'75 2002 DD Project - Non e46 Content - Page 13 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 4.88 average. Display Modes
Old 05-27-2012, 06:47 PM   #241
tyusha
My Ride: 2004 325i SilverGrey
The more i read the more amazed i become!
tyusha is offline   Reply With Quote
Old 05-28-2012, 06:59 PM   #242
328iBen
My Ride: e46 328i
Just went throught the whole thread, amazing build!
328iBen is offline   Reply With Quote
Old 05-30-2012, 01:39 AM   #243
tinkwithanr
My Ride: '00 323i + '75 2002
Originally Posted by Bemwe_03i
Wow nice work stayed up til 2am last night going thru this thread.
You can build anything looks like, do an iron man suit while you're at it
Let me know if i can CAD up anything for you.
Good luck and cant wait to see the end product.
Thanks for the offer! It's always good to see fanatics helping eachother out. That being said I do CAD design as my day job, so I hope I can handle anything that pops up lol.
Thanks guys!
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-30-2012, 02:00 AM   #244
tinkwithanr
New update with good news and bad news. First the bad:
-Overall progress has been much slower than I had hoped. As I mentioned before, I was really hoping to have the entire body blasted during the long weekend. That hasn't quite happened.
-The sand blaster I was planning to use was left in less than great condition, and so I had to use most of my time Saturday refurbishing it.
-I'm not sure what kind of paint was used in the respray of my car, but damn it is tough to cut through. So even one the blaster was up and running progress is slow at best.
-Some area's of the body were hiding more bondo than I expected, and behind most of it was more rust.
And the Good:
-Some area's were less rusty/messed up that I though, which was a nice change for once.
-That's about it lol
Because of the above, I'm probably close to halfway done with the unibody. That then leaves the hood, trunk, fenders and doors. I'll make a more detailed post about the problems/progress once I finish (hopefully later this week), but here are a few teasers.
FUUUUUUUUUUUUUU
Old 06-01-2012, 02:22 PM   #245
Hornung418
My Ride: '04 MB ZHP
Holy Hell. That right rear wheel arch is going to need some serious work.
Hornung418 is offline   Reply With Quote
Old 06-06-2012, 03:05 AM   #246
tinkwithanr
While I don't have any pics of the blasting progress (I just finished replacing the last of the stock parts on the sand blaster besides the pot itself, grrr), I figured I could at least share some of the recent parts purchases.
First I broke down and picked up some Blare Spot-Weld cutters. A bit late considering i already removed the nose panel, but I'm sure I'll need it for other parts here shortly. These are particularly slick in that they have a spring loaded centering pin that retracts as you drill. To start, you 'punch' the metal in the center of the spot weld, and then drill until your through the first layer of metal. Much better than the 0.25" drill bit I was using before lol.
Next up my e36 rear diff cover came in. I decided to use this because of the dual rear mounting ears compared to the single ear on the e30 diff. Also, this will let me swap in one of Rogue Engineering's fancy finned diff covers down the line (http://www.rogueengineering.com/rogue/DC/DC_E36.html).
Ignore my 1 minute bead blasting job, I just wanted to knock the grime off.
Should bolt right up with some slight modifiations.
Last but definitely not least was the start of my fuel system. For the past month I have been trying to decide what route to take with my fuel supply. I could keep the stock tank with an e30 318 fuel pump, but that would probably be well undersized for my final power goals. Which means I would have to replace it in the near future, not something I wanted to do. Then there is also the issue of how 'safe' the stock fuel tank is, along with the lack of internal baffling and a single pick up. This would lead me to need to use a surge tank setup, which only adds complexity to the fuel delivery system. This lead me to look into fuel cells, but most of the ones I came across were unsatisfactory. Pretty much all of them used foam for their internal baffling (if they had any at all), which degrades over time. It also doesn't stand up to e85 fuel very well at all, and since I'm planning to use that under boost, none of those tanks would work.
Then I came across the Aeromotive line of Stealth Fuel Cells. Initially I thought they were very overpriced, until I realized that they came with an internal prefilter, pump, and fuel sender all in one package. But by far the best aspect for me was that they use an internal baffling system to keep fuel around the pickup of the pump at all times. This was key for me, because I plan to drive the car very hard, so starvation is a big concern. The specs of my tank in particular are:
15 Gallons (20x18x10) - fits in the stock location for the most part (slight modification required
Internal A1000 Pump - rated for up to 1000hp in forced induction applications (or closer to 600hp in e85, which gives me enough room to work with)
GM 90 Ohm fuel sender - While not the 3-73 ohm range of the stock sender, it's close enough that I can make it work with some simple circuitry.
Shiny:
-10AN Outlet from the pump, that's a lotta fuel lol
Here you can see some of the baffling. The vertical tube on the left is the return line, it dumps back into the center of the tank which is also where the pickup for the pump is, separated by a small wall. If the fuel level gets low in the tank, the return will dump straight back into the baffle, keeping the remaining fuel by the pickup. The baffling also helps keep the pickup submerged during high side-loads (think long, high speed sweeping corners). You can see the pick up and the prefilter on the right side of the picture.
Old 06-06-2012, 08:34 PM   #247
tyusha
Nice update, but can't wait to see more updates on body work!
