Sponsored by BAVSOUND
Old 08-02-2010, 06:35 AM   #1
ZLAT46
My Ride: M-Sport Ci
Cant find steering wheel control harness!!!
hi guys,
my car had an aftermarked headunit installed, i am now in the process of installing the dynavin unit, ht eonly problem is i cant find the steering wheel cables/connectors as they must have been either tucked away somewere,
does anyone have any ideas how i can locate them, which side they come from? are they attaached or tapped up with another harness? i look all around and as far as i could see i cant find them
or is it possible if i took off some plastics under the steering wheel and tried to back track
i know its a dumb question but i really cant find the suckers \
thanks guys
ZLAT46 is offline   Reply With Quote
Old 08-02-2010, 07:28 AM   #2
Darkoz
My Ride: E46 325Ci
If I read your question correctly, you're looking for the existing factory radio harness which is behind the headunit, if so then the harness looks like the pic below.........
If it's not there then it has most probably been cut off when the aftermarket stereo was installed in which case you'll have to match and splice the loose wires into the supplied Dynavin harness adaptor.
It'll be time consuming but certainly not impossible.
Below is a pic the Dynavin harness adaptor, the square black plug with the pins in it at the bottom right of the pic......
Darkoz is offline   Reply With Quote
Old 08-02-2010, 05:32 PM   #3
ZLAT46
My Ride: M-Sport Ci
thanks for your reply,
what im after in the actual 2 plugs that clip into the factory harness which are for the steering wheel controls? does that make sense? sorry i probably didnt explain myself properly in the original post
Old 08-02-2010, 05:45 PM   #4
Arty
My Ride: 1999 328i
The two 10 pin plugs are for the BMW cd changer and other stuff. The steering wheel controls come via the ibus which is on the 17 pin plug. Google Images for BMW 17 pin to see what connections go where.
Sent from my phone.
Arty is offline   Reply With Quote
Old 08-02-2010, 05:53 PM   #5
ZLAT46
My Ride: M-Sport Ci
so the 2 10pin connectors have nothing to do with the steering controls?
theres the 2 plugs i cant find, the only thing is i installed the after market unit years ago, and some some reason think those 2 plugs were there and now for the life of me cant find them anywere
Sent from my phone.
Old 08-02-2010, 05:58 PM   #6
ZLAT46
My Ride: M-Sport Ci
the 2 10 pin plugs in saying are the ipod and cd changer?
my car never came with a stacker, or anything so would i have these connections?
Free Image Hosting
Old 08-02-2010, 06:02 PM   #7
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Anyone have the part number for the control board on the wheel?
It's shorting out and turning the volume up when I turn
Lol
DIY. On how to replace it?
Tia
JonJon is offline   Reply With Quote
Old 08-02-2010, 08:19 PM   #8
Darkoz
My Ride: E46 325Ci
As Arty mentioned the steering wheel controls come via the factory harness shown in your pic above and the pic I posted earlier, they are not seperate plugs.
Old 08-02-2010, 09:27 PM   #9
ZLAT46
My Ride: M-Sport Ci
So when you hoocked up your dynavin, did you use those 2 10pin plugs for anything? do they connect up to anything?
Old 08-02-2010, 09:30 PM   #10
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
no, they are not used
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 08-03-2010, 12:23 AM   #11
ZLAT46
My Ride: M-Sport Ci
great, answers my question perfectly
thanks for that, appreciate it
Old 08-03-2010, 02:33 AM   #12
Arty
My Ride: 1999 328i
Lol
Tia
There is no direct connection between the button on the wheel and the stereo. The button data is converted into iBus commands and sent over the iBus, along with the cruise and other buttons. So if you are having problems you need to replace the buttons on the wheel, and the part number should be available on RealOEM.
Old 08-12-2010, 01:30 AM   #13
ZLAT46
My Ride: M-Sport Ci
Ok my dynavin is installed, my steering whel controls still don't work, everything has been connected properly via a factory harness, so it's not just clipped together, is there any fuses maybe for steering control? The thing that gets me is they worked just fine before installing the dynavin!
Hope someone can help
Old 08-12-2010, 02:10 AM   #14
Darkoz
My Ride: E46 325Ci
I would bet that you forgot to connect the steering wheel control harness that came supplied with the Dynavin, its the black box with the "headphone" style mini plug at one end, it should be plugged into the "IR in" cable on the back of the Dynavin.
Old 08-12-2010, 03:39 AM   #15
ZLAT46
My Ride: M-Sport Ci
i pluged the headphone style jack directly into the rear of the headunit, or was that maybe ment to be for the mic??? is it an actual cable? or plug at the rear of the unit
thanks darko
Old 08-12-2010, 04:27 AM   #16
Darkoz
My Ride: E46 325Ci
thanks darko
No that is for the microphone, you need to connect it to one of the black cables coming out of the Dynavin wihich is labelled IR in
Old 01-05-2013, 10:08 PM   #17
Alpine
My Ride: 2002 E46 BMW 330Ci
OK guys, I'm now at this point as well. I have a Dynavin V5 and my steering wheel controls aren't connected at all. I have the black box with the headphone style mini plug as supplied in the Dynavin box. I have plugged the headphone style mini plug into the IR IN plug but where do I connect the black box to?? I can't find any matching connection.
Alpine is offline   Reply With Quote
