E46 Xi Forum
Old 08-12-2010, 02:49 PM   #1
cosmith22
My Ride: '02 325XI
325 XI CV Joint/Axle replacement
I have an '02 325XI with 165k on it, my car's front cv boots have been cracked for some time now, leading to joint/axle failure. I'm going to order the remanufactured axles through rockauto, as I can see that the FCP brand axles are crap. Anyway, couple questions. Is there anything else you guys would recommend doing while under the car with the axles off? I read that being I have an XI, the front control arms aren't as problematic as the RWD E46's. Any bushings, wheel bearings, hubs, anything like that that's a common problem or wear part on our cars? Also, I read that the grease for the inner boot is different than the outter boot - anyone know where to get the proper grease for it? Thanks a ton for your help in advance, idk what I'd do without this forum.
cosmith22 is offline   Reply With Quote
Old 08-12-2010, 04:57 PM   #2
330ciandr6
My Ride: .
Send a message via AIM to 330ciandr6 Send a message via Yahoo to 330ciandr6
if you order the axles as a complete unit...why does it matter where to get the grease? just wondering. Check to see if your axle seals are leaking while you are in there. only thing i can think of....
Have a oil or coolant leak? Click here!:http://forum.e46fanatics.com/showthr...732&highlight=
ABS/DSC/Brake/Airbag light on?? Click here!:http://forum.e46fanatics.com/showthr...648&highlight=
330ciandr6 is offline   Reply With Quote
Old 08-12-2010, 05:11 PM   #3
aioros
My Ride: 2001 330xi auto
Check my post for my cv axle replacement, it's not a diy but it may help. you may want to check the tie-rods, control arms inner and outter ball joints and bushings.
aioros is offline   Reply With Quote
Old 08-12-2010, 05:49 PM   #4
bombguy
bombguy's Avatar
My Ride: 2004 M3
Check the FCABS. Also, the dealer has the appropriate grease available.
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 08-12-2010, 05:58 PM   #5
MileHiXi
Banned
My Ride: '02 330xi
You don't need greese if you are replacing the entire axle.
Replace the radial seal no matter what.
MileHiXi is offline   Reply With Quote
Old 08-12-2010, 06:58 PM   #6
bombguy
bombguy's Avatar
My Ride: 2004 M3
They come "pre-packed" don't they? If so, you might be good, if not, refer to my previous post.
2004 JB
Old 08-13-2010, 02:12 AM   #7
cosmith22
My Ride: '02 325XI
Thank you so much guys, called a rep from rockauto and they do indeed come pre-packed. As far as the FCABs go, does anyone have a recommendation as to what brand is the best? I know "best" is a touchy word, but I've heard powerflex poly bushings being mentioned a lot on here and might as well get them unless someone has had a bad experience with em. Thanks again!
Old 08-13-2010, 10:27 AM   #8
aioros
I used the ones from autohausaz made by sachs-boge (oes)
Old 08-13-2010, 02:23 PM   #9
Kubica
My Ride: 2003 325xi
Powerflex fcabs are a huge perf upgrade. You can get xi ones again now, or use centered e36 bushings (part# 401b).
I would also order the redline xi kit from Turner and replace your front diff fluid (all 4 fluids actually) while you are in there.
I have reman A1 cardone axles- they work great.
