Sponsored by BimmerWorld
Old 07-17-2010, 07:27 PM   #1
adrianpl
My Ride: 01 330ci
Rear bushings
My sub-frame bushings are gone. My car has 120,000 miles on it. I am about to give it in to get fixed. Should i also replace diff bushings and rear trailing arm bushings?
adrianpl is offline   Reply With Quote
Old 07-18-2010, 06:00 AM   #2
BodyMan
My Ride: 2002 325i
I would do the RTAB'S at least.
BodyMan is offline   Reply With Quote
Old 07-18-2010, 12:16 PM   #3
adrianpl
My Ride: 01 330ci
What are the symptoms of bad rtab?
Old 07-18-2010, 11:15 PM   #4
adrianpl
My Ride: 01 330ci
bump
Old 07-18-2010, 11:23 PM   #5
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
bad Rtab will make your rear end sway from side to side under pressure. Diff bushings as well, since those will create a clunk and your diff shifting around excessively can put strain on the rest of the running gear. Also take a look at your RSM(rear shock mount) since those are prone to premature failure.
If you're going to the trouble to replace the subframe bushings, it would be worth it to do the full shebang while you have everything out
firefirefire90 is offline   Reply With Quote
