Rating:
Display Modes |
#61 |
I would think greasing is required only on the ball behind the screw the connects to steering rack
#62 |
I did my outer tie rods. The difficult one needed about 9 treatments of soaking in PB blaster with generous heating from a propane torch. The ninth time it finally budged.
#63 |
Excellent write-up, I just did mine today, this is an easy DIY especially with this DIY. For those of you that have earlier E46's the outer tie rod nut is not 19mm. I tried 19, then 18mm (which was still loose) and 17mm (too small) and figured it must be SAE and ended up using an adjustable wrench
Koni FSD's | Eibach Pro Springs |Staggered 19" VMR 710's | Hotchkiss Sway Bars | BMW Performance CF Strut Bar | Meyle HD Control Arms, RSM, Diff. bushing | Powerflex FCAB, RTAB| Brembo Sport Slotted Rotors + Akebono Euro Ceramic | Simota CF CAI | Conforti Shark Injector | Stewart Water Pump | M3 front and rear spoilers | Depo smoked front/side signals, Eagle Eye smoked LED tails | ACS interior trim/pedals | UUC Rob Knob 5 & floor mats |
#64 |
Glad you had success changing them out!
Neil |
#65 | |
#66 |
It is so easy with the puller that I would really want it (this is especially true since you can get the power built one for so cheap). Having done the control arms earlier that summer, it was such a night and day difference of removing the tie rods with a puller compared to man handling the control arms ball joints off with a fork! No question, the puller is worth the $15.
It's also nice because you can remove the tie rod without damaging it, so if you need to remove the tie rod without replacing it, you can do that too. Good luck! Luke |
#67 |
what are the symtoms of a bad tie rod? i been geting some vibration on my steering wheel when im driving at 70 to 80 mph!!! i checked the tie rod last night and i notice the boot has a crack or a hole!!! and when i do a left u turn i get***65279; a scraping noise like a grinder noise!!
#68 |
bmw e46 tie rods
do I have to replace just the tie rod end? or the whole tie rod cus I checked the tie rods this morning and the are really worn out and have some play because I been getting a vibration in my steering wheel I just replace the control arms and control arm bushings, can any one help me out plz
[ATTACH] |
#69 |
To check your tie rod jack your car up and see if you can wiggle your tire side to side easily. Get a pry bar and and see if there's a lot of play in the bushing that attaches to your wheel. These are usually indications of a bad tie rod, it's normal for them to look warned out after so many miles.
#70 |
sub'd for the info, good job OP
#71 |
My Ride: gobbles oil like a B
Sub'd cause I am all about this soon. Again. YAY for Chinese made tie rods from E-bay! Came from a "Hamburg Technic" kit I ordered a long time ago, I am actually surprised that they lasted as long as they did now that I think of it. But my driver's side is BAD, can move the wheel like 1/2" in each direction! Need to do this ASAP. NEVER BUY ANYTHING HAMBURG TECHNIC, I've had a control arm ball joint pop where it was so bad I thought it was going to separate and now this... and sway bar end links that were shot after less than a year! garbage parts.
#72 |
Hamburg technic tie rod outer end was destroyed. Thankfully it came off fairly easy, had both the tie rod separator and pickle fork, pickle fork won. Had to perform a driveway alignment to get her lined up good on that side on my zhp's. Rides good and straight now, so much better in the steering wheel, hitting highway tomorrow so we'll see how accurate my estimates are..
#73 |
Need parts for my zhp want to refresh suspension don't wanna go cheap but don't have crazy money to buy bmw parts I need to know the next best thing to it and where I can get parts good stuff for cheap
| Tags |
| good for tie rods |
