Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 4.82 average. Display Modes
Old 09-13-2012, 05:47 PM   #41
maqtu
My Ride: 3 series
Originally Posted by delmarco View Post
Yeah I realized after I did the write up that pre-3/2003 cars seem to be wired different concerning rain sensor and wiper functions.
On my car I don't remember the wire# but basically all the DIY does is tap the S button pin 10 wire coming out the stalk to the wire # that the rain sensor is connected to so when the rain sensor mode is on and it senses rain,then you push S and it activates the wash function at 5 wipe intervals in conjunction with the wipers being activated automatically from sensing rain. S will ONLY work with rain sensor cars and seems to so far only to be working on premium package pre- 3/2003 cars with rain sensor. I'm not sure how the post 3/2003 cars are different but the bentley diagrams show there is a difference.
On the E39 and X5 the S function is more direct and independant from those car's Rain Sensor system. On the euro E39 and X5 and some USA cars it ONLY serves to access a seperate washer tank and/or separate high powered nozzle jet to power wash the windows and headlamps during winter driving.
On th E46 all I did was tap S into the rain sensor -> wiper blade ON wiring. In all honesty "I'm not exactly sure how and why it works but it seems to" (That is actually a famous Einstien quote when he discovered, but couldn't explain, the Lambda constant that balanced his modified field equation)
Oh and one other important thing S doesn't automatically work on its own you have to push it on while the Rain Sensor mode is on. Otherwise with S not pushed you will not get your windows washed automatically.
Hello Delmarco
I install in my e46 323CI year 2000, light/rain sensor and works fine.
Now I want install stalk with S function and my car don´t have wire in pin 10.
Could you tell me, the pin 10 where connects in my car, to general module controll unit? What pin ?
thanks: Thumbup:
maqtu is offline   Reply With Quote
Old 05-14-2013, 08:14 AM   #42
mwstewart
My Ride: E46 M3 SMG Coupé
I just wanted to update this thread in case anyone else, like I, attempts it and finds out it won't work as intended. The correct wiring, for the E39 at least, is as follows:
Pre 03/99 = Switch pin 6 to pin 16 of connector X332 on the General Module.
Post 03/99 = Switch pin 10 to pin 16 of connector X332 on the General Module.
The wire colour is Black/Grey in both cases.
X332 is a 26pin connector on the right hand side of the GM, at the opposite end to a slide-locking 16pin connector full of high-amperage wires.
Intensive Wash was to my knowledge never fitted to the E46 so connection to pin 16 on the GM should be attempted at your own risk.
I will update when I have experimented.
/// Titainium Silver/Black E46 M3
19's - Auto Lights & Wipers - Electric rear blind - Grad tint screen - Harmon Kardon - Heated seats - LED's
Nav Professional - Phone - SMG - Sunroof - TV - Tyre pressure monitoring system - Voice input system
mwstewart is offline   Reply With Quote
Old 05-14-2013, 06:07 PM   #43
TerraPhantm
My Ride: M3 & ZHP
E39 has a GM3 and E46 has a GM5. Both have different pinouts. I don't think intensive wash is an option -- unless some other car that shares our GM5s has the feature
Old 06-06-2013, 06:56 AM   #44
mwstewart
I can confirm that grounding pin 16 opens the right hand side rear quarter window, so this mod is a no-go.
Old 06-18-2014, 01:11 PM   #45
emeni09
My Ride: 320i M54 '01
Maybe I'm not reading it correctly, but in a 2001 E46 where is the S-button supposed to be wired to for the intensive wash? I've read this topic as many times as I could, but since some of the pictures are missing and only 1 person managed to make it work, I can't figure it out how to connect it.
can anyone help me out?
emeni09 is offline   Reply With Quote
Old 01-21-2015, 04:27 PM   #46
TerraPhantm
My Ride: M3 & ZHP
Finally figured out how to do the special wash feature like what's found on the E53.
Run a wire from from pin 10 of the wiper stalk to pin 39 of the GM5's X253 connector (54-pin connector). Then use NCS Expert, and set MIT_SRA_EIN_LENKSTOCK and SRA_MIT_WASCH_WISCH_SW to aktiv.
Only figured this out because I read the Z8 came with the GM5 module, and it does have this feature.
There isn't an extra reservoir of stronger washer fluid like in the E39, but there isn't one on the X5 either. Basically the feature will allow you to activate the headlight washers without having to wash the windshield 5 times
Old 01-21-2015, 05:27 PM   #47
jgold47
My Ride: 2004 X5 3.0
Dude--couple of years too late for me!
Good stuff.
I have an X5, and I've used this 2x and I live in Michigan, so hopefully no one goes rushing out to do this
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 01-22-2015, 06:01 PM   #48
TerraPhantm
My Ride: M3 & ZHP
Haha yeah, I figured out completely by accident. I like the idea of being able to control the headlamp washers independently (my car gets coated very quickly, maybe because it's so low to the ground)
