Old 07-21-2010, 12:55 AM   #1
dancccp
My Ride: is on rails
Send a message via AIM to dancccp
obc and radio dont turn off with key out of ignition
Hey, today I turned off my car, took the key out and the obc, radio, light switch lights, and windows were all on. The car did not want to lock via the remote either. I pulled a few fuses (obc,central locking....), and also disconnected the battery for about 20 minutes. At this point I have no idea as to where to proceed, any help would be greatly appreciated, thanks
dancccp is offline   Reply With Quote
Old 07-21-2010, 01:16 AM   #2
crazyafghanguy
My Ride: e36 323is
well first of all, u can still play the radio without the key in the ignition, and windows can still work for a little big after car is turned off.
Photobucket
crazyafghanguy is offline   Reply With Quote
Old 07-21-2010, 01:19 AM   #3
blarf
My Ride: '00 323i
Bad ignition switch?
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 07-21-2010, 01:25 AM   #4
TX
My Ride: '01 330i ZSP ZPP
Send a message via ICQ to TX Send a message via AIM to TX Send a message via MSN to TX Send a message via Yahoo to TX
Electronics don't shut off until a door is opened.
TX is offline   Reply With Quote
Old 07-21-2010, 06:19 AM   #5
dancccp
With the the doors opened the windows and radio still stay on, its as if the car stays in ignition I with the key out
Old 07-21-2010, 07:14 AM   #6
JB330ci
My Ride: 2002 330Ci
Have you removed or checked the fuses lately? There are a couple of them for the radio, one of them is probably misplaced or blown. That alone will keep radio on after you turn off the ignition until you turn it off manually. In the normal condition (or factory set) if you had the radio on while driving, it would be off when switch the ignition off. Windows and sunroof will still be operable for a while after you turn off the car.
JB330ci is offline   Reply With Quote
Old 07-21-2010, 09:11 AM   #7
dancccp
I meant the diplay for the radio is still on, which shows the time along with the obc and working windows regardless of doors being open or duration of time
Old 07-21-2010, 12:54 PM   #8
blarf
My Ride: '00 323i
Pretty sure that's configurable. Mine turn off when I turn off the ignition.
Old 07-22-2010, 06:41 PM   #9
dancccp
Resolved: Took off the battery terminals both positive and negative overnight, started the car the next morning and everything turned off properly.
