bmw stock jack is a pos, recommend a good one - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-26-2010, 06:41 PM   #1
oleo
My Ride: 325
so i got a flat this weekend and used the bmw jack. what a piece of shat. it puts all the weight on this one little area.
i had to move it twice because it broke through the pavement and sunk through.
can someone recommend a good but affordable jack?
i also realized how out of shape my fat ass is, i was sweating like a pig while changing the tire. it was 105 degrees, but i stopped under a bridge.
oleo is offline   Reply With Quote
Old 07-26-2010, 07:28 PM   #2
Toad21
My Ride: 00' 328CI
To your credit, it was wicked hot out lately. Solar Maximus is approaching, and it will just keep getting hotter seasons for the next 2 years.
I bought the Autozone 2ton jack with 2 stands for 45$, but the menards 2 1/2 tons is better. A pair of plastic ramps for 20$, I use them all the time and make jacking up this car WAY easier.
Drive onto ramps, then put jack stands under the 2 mounting points. Then jack from the center engine jackpoint using a block of wood for better weight dispersal.
As you will notice, no good jack will fit under this car period. You will either need to jack up with that crap jackstand that came with the car, or drive onto ramps which is way faster.
Goto Menards/Lowes/Home Depot and buy a 30-50$ 2 ton or larger jack. Go ahead and pickup a few stands and a pair of ramps while you are at it.
Toad21 is offline   Reply With Quote
Old 07-26-2010, 09:27 PM   #3
330exeye
My Ride: 2004 330xi
I'm pretty sure most pep-boys carry this, its a 2ton low profile jack, comes in a plastic carry case, I use to drive around with it in my trunk with my lowered Jetta. the widow-maker has earned its name for a reason. god forbid your on an un-level surface, or even worse gravel :headbang: blew out two tires on a dirt gravel rd and all I had was the widow-maker. luckly I had a text book in my trunk i put the jack on.
Originally Posted by DJ Reminisce View Post
It is indeed called E46fanatics, not E46wellthiscarisokthewayitissowhymodit
330exeye is offline   Reply With Quote
Old 07-26-2010, 09:29 PM   #4
deadpass
My Ride: 01 330i
get a 10 dollar scissor jack for roadside emergencies. they work fine and will fit under lowered cars better. for the garage get a decent jack and some stands.
deadpass is offline   Reply With Quote
Old 07-26-2010, 09:35 PM   #5
Brinkley
My Ride: 99 328i, 07 z4 3.0
I got an aluminum race jack at the Freight for 70 thats where its at
Brinkley is offline   Reply With Quote
Old 07-26-2010, 09:38 PM   #6
sea6speed
My Ride: 2010 335i Msport 6MT
Yeah... I replaced all 4 wheels this week in direct sun using the pitiful stock jack. I sweated like a pig, and I run 20+ miles a week...
sea6speed is offline   Reply With Quote
Old 07-26-2010, 11:24 PM   #7
WBVenom
My Ride: Car 54
Scissors-type for mobile carry-around.
The harbor freight lightweight aluminum racing jack for the home.
Super-low, strong, lightweight. Badass.
WBVenom is offline   Reply With Quote
