Old 08-16-2010, 05:00 PM   #1
46mtech
My Ride: 2001 BMW 330i
grill clips broken... need a quick fix!
the clips to keep my grill on my broke and now the grill is very sloopy and i am afraid of it falling out on me while i am driving.
i have a 2001 330i
if you can think of any simple fixes please share!!!!
2001 330i m-Tech 5spd
Mods: hotchkis sway bars front and rear / smoked corner lights, side markers and tail lights / matte black kidney's / MTECH
46mtech is offline   Reply With Quote
Old 08-16-2010, 05:46 PM   #2
M3 4 DW
My Ride: M3 Vert
Super Glue..JK
Just buy some new grills. I want to say they only ran like $50-75 new.
Dustin
M3 SMG *Nav *ACS Front Lip *Carbon Fiber Emblems *Clear Bumper Reflectors *K&N Drop In *RPI Scoops *Matte Black Side Gills *Matte Black Front Grills *LED Interior kit *Shark Tune *8000k Fogs *Factory 19's on 245/35 - 285/30's
M3 4 DW is offline   Reply With Quote
Old 08-16-2010, 05:54 PM   #3
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
wire tie or zip tie
gorrilla or duct tape
or any combo.... or all at once
lol ........
Bimmer4Lyfe is offline   Reply With Quote
Old 08-16-2010, 05:57 PM   #4
ojbimmer
My Ride: E46 coupe
Send a message via AIM to ojbimmer
yea go to discount auto or any other store and get the small wire and used it. I did and it work perfect without anyone noticing
ojbimmer is offline   Reply With Quote
Old 08-28-2010, 11:37 AM   #5
ThosEM
My Ride: 330Ci convertible
Send a message via AIM to ThosEM
Just had the same problem. The grilles basically fell off in my hands as I tried to raise the hood at the gas station. My fix was to screw a couple of pieces of plastic coathanger in place of the broken off clips on top of the grilles. Then I drilled some holes in the lower tabs and put a setscrew into the frame of the grille to press it up against the upper clips. Seems to work fine. Here are a couple of photos. Sorry there wasn't much light and they are blurry but you should be able to see the screw head holding down the piece of coat hanger in place of one clip (the other clip wasn't broken on this grille). Then you can see the setscrews put through the lower tabs on hood into the grille frame.
ThosEM is offline   Reply With Quote
Old 08-28-2010, 06:30 PM   #6
ThosEM
Trying again with photos...
ID:	373499   Click image for larger version
Old 02-14-2011, 06:04 PM   #7
jkubicek
My Ride: 2005 330i
Broken Grill Clips Solution - $1.50!!!
Check it out!!!
jkubicek is offline   Reply With Quote
Old 02-14-2011, 06:19 PM   #8
e46hellrot
My Ride: e46
Originally Posted by Bimmer4Lyfe View Post
wire tie or zip tie
lol ........
+1 gorilla works, it holds good and semi water proof
e46hellrot is offline   Reply With Quote
Old 05-02-2011, 08:54 PM   #9
Lemonsqr
My Ride: 2001 TiAg 330i
Originally Posted by jkubicek View Post
Check it out!!!
This should be stickied!!! very creative. D4mn you BMW for cheaping out on the plastic pieces....really disappointed!!!
Lemonsqr is offline   Reply With Quote
Old 05-03-2011, 03:05 PM   #10
blue328coupe
My Ride: 2000 BMW 328Ci
Check it out!!!
Wish I had thought of this. My driver's side grille fell out while I was driving. So I took the other one out to at least match, and now I have a grilless BMW.
blue328coupe is offline   Reply With Quote
Old 05-03-2011, 08:53 PM   #11
dare23
My Ride: 328i
I used silicone. The advantage is that it is easy to remove if you decide to get new grills. Also the one I used dries clear so hardly noticable.
dare23 is offline   Reply With Quote
Old 05-31-2011, 01:20 PM   #12
Megasm
My Ride: 02 325xi
lol I used high intensity heat tape
Megasm is offline   Reply With Quote
Old 07-22-2013, 02:31 AM   #13
echung
My Ride: E46
thanks jkubicek, I follow this method and fix it today.
echung is offline   Reply With Quote
Old 07-22-2013, 12:16 PM   #14
rob00150
My Ride: 1999 328i
This happened to my grills too. My friend and I just drilled holes in the rubber parts and zip tied the two grills together. It works perfectly with no rattling or anything.
'99 e46 328i 5 speed, Steel Blue
rob00150 is offline   Reply With Quote
Old 09-06-2013, 11:50 AM   #15
Iblu90
My Ride: BMW 330ci
Re: grill clips broken... need a quick fix!
Same thing happened to mine.. What u did was just drilled very small screws and they seem to be holding strong.. it's been 7 months since
Sent from my SPH-L720 using BimmerApp mobile app
Iblu90 is offline   Reply With Quote
Old 09-07-2013, 08:22 AM   #16
McGary911
My Ride: 2004 M3 Convertible
This happened to my M3 a few months back. The passenger side grill broke enough clips to fall out. I just got some bailing wire, and attached one end to one of the grill slats (you can't even see it from outside the car) and twisted the other end to the base of the hood latch pin. That held it super tight for the week or so it took me to get 2 new grills (didn't want 1 old with 1 new, look like crap). It seemed tight enough that it would last for a long time, but I hate having 1/2 a$$ed fixes like this on my car for too long.
Hung the 2 old grills on the wall in the garage.
McGary911 is offline   Reply With Quote
Old 09-10-2013, 03:30 PM   #17
Denis330ci
My Ride: x5, 330ci
some great ideas...... i use 100% silicone for everything all plastic parts no drilling reqired really cheap $7 for a big tube...even used a tab on door panels to keep it from rattling when music is playing too loud.
Denis330ci is offline   Reply With Quote
Old 05-27-2014, 11:39 PM   #18
JrpisOfficial
My Ride: 325i Sedan
L
Jrp
JrpisOfficial is offline   Reply With Quote
Old 06-07-2014, 01:37 PM   #19
Allan smith
My Ride: imola 330ci
+1
Allan smith is offline   Reply With Quote
Old 04-28-2016, 10:50 PM   #20
moapys
My Ride: 2000 323
Grill clips broken - beware RTV/Slicon
...I tried that; it held about a year - then promptly gave up and fell off at highway speed - - gone. I'd probably go +1 on the wire and/or screw approach.
'Out hunting for a replacement side or two, now
moapys is offline   Reply With Quote
