Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 4.73 average. Display Modes
Old 10-03-2011, 05:00 PM   #41
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We are in the process of adding additional cooling kits that are a more complete refresh to our website. The total refresh (complete) kits will included all the parts mentioned.
ECS Tuning
Old 10-03-2011, 05:32 PM   #42
My Ride: 2016 Lexus
sounds like a good plan to me. Maybe you could incorporate some kind of option check list where people can decide what to add by just ticking boxes.
Old 10-03-2011, 08:58 PM   #43
slosvt
My Ride: 00 328i
Send a message via AIM to slosvt
ECS,
What parts are "different" in the Level 1 package? I know the more expensive system is OEM BMW, but what brand do you get for the parts in the ECS brand system?
Ready to order...
Thank you,
slosvt is offline   Reply With Quote
Old 10-03-2011, 09:03 PM   #44
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Remember, OEM parts are the same as Behr, Hella, Whaler, etc. The only reason they cost more is because of a BMW stamp. Shop wisely.
Old 10-04-2011, 10:08 AM   #45
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Originally Posted by slosvt View Post
ECS,
Ready to order...
Thank you,
The kit with the brand listed as genuine BMW kit contains only genuine BMW parts. The kit branded as assembled by ECS Tuning contains non genuine BMW parts, but the parts in the kit are quality OEM replacement parts. The kit found here contains parts by Geba, FAE, Meyle, CRP, and OES. With all of our kits you can click the "kit contents" button a drop down will appear listing all brands used for each part in a kit.
ECS Tuning
Old 10-04-2011, 12:08 PM   #46
DetroitEE
My Ride: 2004 325ci
Does the Geba water pump have a composite impeller?
Edit: Photos look like a metal impeller
DetroitEE is offline   Reply With Quote
Old 10-04-2011, 12:10 PM   #47
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The Geba water pump in the kit featuring a stout metal impeller for improved longevity.
ECS Tuning
Old 10-04-2011, 08:04 PM   #48
slosvt
My Ride: 00 328i
Thank you for the quick reply. I will place the order tomorrow. How long will it take to ship to VA?
Old 10-06-2011, 10:21 AM   #49
ECSTuning
ECSTuning's Avatar
My Ride: BMW
slosvt you have a PM
Old 10-08-2011, 01:31 PM   #50
ELCID86
My Ride: 2004 330i (ZHP) x2
Warning about the water pump stud bolts. They break pretty easily. I thought it was the torque wrench releasing, but it was actually the aluminum bolts/studs breaking. I was was able to back them out with a pair of Vice Grips-thankfully there was enough room to grab the remaining stub.
After more research, it appears the OEM numbers are 07129901921 or M6X30-8.8-ZNS. Anyone know of alternate sources to buy them? I'd prefer something more substantial than the OEM aluminum (?) ones. --Other than that the project is going fine... B-]
It appears ECS Tuning might have them: Mfg Part#07129904544, ECS Part# ES16061 @ $1.04/ea. Trying to verify with them now.
ELCID86 is offline   Reply With Quote
Old 10-10-2011, 10:48 AM   #51
ECSTuning
ECSTuning's Avatar
My Ride: BMW
^Correct the original part number (07129901921) for the stud bolt has been superseded to the one found here. They are the genuine BMW part not an aftermarket equivalent.
ECS Tuning
Old 10-10-2011, 10:54 AM   #52
ELCID86
ECS Tuning
Thanks, just ordered them.
Old 10-10-2011, 10:54 AM   #53
Moosecakes
My Ride: 02' SMG M3
I can say good things about the geyba water pump and ECS, both are awesome the metal impaler is much more of a peace of mind than the poop plastic one on the OEM pump I pulled out... Car is running perfect, well, after I blew up my OEM water pulley and had to rush to BMW before closing to get another lol! ECS aluminum one is on my list as well as a new radiator seeing as i have a small crack. So... look forward to hearing from me again soon ECS
Moosecakes is offline   Reply With Quote
Old 03-21-2012, 02:59 PM   #54
pfd964
My Ride: 330Ci
What did you use to lubricate the H2O pump o-ring?
Thanks for write-up.
pfd964 is offline   Reply With Quote
Old 03-21-2012, 03:01 PM   #55
ELCID86
BMW Coolant.
Old 03-21-2012, 03:05 PM   #56
pfd964
My Ride: 330Ci
thanks.
PD
Old 07-09-2013, 08:30 AM   #57
beamergirl123
My Ride: bmwx5 3.i 6 cylinder
wrong coolant
I made mistake by not using the same bmw blue coolant . over holiday bmw was closed so I used universal coolant will it damage engine?>
beamergirl123 is offline   Reply With Quote
Old 07-09-2013, 08:32 AM   #58
beamergirl123
i used wrong coolant in bmw x 5 2003, will it corrupt engine.
Old 07-09-2013, 10:20 AM   #59
My Ride: 2016 Lexus
it wont corrupt it short term. you should be fine. change it in two years
Old 08-08-2013, 12:18 PM   #60
Tbone8ty
My Ride: 2003 330i
http://www.ecstuning.com/BMW-E46-325...ling/ES263603/
How is the ecs level 3 cooling refresh?
Anything I should substitute for OEM?
Tbone8ty is offline   Reply With Quote
cooling system, diy
