Old 09-11-2010, 05:39 PM   #1
scrappy361
My Ride: 2003 325i
Car don't hold compression in 4 cylinders
I was driving one night and my car just shut off, took the valve cover and checked timing and it was on time, I checked the fuel pump and it is good, when I put a little bit of oil in the cylinders it will run for a short period of time, so me and the mechanic I took it to are stumped, any ideas??
scrappy361 is offline   Reply With Quote
Old 09-11-2010, 06:08 PM   #2
andyman7931
My Ride: e39, e46, e83
Did you do a compression test?
andyman7931 is offline   Reply With Quote
Old 09-11-2010, 06:11 PM   #3
ChasCan
My Ride: 2001 330xi
+1. Most definitley. Chas
ChasCan is offline   Reply With Quote
Old 09-11-2010, 06:14 PM   #4
scrappy361
My Ride: 2003 325i
Yea and it had low compression but when I put oil through the spark plug hole the compression built up enough to run then it lossed it agin and shut off
Old 09-11-2010, 06:20 PM   #5
ChasCan
My Ride: 2001 330xi
That is a classic sign of bad piston rings or a cracked piston. Sorry. Chas
Old 09-11-2010, 06:57 PM   #6
scrappy361
My Ride: 2003 325i
Thanks for the help much appreciated
