Sponsored by The Tire Rack
Old 08-04-2010, 09:31 AM   #1
m3collins
My Ride: 2002 Carbon Black M3
Post up if you have VMR CSL 19" 9.5" front wheels on your M3
Please only post if you have 9.5" in 19's on your E46 M3 with a 245/35/19 tire. I'm trying to see who has these wheels on their M3 for fitment questions. An even bigger plus would be those that are on stock style struts and H&R springs.
If you apply please response to what offset you have, what tires you are running, and what spacer if any. I know about SIN but he is running too narrow a tire for my liking.....uber stretched FTL.
Thanks!
m3collins is offline   Reply With Quote
Old 08-04-2010, 01:22 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Typical sizing for the M3 would be a 19x8.5 ET35-40 245/35/19 and 19x9.5 ET20-25 275/30/19. You can also run a 19x10 ET38 from VMR for the rear.
Old 08-04-2010, 01:25 PM   #3
m3collins
9.5 fronts have been done.......I'm trying to find these people. I must suck at searching as I can't find the ones other than SIN.
Old 08-04-2010, 01:49 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
VMR V713's 19x9.5 +33 up front with a 10mm spacer and a 245 tire. Clearance was extremely close to the outside and fender work was required.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 08-04-2010, 02:32 PM   #5
m3collins
-Charles@VMRWheels
Thanks. Was the 10mm spacer neccessary? Could you get away with a smaller spacer?
Old 08-04-2010, 05:15 PM   #6
david @ eas
Past Site Sponsor
My Ride: E46 M3
Depends on the coilovers... The worst clearance I've seen would be KW V3's. But some can get away with 5mm's if the coilovers permit it. And please don't shoot me because I don't have pictures lol... A handful of customers have done this set up that I know of, but as for spacer size you'll have to figure that out once you get in there and test the wheel up front.
Good luck
david @ eas is offline   Reply With Quote
Old 08-04-2010, 07:20 PM   #7
Midnight Run
My Ride: 05 E46 M3 ZCP
19x9.5 +22 front, 19x10 +13 rear (w/ 12mm spacers)
05 E46 M3 ZCP
TCKline Coilovers
SPC LCA camber kit
Macht Schnell wheel spacers
Macht Schnell comp. studs conversion
ADVAN RZ-DF 19x9.0 +22 / 19x10 +22
Midnight Run is offline   Reply With Quote
Old 08-04-2010, 07:38 PM   #8
SIN3
My Ride: Fitment Connoisseur
Send a message via AIM to SIN3
hi !
2006 M3 Cabrio
2004 ZHP Cabrio
/stanceworks\
"keep it clean, keep it OEM+"
SIN3 is offline   Reply With Quote
Old 08-05-2010, 07:25 AM   #9
m3collins
Good luck
I'm on stock struts! Forget coilovers....will stock struts rub?
Old 08-05-2010, 08:38 AM   #10
GunMoto
My Ride: EG8 | E46 | W211
Send a message via AIM to GunMoto
BMW M3 CSL
19x9.5 et27 BMW OEM CSL Wheels
265/30-19 Michelin Pilot Sport Cup
Square setup
no additional info on suspension (it definitely looks lower than a factory CSL)
GunMoto is offline   Reply With Quote
Old 08-05-2010, 08:47 AM   #11
SalM
My Ride: Shhh
Originally Posted by SIN3 View Post
hi !
This. My Favorite ///M with concaved rims
SalMPhotography
SalM is offline   Reply With Quote
Old 08-05-2010, 08:54 AM   #12
m3collins
In the pics it looks killer. Get behind it and you see the retarded stretched tires.....
But to each his own.....just not my cup of tea. If he's happy with it that is all that matters.
Old 08-05-2010, 12:43 PM   #13
VMRWheels
VMRWheels's Avatar
This setup will be hard to find... Most M3 guys who usually go 9.5" fronts, go with a purpose and most are lowered on coilovers for either a slammed fitment or an aggressive track setup.
Most guys on here are running 9.5 +25 and lower up front with coilovers which is a totally different story as far as clearances go. It looks like you may have to throw your own setup on and see if it works out.
-Charles@VMRWheels
Old 08-05-2010, 12:44 PM   #14
m3collins
That's gonna suck if it doesn't fit! Looks like I need to find someone that will let me test fit their rims.
Old 08-05-2010, 02:00 PM   #15
SIN3
then go with a milder set up and put on the car and if you want more aggressive settings you can just add spacers. or buy another set later. these sell very quick on this forum. you cant expect to get your perfect fitment on the first try. good luck.
2006 M3 Cabrio
2004 ZHP Cabrio
/stanceworks\
Old 08-05-2010, 02:06 PM   #16
m3collins
Yeah thanks. Why am I so adamant on 9.5 you may think? Because I LOVE concavity. 8.5" doesn't have much of that.
