Old 07-22-2010, 02:59 AM   #1
skipole
My Ride: '02 330ci
Xenon Not Working... But No Dash Warning Light?
Tried to search for this issue but found absolutely nothing.
Here's the issue: My driver side headlight is not working. Although it's hard to see with my angel eyes being so bright, I think the malfunctioning headlight actually emits a very faint "yellow" light (almost like a daytime running light, but much less bright). The passenger side light is working normally.
The weird thing is that there's no "bulb out" warning light on my dash. I've had intermittent problems with the other HID (passenger side) in the past, but I always knew when it wasn't working as the gauge cluster warning light would be very obvious.
Not sure if this is related, but I had to replace my battery yesterday. I used an aftermarket replacement, but it has the same cold crank amps rating as the OEM battery (765). Also, I drove for about 20km's yesterday after installing the new battery and there was no problem with the headlights.
Any ideas on what the problem might be or how to go about troubleshooting would be much appreciated.
skipole is offline   Reply With Quote
Old 07-22-2010, 04:55 AM   #2
Syfon
My Ride: 2004 6MT M3
Maybe the globe or element is literally being starved of electricity and is therefore not fucntioning properly and hence no "bulb-out" message on the dash?
Try checking the wires to the headlights/xenons/globes whatever.
Just a suggestion....
Syfon is offline   Reply With Quote
Old 07-22-2010, 05:32 AM   #3
sillieidiot
My Ride: '06 AW 330ci
the bulb out only comes on when the bulb is emitting no light. you said it's very dim, hence there's still some light.
Old 07-22-2010, 07:53 AM   #4
skipole
My Ride: '02 330ci
Thanks for the responses guys. I recently went to the garage and turned the headlights on again. This time, the headlight flickered a few times (halogen color flickers, not blueish white)... then went out completely. Within 30 seconds, the dash "bulb out" light came on.
I've done some reading, and I'm still not clear on what the problem is. It sounds like it's probably just the bulb, but could certainly be an issue with the ballast or igniter. Hopefully not.
Old 07-22-2010, 08:07 AM   #5
afstud
My Ride: 2003 ZHP 6-speed
well it make sense to try the bulb first since thats the cheapest part.. you can get a new set for about a hundred bucks from this place..http://www.theretrofitsource.com/pro...2f7382132c4397 these guys are very reliable and your better off just buying 2 new ones at the same time so the color is the same and they will be brighter trust me, if that doesnt solve the problem then it is your balast/igniter unit thats mounted under the headlight.. you can usually pick up one of those from a salvage yard for fairly cheap, those you dont have to replace in pairs since they stay the same throughout there entire life. what i would also do before you go about buying bulbs is swap them from one side to another to see if the problem follows the componant your swapping..but i would recommend a new set of bulbs since they have been flickering like that and usually a quick start up and shut down like that reduces there life significanly. good luck!
afstud is offline   Reply With Quote
Old 07-22-2010, 10:06 AM   #6
skipole
My Ride: '02 330ci
Cool, thanks for the info. I'm going to attempt to swap the two bulbs katertoday or tomorrow. Looks like a fairly simple process but my ghetto-fab angel eye wiring will get in the way.
I'll definitely replace both bulbs if the issue is indeed bulb-related. I've read that a few places now, and having two different coloured headlights would be tragic.
Old 07-22-2010, 01:24 PM   #7
afstud
it is tragic lol i hate it actually, and its amazing how much of a difference in light output new bulbs actually make.. i just put the xenon headlights in my car, bought the headlight set from a salvage yard and i left the bulbs in that came with them and they had to be a few years old and they seemed to have decent light output.. but once i put my new set of osram bulbs in the light output was about 5x what i started with, its amazing how much light they lose even after 2 years of normal use. balasts on the other hand dont change at all even if a balast is 10 years old it performs the same as a 2 month old balast.
Old 07-22-2010, 03:52 PM   #8
sillieidiot
Actually it doesn't. The output drops from 35w very gradually. Its just hard to notice the difference unless you have 6000k bulbs as it makes those brand new bulbs looks slightly yellower. But the kicker is that in pictures it still shows up as 6000k lol
Old 07-22-2010, 03:58 PM   #9
g4LLiT0
My Ride: 99 Bmw
i have kind of the same problem, my xenon light on the driver side dont work, and the high beam on the passenger side, checked the wires...the wire connected the the driver side xenon doesnt get enough electricity and the same for the passenger side high beam......dnt know what the hell is wrong
g4LLiT0 is offline   Reply With Quote
Old 07-22-2010, 04:00 PM   #10
sillieidiot
did you check the power with a volt meter?
Old 07-22-2010, 04:05 PM   #11
g4LLiT0
My Ride: 99 Bmw
yes...the one that does light up get sufficient current, but the side that does not light up does not get sufficient both high, and lo beams
Old 07-22-2010, 04:12 PM   #12
sillieidiot
hmm the lcm usually controls the power going to the lights. i had a problem where the ground wire to the low beam was messed up somehow so i replaced it and that did it. for some reason that wire affect both my driver's lowbeams and fogs.
Old 07-22-2010, 04:25 PM   #13
g4LLiT0
My Ride: 99 Bmw
its even affecting the lights inside the car, they flicker and go out completely when i hit the brakes
Old 07-22-2010, 04:35 PM   #14
sillieidiot
you sure it's not your battery?
Old 07-22-2010, 04:47 PM   #15
g4LLiT0
My Ride: 99 Bmw
Nope, new battery...
Old 07-22-2010, 04:48 PM   #16
sillieidiot
well i guess try checking the ground wire or something. it look me forever to figure out that it was a ground on the driver's side lol
