Old 07-20-2010, 01:59 PM   #1
kakashi_sensi
My Ride: 01 e46 330i 6spd
Crankcase Ventilation Valve CCV
my shop suggests me to change my ccv...is necessary? mine is a 2001 e46 sedan...
frankly im not too sure wat this is
or wat it does
any info would be greatly appreciated
LEVELONE // Euro.Techniks // OEM BMW Performance Auto -> 6 Speed Complete
kakashi_sensi is offline   Reply With Quote
Old 07-20-2010, 02:58 PM   #2
shanneba
My Ride: 2003 330Ci
There is a BMW TSB on this issue - If you do not have the cold weather version, replace it.
SUBJECT
Oil Separator Cold Climate Conditions
MODEL
E39 (5 Series) all with M54 engine
E46 (3 Series) all with M54 engine
E53 (X5) all with M54 engine
E60 (5 Series) all with M54 engine
E83 (X3) all with M54 engine
E85 (Z4) all with M54 engine
SITUATION
Certain areas of the US experience extremely cold climate conditions during the winter months. A small number of
vehicles in the above-listed Series have experienced problems ranging from leaking or broken valve covers to complete
engine failure.
CAUSE
Moisture accumulating in the engine oil separator; hose to oil dipstick guide tube; or the orifice in the dipstick guide
tube can freeze. When this occurs, depending on the position of the internal valve, it may either cause high crankcase
pressures (stuck closed) resulting in valve cover leakage and/or breakage, or cause an oil hydro-lock condition (stuck
open), which could result in engine damage.
CORRECTION
Replace the crankcase vent valve, crankcase vent hoses, and dipstick guide tube.
E46 (3 Series) rear-wheel drive only
Part Number Description Quantity
11 61 7 534 237 Oil Separator Repair kit 1
11 43 7 565 437 Dip Stick Guide Tube 1
11 15 7 532 629 Hose 1
E46 (3 Series) all-wheel drive only
11 43 7 565 438 Dip Stick Guide Tube 1
Join BMWCCA
Old 07-20-2010, 03:40 PM   #3
Adam330i
My Ride: 03 M3
I would definitely listen to your shop on this one. You definately do not want t let this go. I bought the kit from tischer BMW and installed it myself. It is a rarely straight forward diy, challenging at times but definately doable. Typically unwound say you could wait until fall and then get it replaced. I haven't heard of near as many issues of the hydrolock occurring in the summer.
Adam330i is offline   Reply With Quote
Old 07-20-2010, 04:03 PM   #4
beingdevious
Apple Jews
beingdevious's Avatar
Location: Drunk onthe Beach.. Official 4ngiefest.com Techie Go to: 4ngiefest.com/donate Needs: to leave the computer Status: ///Pantless
My Ride: 2001 325i Sedan
Send a message via AIM to beingdevious
do it.
i did it myself. it's annoying.
[IMG]http://************/ogaeq6[/IMG]
Question for you:
Are boobs and hands polarly charged, thus causing the inevitable joining of the two? If so are some breasts simply charged backwards?
On a scale from 0 to 24...wait, 3 to 24, where 6 is the lowest and 12 is the highest, how freaking high re you right now?
She's got you high, and you don't even know yet.
beingdevious is offline   Reply With Quote
Old 07-20-2010, 04:12 PM   #5
Northern Dancer
My Ride: 1989 325 2002 325
Do you know the history of the car? If it was used often, if it is used often for short trips under 8 km, then replace ASAP especially if the oil was only changed according to BMW on board computer. Conversely, if the car is always driven at least 8 kms IN THE WINTER and you change your oil at least twice a year, then I might consider letting it go.
Northern Dancer is offline   Reply With Quote
Old 07-20-2010, 04:13 PM   #6
Jason@Tischer
Your #1 OEM BMW Part Source
Jason@Tischer's Avatar
My Ride: '02 Dinan 330ci
Send a message via AIM to Jason@Tischer
Here's a link to our E46Fanatics M54 CCVV Kit Special on the site
Jason Reighard
Internet Parts Manager, getBMWparts.com
Email: getHelp@getBMWparts.com AIM: Jason at Tischer Follow Us: FaceBook | Twitter
Jason@Tischer is offline   Reply With Quote
Old 07-20-2010, 04:26 PM   #7
kakashi_sensi
SUBJECT
MODEL
SITUATION
engine failure.
CAUSE
CORRECTION
thanks for the info dude...=) ill make sure i take advantage of this list
Originally Posted by beingdevious View Post
do it.
how annoying is it? the engine bay does look tight
im a noob really when it comes to engine work...will i still manage?
the 2nd owner of the car didnt use it much
i am the 3rd and i use it quite often driving long distances
at least 19.3km each day
Old 07-20-2010, 04:27 PM   #8
kakashi_sensi
Originally Posted by Jason@Tischer View Post
so this link is all the parts i need right?? thanks once again
Old 07-20-2010, 04:34 PM   #9
N89
My Ride: 330Ci
It looks like it has everything except the dip stick guide tube.
N89 is offline   Reply With Quote
Old 07-20-2010, 05:13 PM   #10
kakashi_sensi
ok ill look into that
thanks
Old 07-20-2010, 06:05 PM   #11
Northern Dancer
for Jason
Never done "quote" before so hope this works. Jason-when we order how can we differentiate between RWD and AWD models??
Old 07-20-2010, 06:32 PM   #12
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I did it in just under 3 hours. It's not that hard.
Old 07-20-2010, 06:49 PM   #13
usernamehere
Banned
My Ride: lackbof turbos
Something the m52 guys have to worry about? Im at 216k, many miles per trip..
usernamehere is offline   Reply With Quote
Old 07-20-2010, 11:16 PM   #14
kakashi_sensi
anyone got a diy on this?
Old 07-20-2010, 11:48 PM   #15
monkeyjuice5150
My Ride: bmw
This is one of the require maintenance to do. I would do it... its ***** work tho.
monkeyjuice5150 is offline   Reply With Quote
Old 07-20-2010, 11:56 PM   #16
N89
My Ride: 330Ci
I'm going to do it also but I'll probably have a shop do it since that just looks like a pain in the... If I were you I wouldn't hesitate since you live in a colder climate than I... me, I'm going to wait until fall to do it.
Old 07-21-2010, 12:33 AM   #17
kakashi_sensi
ya thanks for the advice...
i think im gonna do it...i might do it myself? i duno =\
