E46 Xi Forum
Old 07-21-2010, 01:23 AM   #1
2003zhp
My Ride: 03 330i zhp 02 330xi
how hard is it to put a short shifter in a XI?
i searched and have talk to users on other sites that have a xi and been getting two different anserws.
one anserw is you need to drop youre drive shaft and install it from under the car.
and the other anserw i was told is it can be installed from inside the car and takes no more than 30 minutes.
can anybody help me figure out which one is right?
i would love this mod but will not be willing to drop the drive shaft to achieve it.
thanks
2003zhp is offline   Reply With Quote
Old 07-22-2010, 10:53 AM   #2
330xie46
My Ride: 2002 bmw 330xi
i would like to know this as well
330xie46 is offline   Reply With Quote
Old 07-22-2010, 04:11 PM   #3
330m3
My Ride: Bmw 330i
same here...
330m3 is offline   Reply With Quote
Old 07-22-2010, 04:20 PM   #4
LittleChrist12
My Ride: 2003 BMW 325xi
I'm on board to know. I have been told that XIs have to loosen or drop the driveshaft, but confirmation would be nice.
2003 BMW 325xi
2010 BMW M3 Sedan
LittleChrist12 is offline   Reply With Quote
Old 07-23-2010, 10:55 AM   #5
dpgrand
My Ride: 2005 330xi
I just did this this past week, and this is what I had to do:
Lower your exhaust enough to slide the exhaust heat shield back enough for you to access the top of the tranny. I supported the tranny with a jack and then removed the tranny cross brace completely. I then lowered the tranny about an inch. You will now have access to the top of the tranny to remove and install the b!tch clip.
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 07-23-2010, 09:00 PM   #6
2003zhp
i was told by a user on here he did this all from above. here is what he told me:
just pop off the carrier bushing and thats it. you also have to wiggle to get the pin out but thats it? it takes 30mins nothing needs to be dropped from below.
im looking into using this short shifter since its oem and cheaper than aftermarket ones:
http://forum.e46fanatics.com/showthr...=short+shifter
Old 07-23-2010, 10:17 PM   #7
330xie46
i wish somebody would do a diy short shifter for the xi if it can be done from above.
Old 07-23-2010, 11:06 PM   #8
athayer187
My Ride: 2004 330xi
I did it from above too - all you need to do is remove the transfer case mounting bolt (that mounts it to the body) to get some room. It takes patience to get the small allens into the carrier, but it can be done.
1988 535is - 10.5:1, PB N31 cammed M30B35, Miller WAR and MAF, style 29's and style 5's, urethane everywhere, revalved Bilsteins
500/450 Coilovers, Vorshlag camber plates, UUC SSK, Mason Eng. strut bars
Hella H1/H4's, Schroth Rallye 3's, Dinan 25/19 sways, e32 750i brakes, Bav Auto headers, M5 clutch and FW
athayer187 is offline   Reply With Quote
Old 07-25-2010, 11:34 AM   #9
330xie46
how much would you charge to do this?
