Sponsored by The Tire Rack
Old 07-30-2010, 01:47 AM   #1
smoke96
My Ride: 2004 325ci
bbs center caps in ASA ar1's?
just wondering if they fit?
[QUOTE=Back2Basics;11538236]So you're gonna have your food delivered to you while you sit at your computer screen on the 112th floor responding to questions about dildo's and sex lube's while strangers fill your bank account to acquire the tools needed for their sick, guilty pleasures?
That's pretty ****ing legit man.
smoke96 is offline   Reply With Quote
Old 07-30-2010, 07:19 AM   #2
shadow 2
My Ride: 07 328i
Why would you use them if they did fit?
shadow 2 is offline   Reply With Quote
Old 07-30-2010, 12:06 PM   #3
smoke96
My Ride: 2004 325ci
ASA is owned by bbs.
Old 07-30-2010, 01:21 PM   #4
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
ASA isn't owned by BBS. Its owned by Hankook Tires. BBS just helped them setup their wheel manufacturing factory. "Licensed by BBS" does not mean that they are "Owned" by BBS.
In any case, you would not be able to use genuine BBS center caps, as BBS center caps are generally 68mm where as most if not all OEM and aftermarket wheel manufacturers use a 64mm cap. Although, BBS has provided OEM BBS branded wheels to Subaru and Volkswagen, so you might want to check if they have 64mm BBS caps, then your next issue would be, if they snap in or not, as BBS has two or three different backs to their caps.
Just don't put the BBS caps on your ASAs, its tacky.
MrMotorwerk is offline   Reply With Quote
Old 07-30-2010, 01:36 PM   #5
jerseyfresh
My Ride: is schwartzed out
You didn't get the memo?
There's no such thing as being too tacky in Dirty Jersey...
We have television shows and 20" chrome wheels on E46's to prove it...
Originally Posted by trhine View Post
FYI you look like a over weight fortune cookie.
^^^Directed @Kpeng^^^
jerseyfresh is offline   Reply With Quote
Old 07-30-2010, 03:11 PM   #6
jeremykrak
My Ride: n/a
Send a message via AIM to jeremykrak
fvck snookie and jWOW
jeremykrak is offline   Reply With Quote
