Old 07-21-2010, 09:19 AM   #1
Green323i
My Ride: BMW X5 and BMW 323i
Cd changer question/problem
Well I tracked down a 6 cd cartridge for my factory BMW cd changer and put some cd's in it tonight to test it. The cartridge loaded in fine and I could hear the changer loading through each cd in the cartridge but it would end up saying 'No discs' on the head unit. I've searched the forums and read about people having issues with jammed cartridges etc... But mine isn't jamming at all. I used all types of CDs from new to old proper not burnt CDs as well as some burnt cdr and cdrw but everytime it would just cycle through all 6 discs and not read any of them.
Any ideas?
Green323i is offline   Reply With Quote
Old 07-22-2010, 12:01 AM   #2
rkilpa
My Ride: '05 330ci ZHP
Obvious, I know.....but have you confirmed that the discs are right side up? Make sure to follow the directions on the cartridge for the playing surface position.
'05 BMW 330ci ZHP
rkilpa is offline   Reply With Quote
Old 07-22-2010, 12:11 AM   #3
Green323i
I'm pretty sure they are. The side of the disc with the album and artist graphics etc... is facing up. Thats right eh?
Old 07-22-2010, 12:14 AM   #4
Guest021715
Account closed.
its a sign you should stop using outdated cds and switch to USB
Old 07-22-2010, 12:25 AM   #5
Green323i
whilst my cd changer is cactus at the moment i can't really comment too much but from reading many threads on this forum people arent overly happy with DICE and similar devices. I'd want to maintain the use of my steering wheel controls to change tracks etc... and there isnt many options for this, or is there? i may be wrong.
Old 07-22-2010, 06:48 AM   #6
PEEBU
My Ride: E46 Touring
I had this issue also. Turned out to be dirty lense on the laser pick up. Get a generic CD cleaner or DVD cleaner (With the little brush on it) and run it through your changer. You can do this when it starts to skip a little bit also
PEEBU is offline   Reply With Quote
Old 07-22-2010, 07:04 AM   #7
Green323i
Great, thanks. I'll give that a try.
Old 07-23-2010, 01:29 AM   #8
Green323i
Pulled the changer apart and used a cd cleaning cloth to clean it inside but its still not recognising any discs. Each cd is pulled from the cartridge but it never spins and it just moves onto the next disc...............
Old 07-23-2010, 02:02 AM   #9
CoEEzi
My Ride: 02 CB m3
had the same problem....time to get a dice silverline pro...has use of steering wheel controls, more selection, almost same quality sound.... I never looked back since.
CoEEzi is offline   Reply With Quote
