E46 Xi Forum
Old 07-27-2010, 12:31 AM   #1
2003zhp
My Ride: 03 330i zhp 02 330xi
replacing shocks on xi. will i need a 4 way alignment?
i changed out my oem shocks with blistien sport shocks. will i need a 4 way alignment or will this be fine?
thanks
2003zhp is offline   Reply With Quote
Old 07-27-2010, 01:31 AM   #2
dakkon
My Ride: e46 330ci/e30 318is
if you mark the bolts on the front shocks, so you can get the bolts back in the same spot the current ones are you "should" be ok... ideally you should get an alignment... are you changing the springs, ride height by chance? if your changing the ride height then you will need an alignment.
dakkon is offline   Reply With Quote
Old 07-27-2010, 01:33 AM   #3
NOVAbimmer
My Ride: E60M
an alignment after changing suspension parts is never a bad idea
NOVAbimmer is offline   Reply With Quote
Old 07-27-2010, 02:07 AM   #4
e36-2.0
My Ride: 330xi
yup
suspension shouldnt be too far off with the old vs new shocks. geometry only changes with lowered springs or coilovers. you shouldnt need to mark anything because your front suspension has pins to ensure properly lined up.
'02 330xi
Konigsport/Ground Control/DPE/BMW Motorsport/Eurosport/Turner Motorsport/PowerFlex/RacingDynamics/Hotchkis/UUC/Beisan/Bimmerworld/Dinan/Conforti/RPI/GroupN/Technik/Dynavin
Alberta's BMW enthusiast forum.
-Projecttechnik.com
e36-2.0 is offline   Reply With Quote
Old 07-27-2010, 03:42 AM   #5
2003zhp
Originally Posted by e36-2.0 View Post
yup
that good to know. i had a 4 way alignment done when i lowered the car with h&r springs on my oem shocks. that was about 2,000 miles ago. then the oem shocks blew and thats why i just changed over to blistiens.
so since i did not change the height of the car i should be good then.
Old 07-27-2010, 11:18 AM   #6
lab rat
My Ride: '02 330iT
actually I lowered my car with H&R sport springs (replacing OEM sport springs) and had the alignment checked - still within spec
Old 07-27-2010, 11:25 AM   #7
dakkon
yup
the camber could be way off though. without marking it, you will not be able to get the camber the alignment place set... you might wind up running positive camber, and not even realize it....
That is unless you just run max neg camber on both sides
Old 07-28-2010, 03:18 PM   #8
e36-2.0
My Ride: 330xi
it could.... if you install it completely wrong and dont line up your pin. again, changing shocks does not change the geometry of your suspension and its hart not to install it properly.
'02 330xi
-Projecttechnik.com
