Old 07-20-2010, 11:54 PM   #1
envoid
My Ride: 2008 335i
Rear Brake Oddity
Ok. My rears are gone on my 330i so I checked out the rotor to see if I need to replace them as well and I find stamped on the right-rear rotor that the minimum thickness is 20.4mm (didn't check left-rear as was checking rotor wear while making sure there was the wire as the dash light isn't lit). Is it me or is this wrong? There is no lip on the rotor and the current thickness is around 22mm (close estimate as I don't have a micrometer). Is it even safe to have the front rotor on the rear? They work fine but might explain why the rears 'thump' when the car is held at certain speeds (held around 40 it sounds like the ABS is activated but with barely any braking). And since it specifies 20.4mm should I just replace the rotors anyway with the proper rear rotors or use the front ones again?
Got the car used and never had to do the brakes for ~22k miles that I've owned her.
Thanks everyone!
envoid is offline   Reply With Quote
Old 07-21-2010, 12:46 AM   #2
fotsir
My Ride: 2004 Lexus IS300
Thanks everyone!
Q:Is it me or is it wrong?
A:Supposing you are able to read, it's you.
Q:Is it even safe to have the front rotor on the rear?
A:WTF are you talking about? How did the front rotor get on the rear? No, it's not safe; I don't think it's even possible! What, with the handbrake and all. I'll believe it when I see it.
Q:And since it specifies 20.4mm should I just replace the rotors anyway with the proper rear rotors or use the front ones again?
A:If you have the front rotors on the rear, you should definitely put the correct rear rotors on, unless your car has been modified to accept the front rotors. Concerning the minimum spec, that is the minimum thickness that the rotor can be at WHEN REPLACING PADS without having to replace the rotor as well.
fotsir is offline   Reply With Quote
Old 07-21-2010, 06:29 AM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
20.4 is the minimum thickness stamped on the front rotors.
So, you evidently do have a front rotor on the rear...maybe you also have a front brake pad on it too...thus no lip?
It's not terribly surprising to me that our rotors would accept the e-brake, whether front or rear, as I suspect many rotors are made to accept e-brake.
But, I'm thinking, frankly, that coz the front rotor is on rear, what else is there? The caliper would need to be different...ah...that's why no lip. Front rotor, rear caliper and so the pad is sitting proud of the rotor's edge.
Anyway, that's my theory.
OP...you have to have a look at all four rotors...look for stamps. I suspect you'll have the other stamp on the fronts...a little thinner...just put away Bentley.
Get this straightened out...but you do need to see that stamp so you'll know how to proceed.
Doug
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 07-21-2010, 02:42 PM   #4
envoid
My Ride: 2008 335i
I looked at the front rotors and they specify 23.4mm min thickness. So the mins are front 23.4mm, rear 20.4mm. Wtf?? What car did they think they have? I need to go over it a little more to see if the calipers have been changed. Another damn surprise probably.
Old 07-21-2010, 02:49 PM   #5
dmax
dmax's Avatar
Hmmm...find specs on rotors from your car...it might have a superceded pn...I got this info from Bentley.
...and what's wear like in the front...you have lip there?
Out to be a pn stamped somewhere on the caliper...enough of one to help you identify it.
But, now, you at least know that bigger is in front...that's good. Car is stopping, and if something is different than it should be, it sounds like it might be by design and not accident...so could be a good thing!
Doug
dmax on Facebook
Mangofy your E46!
Old 07-21-2010, 03:45 PM   #6
envoid
My Ride: 2008 335i
Doug, thanks for the help. I checked the PN on the front rotor and it is 34 10 1 166 071 (bold is stamped on the rotor) so it is correct. Even has the BMW logo crudely stamped on it. The caliper I'm not really finding anything that relates to the PN but they do look like they should. What I'm finding on it is "844" then smaller below that is "083/4". The fronts do have a lip on them.
So all in all I shouldn't pay attention to the books and just pay attention to what the rotors say and just get the PNs for the car. lol When you expect to have smaller rotors it kinda throws you off.
@fotsir: I'll take a pic after I put the front back on and pull the rear again. The rear rotors say "MIN TH 20.4mm".
Old 07-21-2010, 04:26 PM   #7
envoid
My Ride: 2008 335i
Here's my front rotor:
Here's my rear rotor:
Colors look different cuz i had to use the flash on the rear, but I just shot these while on my 04' 330i.
Old 03-13-2012, 09:27 PM   #8
rkneeshaw
My Ride: 330i ZHP
This is normal. The 330i has larger rear rotors than the 328i, 325i, or 323i. In fact the 330i rear rotors are thicker than M3 rear rotors according to the Bentley manual (but not as large in diameter of course).
So the 20.4mm is the minimum thickness of your rear rotor and this is normal. You do not have front rotors on the rear.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 03-14-2012, 04:46 AM   #9
dmax
dmax's Avatar
It took you long enough to respond, rknee! LOL
Interesting reading me from way back!
dmax on Facebook
Mangofy your E46!
Old 03-14-2012, 09:42 AM   #10
ddombrowski
My Ride: 01 330ci 5spd
Send a message via AIM to ddombrowski
Regardless, I rarely ever replace rotors on the rear of any car so long as they don't have a nasty lip on them and the new pad beds in well. I've never been able to feel a vibration from the rear rotors. Maybe I'm lucky, who knows. I always just pad slap the rear and see how it drives, and every car has always done well after that.
So, even if you are below min thickness on the rear, I wouldn't worry about it.
ddombrowski is offline   Reply With Quote
Old 03-14-2012, 09:44 AM   #11
My Ride: Lexus
The 330 and E46 M3 both use 325mm diamater rotors up front. The M3 rotors are 3mm thicker IIRC.
if you're talking about the rear rotors then yes I believe the E46 M3 is slightly bigger in dia
330i, brakes, e46, rear, rotor