Old 06-06-2012, 09:04 PM   #248
StrummerE46
My Ride: 330ci ZHP
Send a message via AIM to StrummerE46
duuuuude that is dedication. ive always dreamt about buying an old 2002 but knowing what lurks in the body and my lack of technical skill or time would drive my OCD nuts. absolutely insanely awesome.
braucht mehr low
StrummerE46 is offline   Reply With Quote
Old 06-20-2012, 05:36 PM   #249
Brevik
My Ride: Tiag M3
bump for updates
Brevik is offline   Reply With Quote
Old 06-20-2012, 10:22 PM   #250
tyusha
^what he said! :-D
Old 06-20-2012, 11:42 PM   #251
Hornung418
My Ride: '04 MB ZHP
Yeah!
Sent from my DROIDX using Bimmer App
Old 06-26-2012, 03:19 PM   #252
tinkwithanr
Sorry guys, nothing really exciting to post. I just got back from 10 days of vacation so she's still about 50% sandblasted. I did get some more body parts in while I was gone, so you can expect a small update in the next day or two.
Old 06-26-2012, 09:45 PM   #253
tyusha
eeeeexcellent!
Old 06-26-2012, 10:49 PM   #254
Russell L.
My Ride: 1972 BMW 2002tii
Nice build thread. I have a 72' 2002tii that I bought a few years ago. I love the car and have finally been able to drive it lately as it has been in the shop for the past 6 months trying to get a problem fixed with the engine. During the summer, it would get very hot outside and the car would start chugging. On right turns it would almost stall because there wasn't gas being pumped im guessing. Im not sure, but just recently the car has been running great, and I hate to say it, but i haven't had any issues with it *fingers crossed*. My car is actually in great shape compared to some other tii's, but it would be a fun car to restore.
Russell L. is offline   Reply With Quote
Old 07-02-2012, 10:44 PM   #255
Hornung418
My Ride: '04 MB ZHP
Bump!!
Old 07-02-2012, 11:37 PM   #256
djnekkon
My Ride: MB3ci & z33 HR
Incredible! keep up man!
Old 07-11-2012, 10:38 AM   #257
Hornung418
My Ride: '04 MB ZHP
bump I say!! Where's the pics?? I need my 2002 fix! LOL
Old 07-12-2012, 07:35 PM   #258
Pottsy
My Ride: 2004 330i zhp
Awesome build. love e10's
Pottsy is offline   Reply With Quote
Old 07-14-2012, 11:19 PM   #259
tinkwithanr
So it's been a while since I had an update worth posting, between the crazy hot weather and my work schedule it's been hard to make any noticeable progress. Luckily today I managed to knock out enough that it was worth it to catch you guys up.
First thing first, the rest of the Turbo body parts came in from Blunttech (thanks again Steve). All together the kit consists of:
4 fender flares:
Rear Trunklid Spoiler:
Front Spoiler/Lip:
Gasket for between the Body and Flares, along with mounting nuts:
Sadly the Front Driver Side Flare is currently unavailable from anywhere. Supposedly BMW has then in production, but there is no telling when they will be available again. As of right now it's not holding me up, since mounting and trimming the front fenders won't take to long (the time consuming part is going to be the rear flares). Worst case scenario is I'll end up having to get a reproduction and use it until the OEM piece comes back in stock.
Old 07-14-2012, 11:48 PM   #260
tinkwithanr
The rest of my time has been spend stripping the car down to bare metal. After finishing all of the exterior surfaces, I started working on the underbody. The sand blasting process worked great for the surfaces with just paint and bondo (in some cases LOTS of bondo lol), but it was pretty much useless on anything with rubberized undercoating. Which is the entire underside of the car. Because of this, I had to bust out the 4" grinder with the wire wheel attached and strip off all the rubbery material. This leaves the base metal primer, which I'll sandblast off as a final step.
Here's a pic of the underbody after stripping off the rubbery undercoat. It's kinda hard to see, but the grey/greenish area's are the base metal primer ready to be sandblasted. The lighter grey area is already sandblasted metal, and the black is an aftermarket undercoating from my previous repairs. It will also be coming off to bare metal, but it needs to be ground off still.
What does half a car worth of undercoating look like?? This, the pile is about half and inch thick.
After spending a few hours working on the bottom of the car, I turned my attention to the rear fender wells. The first picture is after I wire wheeled out all of the undercoating. This showed me what places were rusty and needed attention.
For my rear suspension, I'm going to be running a true coilover that ties into the roll cage in the trunk area. This means that the stock spring perch and reinforcement are just taking up space, so out they come.
With the inner section cut out, it just left the spot welded attachments which gave me a great chance to use my new spot weld cutters. Here you can see the individual spot welds on each piece.
First I punched the center of each spot weld so the cutter could locate properly.
And here you can see the cutter. The center rod is spring loaded, so it helps to locate the cutter without drilling into the second layer of metal.
As you push the bit in, the rod retracts keeping the bit centered.
Now all that was left was to drill out all the spot welds for the spring perch support.
Bottom Side Done:
Top side Done:
After removing it, I'm really glad I did. You can see all the rust that was hiding underneath it. Luckily with the perch out of they way it will be very simple to patch it and tie it into the cage with my shock mount.
The next steps are to remove the spring perch from the other side (passenger) and then sandblast the underbody for hopefully the last time. Then I just need to blast the interior, which shouldn't take much time at all thanks to the thin layer of paint, and the trunk.
