Old 07-18-2010, 02:52 PM   #1
330xie46
My Ride: 2002 bmw 330xi
Question question on bent rim repair
after they fix the bends in the rims, will they need to be repainted?
330xie46 is offline   Reply With Quote
Old 07-18-2010, 03:02 PM   #2
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
1) depends on the rim painted finish or polished finish
2) depends if the wheel repair service offers painting as a repair package or separate service.
MrMotorwerk is offline   Reply With Quote
Old 07-18-2010, 03:56 PM   #3
330xie46
heres a link to pictures of the rims that im buyin that need the repair.
http://forum.e46fanatics.com/showthread.php?t=773287
Old 07-18-2010, 04:39 PM   #4
tootall
My Ride: 2011 328iT 3 pedals
Show those pics to a rim repair shop, or call to discuss it with them. One shop I spoke to wanted $250 to refinish and repair a bent Style 45 rim "the right way". You buy them new for less than that. I don't think buying rims used and reconditioning them is worth it unless you buy and can repair them and still be significantly less than brand new.
BMWCCA member since 1990
Upgrade your 328 with a 330 intake: http://forum.e90fanatics.com/showthread.php?t=1095889
tootall is offline   Reply With Quote
Old 07-18-2010, 05:22 PM   #5
loginfailed
My Ride: My buddies 350hp
Repaired rims will look good, but won't ever be as strong so they will be suseptible to bending again.
Also it can be hard to balance a repaired rim. While they can be balanced on most balancer machines, once the weight of the car is on the wheel it will make your steering wheel vibrate on the freeway.
If you do buy bent wheels & have the repaired, be sure to take them to a tire place that has a Hunter Road Force Balancer machine to have them balanced. The Road Force Balancer simulates the wheel being on the ground by applying force against the wheel when balancing.
Good luck with whatever you decide.
loginfailed is offline   Reply With Quote
Old 07-19-2010, 03:00 AM   #6
Guest021715
Account closed.
Not always, depending on the material of the rim. Like said, they will never be as durable.
Old 07-23-2010, 09:23 AM   #7
ALSHUBCAPS.COM
WHEEL GUY
My Ride: TAA II
if a non chrome wheel is bent on face side they will need to be reconditioned, if it is bent on the inside flange then no
as for as good as new, it depends on the repair facility. if the wheel is cut straight it will never be as strong again but done with hydraulics & slow heat it can correctly & safely be repaired.
just go to a place that subscribes to WEAA standards & you should be ok
ALSHUBCAPS.COM is offline   Reply With Quote
