole new shock and strut. You are not removing that spring yourself, so you will need a whole new assembly. Maybe i can find you one cheap on ebay. brb.
Note: Sometimes its a bad idea to get high before attempting something you have never done before. I have made similar mistakes myself.
Toad21 is offline   Reply With Quote
Old 07-15-2010, 05:22 PM   #9
xecure
You will need a tapper to get those bolts out now, and start shopping for a whole new shock and strut. You are not removing that spring yourself, so you will need a whole new assembly. Maybe i can find you one cheap on ebay. brb.
LOL, I wasn't high though. Just new to this trying to save some $$. I was planning on doing my suspension soon anyhow so I guess this was my push. Is it safe to lower my car or no?
thanks.
OMG LOOK AN E46!
Old 07-15-2010, 05:23 PM   #10
Toad21
My Ride: 00' 328CI
Ok I found a potential cheap fix.
http://cgi.ebay.com/ebaymotors/Used-...Q5fAccessories
I am not at all sure how to attach this piece, we will need more expert help on this topic.
Old 07-15-2010, 05:31 PM   #11
Toad21
My Ride: 00' 328CI
Lowering has more negatives than positives, if you can find OEM parts you might be better off.
Ok you should buy a pair for the front
Driverside $115
http://cgi.ebay.com/ebaymotors/Strut...Q5fAccessories
Passenger Side
Old 07-15-2010, 05:37 PM   #12
blarf
My Ride: 323i, 325iT, 540iT
Just buy new OE mounts and be done with it. They were probably falling apart anyhow. What you want for the ball joints is a hinged separator.
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 07-15-2010, 07:43 PM   #13
xecure
so just replacing the mounts should fix the problem?
Where can i get one of those tools?
OMG LOOK AN E46!
Old 07-15-2010, 07:53 PM   #14
maximepetit
My Ride: '02 topaz blue 325i
I replaced my control arms last week and had the same problem as you.. Hammered it for hours and it wouldn't budge.
Then I bought a pickle fork end for a pneumatic hammer and got it separated in less than a minute. Try it, It'll work.
maximepetit is offline   Reply With Quote
Old 07-15-2010, 08:06 PM   #15
xecure
Where did you buy it from? Would autozone have something like that?
OMG LOOK AN E46!
Old 07-15-2010, 11:48 PM   #16
loginfailed
My Ride: My buddies 350hp
To get ball joints to come loose, this is what I do. Set up the pickle fork in whatever orientation you need to get a clear shot at it. Use a short ~4 lb hammer. Swing the hammer hard using both hands. Just like in most sports, the most important thing to remember during your swing is FOLLOW THROUGH.
It will come loose. 4 lb hammer, use both arms, follow through...
Also, sometimes you don't even need a pickle fork. I don't recall how the XI looks under there. But a lot of the time you can just hit the spindle itself with the hammer (right where the ball joint goes through the spindle)
loginfailed is offline   Reply With Quote
Old 07-16-2010, 12:55 AM   #17
berserker
My Ride: 2000 328i stick
Yeah that is no biggy, you just need the new mounts and rubber - do both sides while you are at it - nothing expensive, nothing crazy.
berserker is offline   Reply With Quote
Old 07-16-2010, 01:07 AM   #18
IntegGeezer2Bimmer
My Ride: M3
STOP BANGING YOUR CAR!!!! IF YOU ALREADY TRIED BANGING YOUR CAR FOR MORE THAN 5 TIMES AND STILL NOT LOOSE, FORGET IT. TRUST ME, JUST BUY A BALL JOINT SEPARATOR FROM NAPA STORE, SEARS, EBAY. AUTO ZONE DOESNT EVEN KNOW THIS TOOL EXCEPT FOR THE PICKLE FORK. YOU CAN TRY KRAGEN.
Originally Posted by Born Again View Post
you have to understand the people that jump from car to car often have NO MONEY
they are usually making poor financial decisions and rolling over debt.
No offense to some members on the group but there are dudes making less than $35K driving in fairly new cars - lol like leasing a $40k car - wtf - the car is worth more than what you make in a year!
OP just be sensible - good luck!
IntegGeezer2Bimmer is offline   Reply With Quote
Old 07-16-2010, 01:10 AM   #19
blarf
Fleebay. I can't vouch for the quality, but that's the type of tool BMW (and Benz I think) calls for. What you'll typically find at autozone are tools that look like a pitman arm puller. These should work too (I've not done ball joints on an E46, AWD or no) without needing to swing a big sledge or risking damage to the ball joint or its dust boot.
If all you've done was tore the strut out of its rubber, then, yes you should only need a new strut mount (but, as mentioned, you might as well do them in pairs).
Old 07-16-2010, 01:18 AM   #20
blarf
Looks like Harbor Fright has a similar tool on sale now:
http://www.harborfreight.com/3-4-qua...tor-99849.html
Discussion of said tool:
http://www.m5board.com/vbulletin/e39...separator.html
