Sponsored by The Tire Rack
Old 08-09-2010, 09:56 PM   #1
Bigalow311
My Ride: R
staggard tires for 17" e46 325Ci
Hello,
I just got my BMW and I happen to fail my state inspection because of my (R) rear tire. All my tires are different brands so I'm planning on buying 4 new tires as opposed to just buying the tires in question.
My current setup:
Wheels:
http://www.bmwwheels.com/bmwwheels_d...=68&Series=E46
tires:
245/40/17 all around (I don't know why the previous owner had a 245 on a 7.5" wheel...)
My questions are:
Can I get away with a staggard of (F) 235/40/17 (R) 245/40/17?
If not then, will a (F) 225/45/17 (R) 245/45/17 work?
I basically want a staggard setup with the best grip while still maintaining my stock alignment. I don't like the profiles being different sizes hence my desire of the same profile.
Bigalow311 is offline   Reply With Quote
Old 08-10-2010, 10:25 AM   #2
lab rat
My Ride: '02 330iT
I would go with the standard 225/45/17 all around setup. That way you can rotate tires. If you want the staggered look just add 10mm spacer in the back and start saving up for nicer wheels.
Old 08-10-2010, 11:48 AM   #3
Bigalow311
My Ride: R
225 aren't for me. I love hitting corners and that is too small a size for me. I'm going to check the width of my wheels when I get home and decide a tire size off of that.
Sent from my Garminfone using BimmerApp
The ULTIMATE driving machine = Lexus
Old 08-11-2010, 10:59 AM   #4
lab rat
My Ride: '02 330iT
Well, you didn't say anything about performance You can go to 245/40/17 on all corners but that's probably maximum the 7.5 inch rim can take.
Old 08-12-2010, 01:49 PM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Actually 8" is the minimum width recommended for a 245/40/17 wheel. I would do a 235 as the max width OP.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 08-12-2010, 08:22 PM   #6
Bigalow311
My Ride: R
Thanks all for reading and posting. I ended up with the stock config: (F) 225/45 (R) 245/40
