Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 12-30-2010, 11:53 PM   #21
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Originally Posted by AL330CI View Post
McSpeed,
To remove the OEM damper, besides the special Baum crank pulley removal tools (I'm using a toolset from Koch Tool), is there other special tools required? I'll probably be removing mine to do t
Besides the micrometer and damper holder, no. Unless you consider a long pipe to be a special tool.
Assuming you have a manual and don't need the fan clutch wrench.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-31-2010, 12:38 AM   #22
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by bigjae1976 View Post
This is a what if. What if I start pressing the damper on and I line up the woodruff key incorrectly? Will it be a total PIA to remove the damper and try again? Can I adjust the damper to line up after I start pressing it on? Or am I totally focked and I should just do it right the first time?
I think it just has to line up well enough the first time - otherwise I'm pretty sure it'll suddenly get REALLY hard to press the damper on (up to the structural limits of the the woodruff key I guess lol). Also, the closer it gets to the woodruff key slot-in point, the harder it'll be to correct the alignment, thanks to the interference fit, IIRC. The antiseize helps a bit though. The press tool makes it easy to back off if you need to; the slot gives you a little fudge room, too- so it shouldn't be too dificult.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 12-31-2010, 02:54 AM   #23
bigjae1976
bigjae1976's Avatar
OK, thanks! So it is semi-idiot proof? I might survivie this DIY then. Can't be worse than the clutch.
Old 12-31-2010, 03:48 AM   #24
McSpeed
If you're comfortable doing a DIY clutch install in the snow, this should feel about as easy as making pancakes
Old 12-31-2010, 04:38 AM   #25
bigjae1976
bigjae1976's Avatar
Frozen or homemade?
Old 12-31-2010, 04:43 AM   #26
McSpeed
Frozen or homemade?
Like from a mix where you add water
Old 12-31-2010, 06:40 AM   #27
bigjae1976
bigjae1976's Avatar
I messed up stove top stuffing a couple of weeks ago...maybe I should pay to have this done.
Old 12-31-2010, 02:02 PM   #28
McSpeed
that could've happened to anyone! try it again with air tools and we'll see
Old 07-08-2011, 01:33 PM   #29
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Just reread. I have everything to do this except the big torque wrench....
Old 07-08-2011, 02:19 PM   #30
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I honestly don't think it's a big deal: I just used a 2 ft long breaker bar on a 22mm impact socket and gave it a good yank.
On the OEM damper, the bolt was a critical part of the damper coupling. On the ATI piece, I honestly think you could leave the bolt off and the engine wouldn't know any better.
Up to you...but I won't be using a torque wrench on this. (I do religiously on pretty much every other bolt on the car though)
Old 07-08-2011, 02:59 PM   #31
aggieE46
Keep it clean
aggieE46's Avatar
Even better news.
I should be good to go, then. Just want to dyno the AA tune by itself, first. Woot!
Old 07-08-2011, 06:17 PM   #32
bigjae1976
bigjae1976's Avatar
Crap. My public admission to messing up stove top is being bumped to the top.
How long should this take an average person to do that has the right tools?
Old 07-08-2011, 07:46 PM   #33
aggieE46
Keep it clean
aggieE46's Avatar
Average??? I'm offended!
Old 07-08-2011, 08:19 PM   #34
TxZHP04
My Ride: ESS TS2+ ZHP
Stove Top takes maybe 15 minutes, no special tools required.
Old 07-08-2011, 10:38 PM   #35
bigjae1976
bigjae1976's Avatar
You're not average and I hope you'll be 2x as fast!
Old 07-09-2011, 01:04 AM   #36
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Should have it done (Down) pack now
BimmerBrakes is offline   Reply With Quote
Old 07-09-2011, 07:45 AM   #37
aggieE46
Keep it clean
aggieE46's Avatar
Oh, now we're getting personal... wait, what?
Old 07-10-2011, 11:41 PM   #38
Blocked Out
My Ride: Imola 330i M-Sport
Awesome write up, thank you.
Quick question, if anyone knows teh answer it'll be very good.
Why does ATI needs to be interference fitted as opposed to OEM which just slides in and out?
I know that -0.001 fit is not that much but why not just make it to slide in and out.
I thought came to my mind, we do alot of interference fits at work (Im a die maker btw) , we freeze whatever needs to be interference fitted and then slide it into whatever it should go into. This way we can fit a 3.0000 shaft into a 2.9985" hole, try doing that with a pulley , lol.
Anyway, you think its safe to freeze the damper ?
Original BMW Teile ///
IMG_1725
Old 07-11-2011, 07:32 AM   #39
McSpeed
If the buna rubber damping material can take it I don't see why not. Maybe doublecheck with ATI first just in case. The superdamper is combination of an aluminum casing and a steel hub if thermal contraction properties matter.
The ATI's interference fit makes it so the damper becomes part of the crank and that directness helps it damp better; the full seating surface of the damper is engaged and there's no slop for the harmonics to hide in.
With the oem damper not being as tight and primarily relying on the bolt for attachment, it can end up just having a solid connection at the very end, so all the damping action gets done through less material. Also, the rest of the hub therefore sees some room for micro-wiggle, which leads to some distortion or wear of the hub, apparently, since everyone seems to say that their OEM damper slides off by hand.
I could be wrong but I don't think the OEM damper extraction tool would exist if the dampers were factory specced to slide off by hand...
Old 07-11-2011, 10:05 AM   #40
aggieE46
Keep it clean
aggieE46's Avatar
Interesting thought on the freezing. I've done that with solid aluminum bushings before. Definitely makes it easier.
That being said, I have the install tool to use
