Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 08-05-2010, 07:05 PM   #1
snowcatxx87
My Ride: 04 330CI
DIY: Coupe Rear Windows One Touch Close
Alright, so I have solved the coupe vent's not being one touch close from the factory.
There are 2 parts.
1) Coding your general module
2) Modifying your exsiting switches
1) CODING
You will need someone/indy to code your car to allow one touch close on your rear vents. This is under car key memory, and needs to be set to active.
2) SWITCH MODIFICATION
You will need to take apart your swtiches, that's right, you do not need sedan switches!
I figured this out when I compared a set of sedan switches and coupe switches.
Basically, the up and down movement of the switch translates into forward and backward movement. I'll explain later.
Open up the switches, there are these tabs on either side:
Once inside, it'll look like this:
You see what I have highlighted in green? This part here moves in the direction of the green arrow.
Look at the casing. The REAR buttons have this:
Two pieces of vertical plastic molded stopping the SECOND click UP on your rear switches.
Take a dremel and grind it down.
It will look like this:
Put everything back together, and voila.
One touch close rear vents.
3) VIDEOS
This video shows the two notches both up and down, with a closing of rear vent:
This video shows the vent being closed without holding the switch:
-snowcat
snowcatxx87 is offline   Reply With Quote
Old 08-05-2010, 07:29 PM   #2
intelone
My Ride: e46 M3
Sweet. I only open the rear vents on accident when thinking it was my front window switch. Thanks to this DIY, I don't have to hold on the button to close them. Thanks a bunch. Great writeup.
6MT CB ///M3.:. USMC Vet .:. Univ. Student
///Alpine .:. 9861 .:. H/C 701 .:. S624 .:. JL Audio .:. 300/4 300/2 500/1 .:. 10W6v2 wicked .:. Focal K2Ps
Diamond Graphite v710s .:. KW2s .:. ZCP Rotors .:. 996 Calipers .:. SS lines .:. Textar pads .:. VIS Bootlid
CSL Diffuser .:. CF Grills & Gills .:. Alcantara Steering Wheel & Boots .:. 55w 5000K TFX
My Sequential Turn Signals
intelone is online now   Reply With Quote
Old 08-05-2010, 08:40 PM   #3
TRBOVNM
My Ride: 04 330 CI/04 Cobra
Send a message via AIM to TRBOVNM
hell yeah. I was wondering why they did that when the windows are one touch. I assume the coding is done at the dealer? And I have never heard the term "indy". Is that just another term for a performance shop?
TRBOVNM is offline   Reply With Quote
Old 08-05-2010, 08:40 PM   #4
Chris-TK
My Ride: Mazda
Great write up!
K.
Chris-TK is offline   Reply With Quote
Old 08-05-2010, 08:47 PM   #5
Str86ix
My Ride: 01 325ci
Yea where would u go for coding? I assume the dealer? I hate holding that damn button up wen everything else is one touch
UUC TSE3/ Supersprint headers/3.46 diff/JC Shark injector/BavAuto Ignition coils/NOS 50 Shot/UUC 11.5lb flywheel/Jim Conforti CAI/UUC SwayBarbarian/MZ3 shifter/UUC Clutch line and UUC clutch stop
Str86ix is offline   Reply With Quote
Old 08-05-2010, 08:53 PM   #6
rares
My Ride: 02 S54
Send a message via AIM to rares Send a message via Yahoo to rares Send a message via Skype™ to rares
wow, what a cool diy... thanks a bunch
rares is offline   Reply With Quote
Old 08-05-2010, 10:46 PM   #7
TerraPhantm
My Ride: 2005 M3 Coupe
Just so everyone knows, the flags that need to be set can't be done by the dealer. A shop with an autologic tool (or similar) can do it.
TerraPhantm is online now   Reply With Quote
Old 08-11-2010, 12:10 AM   #8
kuksul08
My Ride: M3
Send a message via AIM to kuksul08
Awesome, I'm putting this on my mod list
indy=independent
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
kuksul08 is offline   Reply With Quote
Old 08-11-2010, 09:06 AM   #9
TRBOVNM
^Thanks for the info. I have my trim out for carbon fiber wrap, so I plan to modify the switches while it is apart. then try to get it coded in the next few weeks.
Old 08-11-2010, 09:08 PM   #10
RogueStatus37
My Ride: '04 330ci
This applies for me as well
As does this
2004 330Ci ZSP 6-Speed
Blackout grills l Smoked Reflectors l CCFL Angel Eyes l Gloss Black Roof Vinyl l BSW Speaker Upgrade l 3.46 Open Diff l BMW Performance SSKl M3 Style Trunk Spoiler
H&R Sport Cup Spring Kit l RHO Tow Hook Plate l Nokya Hyper-yellow Fogs l Stainless Steel Headers l Tuner Slotted Brake Kit l AXXIS/PBR Metal Master Pads l BMW AUX Input Kit
RogueStatus37 is offline   Reply With Quote
Old 08-11-2010, 10:50 PM   #11
SL Blak Soldier
My Ride: 2001 3 Pedal M54b30
Send a message via AIM to SL Blak Soldier
So what you are saying is that anyone with a gt1 can't do this?
SL Blak Soldier is offline   Reply With Quote
Old 09-03-2010, 07:42 PM   #12
theinfamousdrew
My Ride: 911 Turbo / E70
Thats correct...it cant be done in GT1...
if anyone is near me i can do it for them
theinfamousdrew is offline   Reply With Quote
Old 09-04-2010, 09:48 AM   #13
johnca
Modded ///Member
johnca's Avatar
My Ride: E46 Slow CSL
Nice work
johnca is offline   Reply With Quote
Old 10-07-2010, 07:03 AM   #14
Bimmerci330
My Ride: 02 330CI 3 Pedals :)
Send a message via AIM to Bimmerci330
easy mod, Thanks
Bimmerci330 is offline   Reply With Quote
Old 10-07-2010, 12:19 PM   #15
TRBOVNM
really wish I had someone closer to do the coding.
Old 10-07-2010, 12:30 PM   #16
kraimer
My Ride: -04-330Ci-
Send a message via AIM to kraimer
Respect!
kraimer is offline   Reply With Quote
Old 10-08-2010, 01:39 AM   #17
ZZen330
My Ride: 2002 330Ci
Hmm, I want to do this. I actually like to open he rear vent windows often, but I hate holding the switch when closing them!
Anyone know where to code this in BC?
ZZen330 is offline   Reply With Quote
Old 10-10-2010, 09:59 PM   #18
Minnetonka
My Ride: 03 330CI
Any body know of someone in NorCal that can do this?
Minnetonka is offline   Reply With Quote
Old 02-10-2011, 01:54 PM   #19
45jimmy
My Ride: AW M3
Send a message via AIM to 45jimmy Send a message via MSN to 45jimmy
Anyone live in Houston that can help with the programming part?
45jimmy is offline   Reply With Quote
Old 02-11-2011, 04:06 AM   #20
ikiy
My Ride: 320cd e46
i have 320cd 2004
can i do this too or have need to code them ?
if it works to me i can begin in max 1 hour
ikiy is offline   Reply With Quote
