Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 07-20-2010, 12:05 AM   #1
tritunes
My Ride: 2001 325i, 2004 M3
FS: STOPTECH 14" (355mm) Front Big Brake Kit - Silver/Slotted (E46 M3)
Sold -
tritunes is offline   Reply With Quote
Old 07-25-2010, 02:07 PM   #2
sly1types
My Ride: M3
Send a message via MSN to sly1types
What is the thickness of the rotors? What is the minimum thickness listed on the hat?
A truck and some cars...
sly1types is offline   Reply With Quote
Old 07-25-2010, 10:52 PM   #3
tritunes
Can you point me to the location on the hat? I looked pretty closely at the hole assembly and am not seeing it. I measured across the entire rotor, from outside surface to opposite outside surface and it measures 31.5mm, if that helps you any.
If you can point me to the minimum thickness location I'd appreciate it. Otherwise I will try to contact Stoptech tomorrow.
Thanks,
Peter
e46 m3 bbk, stoptech
