Old 07-23-2010, 10:49 AM   #1
chirag425
My Ride: 02 M3
CAR came with two keys but remotes don't work.
HI I just bought 02 m3.
car came with two keys.
remotes don't do anything. i can lock/unlock using key in to the door.
do i have to make a trip to stealership and pay money to program it??
can i do it myself?
thank you all.
chirag425 is offline   Reply With Quote
Old 07-23-2010, 11:13 AM   #2
golf_234
My Ride: E46, E90
you can do it yourself search program key .. its some weird sequence. i did it for my neighbor
golf_234 is offline   Reply With Quote
Old 07-23-2010, 11:14 AM   #3
golf_234
My Ride: E46, E90
1. Unlock the car doors using your original key.
2. Get in and close (don't lock) all the doors.
3. Put the key in the ignition and turn it momentarily to position 1 which is the first position when you turn the key clockwise. This is the accessory position. Don't stay in position 1 longer than 5 seconds; then turn the key back to the off position.
4. Remove the key.
5. Now, on the key, press and hold down the unlock button while at the same time press and release the lock button three times within 10 seconds while still pressing the unlock button
6. release the unlock button
7. The system indicates re-initialising by locking and immediately unlocking the door locks.
Old 07-23-2010, 12:57 PM   #4
Andy2108
My Ride: SpecE46 & E46 M3
the stealership can hook up your key and look at the info on it. if they can do that then i suppose the battery must be good. if so, then do that ^
if not, then new battery diy or new key from dealer
De gustibus non est disputandum.
Old 07-26-2010, 09:12 AM   #5
chirag425
My Ride: 02 M3
thanks, I'll try this..
4. Remove the key.
Old 07-26-2010, 09:50 AM   #6
golf_234
My Ride: E46, E90
there was a slight variation i came by on the forums that i used that definitely worked that i believe was slightly different than that one ^^^ where the guy said "i do this at work all the time" and his procedure definitely worked .but i couldn't find it if that doesnt work i would search a bit more trying to find whatever thread i was on.
Old 07-26-2010, 09:55 AM   #7
golf_234
My Ride: E46, E90
well, i had trouble finding the exact post i was talking about but did find more valuable info in regard to the second key.. also, it looks as though people have confirmed this process on this thread
Originally Posted by three2slick
Takes 1 minute. Go to your car right now, make sure it's locked. Unlock it, get in, close the door, put the key in the ignition and turn the key to the point all the dash lights come on but DON'T start the car. Then turn the key back and take the key out. Now hold the unlock button and press the lock button 3 times while you hold the unlock button, then after you have pressed it 3 times, let go of the unlock button. The doors will lock and unlock to show it has been initialized, if you have a 2nd key, follow the same procedure but you just do the button sequence, you don't put the key into the ignition.
Old 07-26-2010, 10:03 AM   #8
mrwech
My Ride: 00 328i
thats a problem with e46s,so even a trip to the stealership wont save you...it has something to do with a gm5 module gone bad.
http://www.bmwgm5.com/
mine works sometimes and i have to manually unlock it sometimes.
mrwech is offline   Reply With Quote
Old 07-26-2010, 10:59 AM   #9
tntempest
My Ride: E46 M3 2003.5
In my case my remote did not work, then one day while I was taking it apart to fix the battery it started working all of the sudden, somehow all the force made the connection happen. In my case the battery lead had broken. I was able to just put a dab of solder and fix it. It's hard to get the key itself open, but it's worth it if the reprogramming is not working. There is no telling how long it had not worked (it was like that when I got it) and it was my only key. So it must hold it's memory even if the battery dies.
Current, worn out 2003.5 E46 M3 with 170k miles, Silver, fixing 13 years of neglect.
Previous BMW rides, 91 E30 318IS, 89 E30 325is, 96 E36 328is, 98 E36 M3, 99 E39 540 Sport, 00 368 M Coupe, 01 E46 330Ci, 2003 M3 Carbon Black, 1997 328IS, 2011 335 Sport sedan,
tntempest is offline   Reply With Quote
Old 07-26-2010, 12:19 PM   #10
chirag425
My Ride: 02 M3
thanks a lot. i am at work right now. I'll go back and try this as well when i get home in the evening.
