Old 08-16-2010, 06:16 PM   #1
srivathson
My Ride: 2003 BMW 330i
Engine hissing noise
I have a 2003 330i sedan and started hearing a distinct hissing noise from the engine compartment right behind the oil dipstick. I took it in to the dealer since I had my inspection 1 service performed just a few days ago and the shop foreman said that he could not see any leaks and there was no fault code thrown. He said that it was a "normal" engine sound. Somehow I don't buy that and now I'm all freaked out. Any ideas? My car has around 83K miles.
srivathson is offline   Reply With Quote
Old 08-16-2010, 07:43 PM   #2
Jmanscotch
My Ride: makes my pants tight
Based on the description of the locating I would suspect your DISA valve has lost its tight seal. If not familiar with the DISA, search DISA and you'll find some videos of it and can compare to your exact sound/situation. It is pretty easy to remove (5-10 mins from hood open to close) and you can clean the seal or tighten it down to see if that fixes it.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 08-16-2010, 08:05 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Or buy the new o-ring in advance (will prolly need to order it) and replace it...and maybe before hand, try taking a hose to isolate sound with and running it down the ccv hose from valve cover just behind oil filter housing cap...I know that can crack and also hiss. I had a hiss, did whole ccv and disa...no hiss...don't know which one...I did other stuff too, but no hiss anymore.
Also, intake boot elbow going to icv cracks and would hiss...sort of in that area too, upper intake has a hose that also can suck air, so a dab of rtv might seal that (little dab, you'll need it off again). If you did air filter recently, might've missed closing a bracket.
Use hose to isolate...if not there, check pulleys/belts...if only at start up, check SAP hoses...
HTH
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-16-2010, 08:06 PM   #4
haurelio
My Ride: 2001 bmw 325i
does it sound like a fan?
Old 08-16-2010, 08:11 PM   #5
Jmanscotch
HTH
Doug
Didn't know you could get just the seal, cool.
Also, to elaborate on Dougs comment since you mentioned the mechanic didn't "see" any leaks (assuming this was referring to the intake tubes), there is often small tears that are hard to see/notice in these boots and when small, won't throw a code right away.
-Jake
Old 08-16-2010, 08:14 PM   #6
franz
My Ride: 03 330i
It's the lower intake boot elbow, $14-20 part, 30-40 minutes.
franz is offline   Reply With Quote
Old 08-16-2010, 08:50 PM   #7
srivathson
Thanks all.
Doug: Any pictures/video that you can link me over to that shows the parts in question that I need to check?
franz: Where is the lower intake boot elbow? How easy is the replacement? links to DIY?
haurelio: No, doesn't sound like a fan. Its a constant hiss that does not change pitch with acceleration. just constantly there.
Old 08-16-2010, 08:57 PM   #8
dmax
dmax's Avatar
Originally Posted by srivathson View Post
Thanks all.
No pics...but you'll find them...the ccv hose I refer to is the only hose leaving the valve cover (on mine anyway...think 323s are different with the ccv hoses)...the intake boot mentioned a lot is at the bottom of the tube that runs aft of the air filter...through maf, upper intake boot then lower intake boot...which attaches to both throttle body and icv...a bit of a pain your first time...you could smoke the engine with carb cleaner a little and see if it revs up...if it does...air leak on intake side...not sure if ccv hose would be affected by it.
Anyway, use hose to isolate sound and you'll get pretty close. CCV valve also makes noises...I know it honks...don't think it hisses though...but that might have been my hiss, I suppose. Point with ccv is, if you do one hose, you'd be silly not to do whole system and be done with it.
HTH...Night!
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-16-2010, 09:14 PM   #9
franz
My Ride: 03 330i
http://www.bmw330ci.net/maintenance/tubeelbow.php and even if it's not this elbow it is guaranteed to be rotten by now, and you will be down there where the hiss is.
Old 08-17-2010, 05:14 AM   #10
srivathson
Thanks guys. I will try to look at this over the weekend and post an update
Old 09-29-2010, 10:17 PM   #11
CruzBMW
My Ride: 2001 BMW 325ci
After replacing my air intake boot, my engine doesn't run hard, not so much engine noise and It corrected the whistling sound. Now a hissing sound is noticeable. It's coming from the top near the dip stick and down wards. When replacing the boot, I did notice oil leakage on the engine. I'm having the ccv replaced and hopefully it will correct the hissing sound and oil leakage. I will leave an update after the job is done.
Sent from my iPhone using BimmerApp
CruzBMW is offline   Reply With Quote
Old 09-30-2010, 10:29 PM   #12
haurelio
did you replace the upper and lower boots?
Old 09-30-2010, 10:37 PM   #13
CruzBMW
I replaced the lower boot. It took care of the whistling sound and the rough start. Now there is a hissing sound. I'm hoping it is the ccv (oil sep.)
engine, hissing, noise
