Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 07-11-2011, 10:28 AM   #41
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by Blocked Out View Post
I thought came to my mind, we do alot of interference fits at work (Im a die maker btw) , we freeze whatever needs to be interference fitted and then slide it into whatever it should go into. This way we can fit a 3.0000 shaft into a 2.9985" hole, try doing that with a pulley , lol.
Anyway, you think its safe to freeze the damper ?
Wait- if the damper's hub is too small to go on easily, wouldn't you want to heat it up to make it bigger? IIRC they recommend not doing that.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 07-11-2011, 08:42 PM   #42
Jackcat559
My Ride: 2003 530
no need to heat it up. Just use a dab of heat resistant lithium grease. and the install tool. Goes on in about 2 minutes.
Jackcat559 is offline   Reply With Quote
Old 07-11-2011, 10:14 PM   #43
Blocked Out
My Ride: Imola 330i M-Sport
Ya, my bad. Mixed up the two.
Anyway, it was just a thought that came to my head . Wouldn't be possible because you cant really heat it up that much, and you cant freeze the snout.
Original BMW Teile ///
IMG_1725
Old 12-27-2011, 12:49 AM   #44
BimmerBrakes
The Brake Newbie!
My Ride: 2005 ZHP BMW
Send a message via AIM to BimmerBrakes
Will be using this DIY! Thanks for the tips and tricks...
BimmerBrakes is offline   Reply With Quote
Old 01-06-2012, 05:32 PM   #45
TrippinBimmer
My Ride: Just Fast!
Here are some extra pictures when I was doing my install...
http://s1030.photobucket.com/albums/...ATI%20Dampers/
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 10-10-2016, 03:57 PM   #46
Fair
My Ride: Various BMWs
Reviving this old thread. Good tech up in here, thanks!
My wife races a 2001 330Ci in NASA TTD time trial class. It has a bone stock M54 with 162K miles.
The OEM balancer was "slipped" when we bought the car, so we've kept the revs way down (sub-5000) until I could save enough pennies for the ATI bits.
It was obvious that the front seal was leaking, so we will replace that while the stock balancer is out.
Just got an ATI balancer kit from VAC and saw this thread, so we ordered the ATI Damper Puller and Installer kit, part # 918999. We'll give this a shot tomorrow and button the car back up (with VAC oil pump driveshaft and oil pan baffle kits) and hopefully get her back on track this weekend for the final NASA TT event for 2016 in Texas.
Thanks again to the OP for the great pics!
Fair is offline   Reply With Quote
Old 10-14-2016, 10:15 AM   #47
rkneeshaw
My Ride: 330i ZHP
You wont need the installer kit with the newer ATI damper. You only need the custom ATI damper puller/installer if you need to remove the ATI damper later.
See here:
http://forum.e46fanatics.com/showthr...8#post17060628
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
