The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 4.88 average. Display Modes
Old 09-08-2010, 12:19 PM   #21
tinkwithanr
My Ride: '00 323i + '75 2002
Originally Posted by zhp43867 View Post
subscribed.
Originally Posted by spngr311 View Post
Subscribed!
Originally Posted by kk325xi View Post
i love u.
sooooo h0mo hehe
...... lol
Originally Posted by Fozzy View Post
In !
Originally Posted by juicytofu View Post
good luck. helluva lot of work.
Thanks, it's not that hard just time consuming. Now I just need to find more time lol.
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 09-08-2010, 12:35 PM   #22
bombguy
bombguy's Avatar
My Ride: 2004 M3
subscribed!! This better be good!!
2004 JB
KWv2, Spacers 15/F-10/R, MVR Rep, Alpine IDA-X305 w/ KCE-BT400 Bluetooth,
Agency Power Exhaust, Khoalty AE's
bombguy is offline   Reply With Quote
Old 09-08-2010, 01:29 PM   #23
tinkwithanr
So this past weekend I was able to get a big chunk of the rust repair taken care of. There's still a lot of stuff to do, but now I have a feel for what I need to do and more importantly how to do it. This is the first time doing body work and so I'm pretty much learning as I go.
First order of business was to remove all of the rusted out/heavily pitted metal. Once this was done it exposed the frame rail that sits under the floor. Luckily for me it was still very solid, it just has some debris inside.
Driver Frame Rail - Before
Once I cleaned it out, I applied a coat of Weld-Thru primer so I could add some extra support on the inside of the frame with a 1/8" thick sheet metal cut to fit.
The Primer:
Weld-Thru Primer
The Frame Rail freshly primed:
Driver Frame Rail - Primed and Ready
The reason for the primer is that when 2 pieces of metal of butted up against one another they have a tendency to trap moisture, which leads to rust. The best way to prevent that is to paint both pieces before you push them together. But since the insert was being welded in normal paint would be burnt away, so it wouldn't do any good. The Weld-Thru primer is special in doesn't burn away when welding, so it will still protect the metal from rust.
The frame rail with the added metal welded in:
New Patch Welded In
After that I applied a good coat of POR-15 (rust inhibitor). Once that was sealed up I could move on to the rest of the driver's floor. Below you can see where the rust started to run up onto the transmission tunnel ever so slightly. In order to repair this I cut put a template from thick paper and then traced the pattern onto some sheet metal.
The hole:
Driver Floor Before
The metal piece cut from the paper template:
Patch for Driver Tunnel
Once I had the outline cut out I used some body hammers and dollies to get the curve right. Once the shaping was done I tacked it in place until the rest of the floor could be made up. I forgot to take more pictures as I made that piece up, but here's the paper template I made for the other corner of the floor.
Paper Template:
Paper Template
Sheet metal from Template:
Metal cut from template
And here you can see this piece tacked in place:
Tacked in 2
Next in line was the inner front rocker/side of the floor. At first I was going to leave this piece in, but the more I poked at it the more fell out, and so I decided to make up a new patch to cover it up.
The rusty piece:
Old Busted Joint
The sheet metal patch, unbent:
Template of old busted joint
The patch, freshly bent:
New Hotness\
And here is where it got welded in:
Location of old busted joint
Once the sides were patched up I made up the inner floor panels. Here's the left one ready to be tacked in place:
Left Floor Pan
The last thing I worked on this weekend was my crappy stock gas pedal mount. it was rusted and pitted and all around worn out, so I figured I would make a new one.
The old busted joint:
Old Pedal Mount
The new sheet metal piece ready to be cut:
New Metal
The bends matched up pretty good:
Bent up to match
Then I made up some new mounting 'nipples' from some 1/4-20 bolts and acorn nuts. I put the nuts in a drill press and then rounded them off with a grinder until they were the right shape. To hold the bolts in place I welded then through the holes from the back of the mounting plate. Finally I threaded on the rounded acorn nuts down onto the bolts and Voila!
The New Hotness:
New Pedal Mount
And it actually fits!!
It fits!
Last here's a picture of how she sits right now. I still need to grind the welds down and then seal everything up nice and good. I'm hoping to get to that tonight or tomorrow. Then I get to tackle the passenger side....
It has a floor now!
New Floor!
Old 09-08-2010, 02:06 PM   #24
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
sweet - i have considered getting one myself, preferably a round taillight tii
/_________\
O==[][]==O
Old 09-08-2010, 02:18 PM   #25
tinkwithanr
Do it, their great little cars. I'd love to have gotten a tii, but I'd hate to molest a true classic like that. Especially since this will end up on campus with me. I won't loose sleep if this gets a door ding or gets messed with (to a point).
Besides you can't run quad 40mm mikuni's on a tii .....
