Old 08-06-2010, 01:51 PM   #1
/\/\III
My Ride: /\/\ III
AC problems
Been reading the board for my e46 330i ac problems and I still couldn't find out why the ac is blowing hot air on middle dash vents. When the windsheild button is selected, hot air comes out, but cool air comes through dash. Same goes with the bottom vents when selected, hot air comes out and cooler air comes through the dash.
Trouble shooting included
- Replacing the water valve, which was bad
- Draining out the ac oil and adding oil/refrigerant to 1.63 lbs exact.
Any assistance is greatly appreciated.
Thanks.
/\/\III is offline   Reply With Quote
Old 08-06-2010, 02:14 PM   #2
kc_bimmer
My Ride: 2003 bmw 3525ci
I have the same problem with my 03 325ci . The center vents will blow hot and cold. I was told by the dealership its a common problem the with the electronic flapper thing insdie the dash i dont remember what its called but they wanted over 700.00 to fix it. They told me the whole dash has to be removed.
kc_bimmer is offline   Reply With Quote
Old 08-06-2010, 02:15 PM   #3
/\/\III
My Ride: /\/\ III
is it the same piece that has to be initialized to your car and you have to buy it brand new...what a rip off.
Old 08-10-2010, 05:22 PM   #4
/\/\III
My Ride: /\/\ III
Need help identifying this part on the parts list...
Old 07-02-2011, 12:59 PM   #5
/\/\III
My Ride: /\/\ III
revisited, can someone tell me what part this is.
Old 07-02-2011, 01:21 PM   #6
junkiekommando
My Ride: 02 330i, 91 318is
If the a/c blows hot and cold it may be that you just have to refill the system with r 134a . But make sure you don't over fill it though.. Not sure what electronic flapper you are talking about though
-Carlos
junkiekommando is offline   Reply With Quote
Old 07-02-2011, 01:36 PM   #7
/\/\III
My Ride: /\/\ III
system was recharged exactly, no leaks found, any other suggestions...searching did't reveal anything
Old 07-02-2011, 03:06 PM   #8
junkiekommando
is the a/c compressor engaging?
-Carlos
Old 07-02-2011, 03:09 PM   #9
junkiekommando
Do you know the part # or the actual name of this part? Can't seem to figure out what that is
-Carlos
Old 07-02-2011, 03:15 PM   #10
junkiekommando
Did a shop recharge it or did you diy?
-Carlos
Old 07-03-2011, 07:29 AM   #11
/\/\III
My Ride: /\/\ III
shop recharge it with snap on machine...saw the machine put in exact lbs.
me too, i want to know what the electronic flap is...couldn't find this part on oem.
Old 07-03-2011, 07:48 AM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Let me have a look for you...me and realoem are one!
Start the clock!
Flapper 'thingy' translated into BMW-speak is probably #10.
In my old e36, flaps would stick pretty often, and I'd just spin the dial while changing fan speed and 'knock' it loose.
Perhaps try something similar just in case it is just hanging up a bit. Or, you might somehow be able to open up that flapper manually and leave it open.
Search evaporator replacement if you chose to go in...was just a little battle on here about how long it takes. The guy who did it first time in 8 hours was told that was a great time...just fyi. Ouch!
Make sure your heater valve isn't open, as I have heard of that causing AC to be warmer...whether in all vents or just some, I don't recall...but use advanced search/title search...something like "AC warm" should get you to tons of threads to consider.
Facebook.com/DMAXstandup
Mangofy your E46!
