Sponsored by BimmerWorld
Old 08-11-2010, 10:33 AM   #1
rharris21
My Ride: 330CI
Brake problems - loud squeak!
Hi ppl - I'm new to e46fanatics so I just thought i'd see if anyone can help.
I have a squeaky brake problem!
My rear discs are fairly corroded and tbh they need replacing which I will do soon.
The noise though seems to be coming from the front.
Its strange because the discs on the front after examination are like new! and with plenty of pad left.
The noise is a very high pitch (and sometimes seriously loud) squeak as I brake. it squeaks intermittently as i then pull away and tends to die down after 30mph.
I have had it looked at by my brother who's a mechanic but only at home - he seemed to think my calliper might be slightly seized (right is worse than left).
I also had it looked at today by a friend at ATS who has the facilities to have a proper look. He said there were no obvious signs of a problem but did do a few things to try and solve it.
I have only driven it briefly on way home from ATS and it seemed to have been solved but as I pulled into my close, it returned!
I'm not sure whether the noise came from the rear or front. I'm hoping the rear as I know these need replacing.
I just wondered what everyones thoughts were as I have tried and tried to solve this problem.. but so far to no avail!
Any help is greatly appreciated as driving with LOUD squeaky brakes is slowly driving me mad!
Thanks.
rharris21 is offline   Reply With Quote
Old 08-11-2010, 10:38 AM   #2
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
What kind of pads are you using? Some pads squeal a lot more than others.
Did you compress the calipers back into the piston when you had them checked? That should help you determine if they're frozen or not...but if they were frozen your brakes would be super hot. Your brakes will feel like an oven when you get near it. It's unmistakable.
I would spray it down with brake cleaner and see if that solves your problem.
JetBlackE46 is offline   Reply With Quote
Old 08-11-2010, 10:51 AM   #3
rharris21
My Ride: 330CI
I presume they are cheap pads. The front brakes look almost new upon inspection but they are as I brought the car. Have had the car 4 months. I haven't compressed the piston but my friend at a local garage had it yesterday and I believe he tried a few things. I have gone close to the brakes after a long run and they were hot but not super super hot.
it seems as if the pads aren't being released after braking - hard or soft. It seems as if there sticking somehow..
Old 08-11-2010, 11:16 AM   #4
jcns
My Ride: California
OP, take out the front pads.
file the leading and trailing edges of the brake pads at about 45 degrees.
Some pads are already manufactured with this angle, some are not. I have used this trick for 20 years and it works.
jcns is offline   Reply With Quote
Old 08-11-2010, 02:54 PM   #5
mrx733
My Ride: E46, W201
Send a message via AIM to mrx733
put anti-seize or similar on the corners of pad
mrx733 is offline   Reply With Quote
Old 08-11-2010, 04:30 PM   #6
rharris21
My Ride: 330CI
Thanks for the help. I am going to try this tomorrow and I will let you know how it goes!
Old 09-30-2010, 12:52 PM   #7
drfreeman
My Ride: 330i ZHP Titanium Si
I have the same problem. My front pad is almost gone but no warning light. It squeak when apply brake and squeak when slowly move away from stop sign. It stopped when reaching 10 mph. It squeak again on the driveway. So, I changed a pair new zimmerman rotor with hawk hps pad, the problem are the same. I suspect the squeak may related to wheel bearings ? or alignment issue. I have no clue
drfreeman is offline   Reply With Quote