Old 09-08-2010, 03:32 PM   #26
DropTopKingM3
My Ride: All German
Subscribed for epicness
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 09-08-2010, 03:39 PM   #27
BMW-UDM
My Ride: Piggy bank
Awesome!!
BMW-UDM is offline   Reply With Quote
Old 09-08-2010, 03:50 PM   #28
Kwando
My Ride: rolls Volks TE-37SL
Will be following this closely as I too would love to have one someday. Although I don't have any restoration skills I always wanted to trot around town in one of these. I can't believe a 2002 turbo is asking 40k+; with good reason, but still Any plans to change the colour or wheels?
Kwando is offline   Reply With Quote
Old 09-08-2010, 04:15 PM   #29
tinkwithanr
Thanks!
Originally Posted by BMW-UDM View Post
Awesome!!
For now it will stay red and I'll stick with the msw's. Eventually I'd love to paint it either the stock turbo white or silver, or maybe phoenix yellow. Next summer I'm planning to do more exterior body work which should include turbo fender flares and front air dam, at which point the wheels might change due to the need for a different offset. All in due time though, I need to get her back on the road first!
Old 09-09-2010, 09:27 AM   #30
bombguy
bombguy's Avatar
My Ride: 2004 M3
What are the overall plans anyways?
2004 JB
Old 09-12-2010, 09:22 AM   #31
tinkwithanr
For now I'm just fixing all the big rust issues and replacing the important lines (fuel and brake) to make it reliable and safer. Also I'm going to re-seal the inside of the car from the outside. Then down the road (read next summer) I'll make the body more presentable and probably do a complete suspension overhall.
In the meantime, since I don't have enough to work on yet:
Bike Carbs Bought!
They will just need to be re-jetted and then mounted to a custom intake manifold to take the 3.25"-on-center carb spacing to the 4"-on-center intake port spacing. It will also need to transition from the circular outlet of the carb to the more rectangular inlet on the m10.
Old 09-12-2010, 10:57 AM   #32
Sherweeeny
My Ride: BMW Civic
nice work mate! im also glad you are sticking to the period correct mods. that fred flinstone mod had to go poste haste, as it way way too incorrect for its era!
Sherweeeny is offline   Reply With Quote
Old 01-09-2011, 12:43 PM   #33
Grande D
My Ride: E36 M3
Bump
Old 01-09-2011, 01:57 PM   #34
tinkwithanr
Sorry, progress has definitely been made, but updates to the thread obviously have not. It was on the road reliably from October through the end of November when I had to park it because the defroster fan doesn't work.
I'll make a more detailed post in the near future, but some of the stuff that has been done over the past few months:
- Big Brake upgrade for front (uses old 4 pot volvo calibers that manage to bolt in place)
- e21 rear drum upgrade (250mm drums up from 230mm stockies)
- all new carpet for the whole interior
- new 'silver dollar' gauge cluster waiting to go in (from the earlier '02's)
- Strut bar/battery tray ready to be installed in the trunk
- new period vdo gauges for oil temp, oil pressure, voltage, water temp ready to go in
Pry forgot some other stuff but I'll make a more organized post sometime this week when I can get some pictures.
Old 01-09-2011, 02:19 PM   #35
DeanMachine
My Ride: 03 330i japanrot
Nice 02 man, these things are fun little cars.
DeanMachine is offline   Reply With Quote
Old 01-09-2011, 06:19 PM   #36
tinkwithanr
Yeah they are. Do you have one?
Old 01-09-2011, 06:27 PM   #37
Krystian_E46
My Ride: E46 M3,AA3 ZHP,S544D
Send a message via AIM to Krystian_E46
nice find man, you should do something like this one i drove fully restored
- Krystian
http://www.facebook.com/kgawlak
Instagram : KrystianGawlak
Owner of many E46's :)
[Currently own 2004 M3, 2002 325i S54 M3 Wagon, S54 ZHP, 2004 ZHP HARD MOTORSPORT Flares & Centerlocks, 2005 AA 2.5 Kit ZHP(SOLD), S54 Sedan, 01 330ci and 1 Coupe 1 Sedan 1 E46 M3 parts cars]
Krystian_E46 is offline   Reply With Quote
Old 01-09-2011, 06:32 PM   #38
330i ZHP
330i ZHP's Avatar
was it a good driver? I have always lusted over the Turbo
/_________\
O==[][]==O
Old 01-09-2011, 06:34 PM   #39
tinkwithanr
Actually those are the flares and front air damn I want to go with, but I don't think I want to paint it white. Especially since I don't wanna go turbo right now I don't wanna seem like I'm trying to make a turbo-clone or anything.
That is very sexy though, where'd you get to see it/drive it?
Old 01-09-2011, 06:37 PM   #40
kpeng
Banned User
My Ride: E46 330 and E30 325
Subscribed.
kpeng is offline   Reply With Quote
