Old 07-26-2010, 12:28 PM   #1
Washburn
My Ride: 2005 AW 330Ci ZHP
Exclamation Repair History - opinions?
Can some tell me if i should run from this or is it not bad?
My biggest worry is that "permanent heating failure/thermostat" part - what's that about?
Thanks a lot IA.
Repair History (Claims)
Center
ID
Loc
ID
Claim
Number
Repair
Order
Number
Repair
Order
Date
Repair
Entry
Date
DAVIS
Mileage
Defect Code/Description
24987
01
811080
153755
01/04/2010
01/06/2010
N/A
25,384
3241054800
Hose from pump to steering gear leaking
24987
01
796290
151004
11/16/2009
11/18/2009
N/A
24,333
1011004700
Cold start drop in engine speed
1153121200
Characteristic map thermostat, heating permanent failure
6121001200
Vehicle battery permanent failure
24987
01
718100
137437
04/03/2009
04/07/2009
N/A
20,542
1142004800
Full-flow filter body leaking
34000077MP
BRAKE FLUID CHANGE- FULL MAINTENANCE PROGRAM
61610077MP
FT WIPER RUBBER INSERT-MP
85990087MP
MP-LOW MILEAGE ANNUAL OIL SERVICE
24987
01
634190
123177
08/04/2008
08/05/2008
N/A
17,790
5141017800
Arm rests (incl. soft pad) door trim panel, front poor surface finish
46786
01
140040
244366
03/11/2008
03/12/2008
N/A
15,187
0084310100
TCU SIB #84-22-06 AND SIB #84-23-06 #
46786
01
140030
244366
03/11/2008
03/12/2008
N/A
15,187
3332003700
Rubber mount, semitrailing arm (outer, rear, bottom) connection to vehicle body loose
85990089MP
1ST ENG OIL SERVICE-FULL MAINTENANCE
04124
01
862420
468493
04/03/2007
04/05/2007
N/A
10,447
6131621500
Seat adjustment switch, front (without memory) permanent malfunction
04124
01
856800
467460
03/21/2007
03/23/2007
N/A
10,159
10320105MP
STATE & LOCAL TAXES - FULL MAINTENANCE PROGRAM
85990087MP
Washburn is offline   Reply With Quote
Old 07-26-2010, 02:16 PM   #2
Washburn
Bump. Anyone? I searched, BTW, but can't get a clear idea on how bad this service Hx is.
Old 07-26-2010, 11:17 PM   #3
chet31
My Ride: 05 330i convertible
Just a guess, but this "permanent" seems to simply mean the part cannot be fixed. For example, "permanent battery failure," i.e. it needs a new battery. Your car needed a new thermostat, not all that unusual, and not that serious on a BMW, since they simply stick open when they fail (engine does not warm up as fast, it does not cause engine to overheat). You could also call the dealer where the repair was made and ask them what they mean by the term.
chet31 is offline   Reply With Quote
Old 07-27-2010, 04:24 AM   #4
akhbhaat
Lying, drunken cheat
My Ride: German Civic
There are no red flags in that history. You should know that these descriptions are taken from a standardized proprietary list and so they aren't necessarily accurate or precise.
I'll translate for you:
Minor power steering leak--extremely common in the E46. My 323i had it when it was as little as four years old; I drove it that way for another five years and never bothered to fix it because the leak was so gradual that it was a hell of a lot cheaper and easier to routinely check (and refill) the fluid.
1153121200
Low or wavering idle; can cause hesitation or stalling. Common problem with 330 ZHPs before an ECU reflash. Is this car a ZHP?
This can also be caused, for example, by a bad fuel filter. There's a pressure regulator built into the fuel filter of later E46s. When it goes bad, there isn't enough residual pressure in the system to feed the engine after it sits for a long period (e.g. overnight--hence cold engine), so the car will struggle to start and maintain idle until the pump has enough time to get everything going.
6121001200
The thermostat is just a valve that adjusts the flow rate of engine coolant from the radiator. In doing so, it regulates the temperature of the engine: in a cold engine, it will close somewhat to help the engine warm up quickly. Once the engine warms, it will open further as needed to prevent it from overheating.
In this case it failed, probably in the "full open" position (by design, to prevent engine damage from overheating). When this happens, the engine fails to warm to operating temperature, which adversely effects fuel efficiency and increases engine wear. While no significant damage occurs (provided it doesn't stick shut, which can cause overheating), it is inadvisable to run it hard under these circumstances. Very common on higher mileage cars, which is why the thermostat is considered a preventative maintenance item for cars with 75-85k miles. That's a very low mileage for a thermostat failure, but suffice it to say that it's just a single component.
Dead battery. It happens.
A recall that affected the Bluetooth/BMW Assist module.
85990089MP
Bad trailing arm bushing...who knows why. Could have been that way from the factory. Since it happened at low mileage, the owner probably complained about some light clunking or rattling and that was some tech's diagnosis of the problem.
No significant quantities of judgment-impairing narcotics were consumed during or before the creation of this message.
akhbhaat is offline   Reply With Quote
