Sponsored by BimmerWorld
Old 07-16-2010, 07:40 AM   #1
theinfamousdrew
My Ride: 911 Turbo / E70
M3 rear sway bar
Ok.....im sure this has been beaten to death...but i cant find any info on it
Will a m3 rear sway bar fit on my 330Ci?
and yes i have searched and i have found out that the front sway bar from and m3 will fit....BUT
what about the rear?
theinfamousdrew is offline   Reply With Quote
Old 07-16-2010, 08:19 AM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
No. Not unless you swap the entire M3 rear end with it.
Old 07-16-2010, 08:22 AM   #3
theinfamousdrew
sweet....thanks.....im starting to upgrade my suspension and im gonna have a ton of questions...lol
Old 07-16-2010, 08:45 AM   #4
BMWstudent
My Ride: hates potholes
I have a 330i and i have a set of m3 vert sway bars (I figure thats as start of a difference between the chasis as possible, right?)
The front bar fits without a hitch. I used the m3 bushings in the 330's carrier sleeves (not sure what these are exactly called. bushing brackets? thats kinda a lame name)
The rears are almost the exact same shape as each other, but the m3 bar has some flaring at the end to keep it in the end links better (I'm guessing). I just got my bushings in the mail the other day so I'll be installing it today if possible. The real issue comes into play in that the 330's two bushing carriers next to the diff are a good deal smaller than the m3's. I plan to remedy this by using bushing intended for an aftermarket swaybar for a 330 and the standard brackets. (I have a set I got from powerflex)
my plan for the rear: use the 330's end links with the end-link bushings from the m3, use the 330's bushing brackets in the center, and the powerflex bushings.
Give me ten hours and I'll tell you (with photos) if you can do it without excanging the whole rear end. That would be silly.
BMWstudent is offline   Reply With Quote
Old 07-16-2010, 09:40 AM   #5
nite-stalker
My Ride: 325Ci
^^^ have you tried test fitting it first?
on the coupe it does not fit at all, the non-m bar is shaped to clear the differential, the M bar is straight at that section and will not clear the differential, it is not just a bushing issue.
nite-stalker is offline   Reply With Quote
Old 07-16-2010, 01:23 PM   #6
BMWstudent
No to test fitting. I'll take a copious amount of pictures though to verify one way or the other.
Old 07-16-2010, 01:37 PM   #7
BMW_Matt
My Ride: Has AWD
That means you didn't search. Simple answer is no, not without fabrication.
BMW_Matt is offline   Reply With Quote
Old 07-16-2010, 01:46 PM   #8
mvrk10256
My Ride: E30 325i
get hotchkiss bars, and never look back.
Old 07-17-2010, 07:35 AM   #9
BMWstudent
sedans have the same issue. the m3 bar interferes with the rear-most bracket for the diff on a sedan as well
Old 07-17-2010, 08:01 AM   #10
theinfamousdrew
off hand....does anyone know the size of the stock FRONT sway bar?
Old 07-17-2010, 09:44 AM   #11
I_Miss_My_///M
My Ride: 325i-RIP, '03 330Ci
23.5mm
I_Miss_My_///M is offline   Reply With Quote
Old 07-17-2010, 09:53 AM   #12
theinfamousdrew
Thanks.....just wanted to make sure the m3 sway was a real upgrade
Old 07-17-2010, 11:19 AM   #13
theinfamousdrew
Can the stock bushing mounts (brackets) be used for the m3?
Old 07-17-2010, 11:21 AM   #14
nite-stalker
My Ride: 325Ci
fronts, yes
Old 07-17-2010, 11:29 AM   #15
theinfamousdrew
Thanks for everyones help!
