Sponsored by The Tire Rack
Old 08-06-2010, 09:04 PM   #1
MoE46
My Ride: 2002 325Ci
Need help!
Do a 2004 5 series rims fit on a 2002 3 series? I need a set and my cousin is willing to lend me his but I'm not sure if they will fit. I know the center bore is slightly different but I'm not sure if that slight difference is enough.
MoE46 is offline   Reply With Quote
Old 08-06-2010, 10:18 PM   #2
Penguin Koolaid
Banned
My Ride: Inline Six
Depends on the offsets. It will likely poke.
Penguin Koolaid is offline   Reply With Quote
Old 08-09-2010, 07:26 AM   #3
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Offset is too low.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Last edited by Rudy@Tirerack; 08-09-2010 at 12:13 PM. Reason: corrected center bore error
Rudy@Tirerack is offline   Reply With Quote
Old 08-09-2010, 12:01 PM   #4
Penguin Koolaid
Banned
My Ride: Inline Six
Originally Posted by Gary@Tirerack View Post
Offset is too low and center bore is off enough that you may have vibration issues.
I thought with the move from e39 to e60 the hub bore size changed, and is now identical to the e46/e90.
Old 08-09-2010, 12:12 PM   #5
Rudy@Tirerack
Moderator
You are correct. I was thinking 03, not 04. I'll correct my post.
Old 08-09-2010, 02:13 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Though center bore and rim width may work, the offset on a E60 5-Series is unfortunately too low to work on a E46. Major fender work and stretched tires will be required for this setup. I would recommend looking for the proper 8.5 +35-40 front and 9.5 +45 rear fitment so that you can run the proper tire sizes that are direct bolt-on.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
