Old 07-23-2010, 12:34 AM   #1
M3_for_me
My Ride: Individual CB 330ci
Overheating ONLY when idle
car overheats only while in idle especially on really hot days but as soon as i pick up speed it goes back to normal operating temp, i tought the fan was broken but it randomly turns on while the car is parked with keys out of ignition and also i just replaced my expansion tank 2 months ago and i have a 5spd
M3_for_me is offline   Reply With Quote
Old 07-23-2010, 01:44 AM   #2
BimmersGarage
My Ride: E46 330i
How many miles on your vehicle?
1. Did you Bleed your cooling system properly after your installed the new Expansion Tank?
2. Check your thermostat.
BimmersGarage is offline   Reply With Quote
Old 07-23-2010, 01:46 AM   #3
deadpass
My Ride: 01 330i
have you checked the coolant to make sure the level is high enough? just because your fan turns on sometimes doesn't mean it's working right all the time.
deadpass is offline   Reply With Quote
Old 07-23-2010, 01:53 AM   #4
Goondaddy
My Ride: 2002 325ci
Your viscous fan could be busted. Try holding a newspaper against the fan when it is spinning, it shouldn't stop. Could be some issues with bleeding the system.
Goondaddy is offline   Reply With Quote
Old 07-23-2010, 07:06 AM   #5
usernamehere
Banned
My Ride: lackbof turbos
I had the same problem a few months back, it was an early warning sign for me. Wait for it to cool completely off, check the level and bleed the system. I was able to catch a leaking issue. It was scary at a stop light, cause my needle slowly went near the red and I had to reev it to bring the needle back down.
I would also check to see if your fan is turning on.
usernamehere is offline   Reply With Quote
Old 07-23-2010, 08:18 AM   #6
havnfun328
My Ride: '99 328i, '03 M5
Manuals only have an electric fan. Mine failed and the symptoms were similar. Does your AC kick off when you are sitting idle? The fan may still run, but not fast enough to cool the radiator and condensor.
It's an easy fix but the part is pricey.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 07-23-2010, 09:39 AM   #7
BimmersGarage
My Ride: E46 330i
Originally Posted by Goondaddy View Post
Your viscous fan could be busted. Try holding a newspaper against the fan when it is spinning, it shouldn't stop...
Good suggestion, BUT...
@OP
Since you have an electric fan, don't do this.
