The Showroom
Thread Tools Search this Thread Rating: Thread Rating: 52 votes, 4.88 average. Display Modes
Old 11-28-2012, 01:16 AM   #401
Andy2108
My Ride: SpecE46 & E46 M3
HOW DID I NOT KNOW ABOUT THIS THIS IS AWESOME I LOVE 2002'S
Old 11-28-2012, 03:37 AM   #402
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
updates are great
/_________\
O==[][]==O
Old 12-07-2012, 10:49 PM   #403
tinkwithanr
My Ride: '00 323i + '75 2002
Wrote up a nice update and it deleted itself right before I posted it, so I'm just gonna throw a bunch of pictures up and maybe explain it later lol.
New storage for the socket sets. I laid them out how I wanted and drew it up in CAD. Then used that to engrave some signs and underlaid that with plywood:
Fits in the drawers of my craftsman box:
Then I worked on the front struts. Removed the spring perches and cut them in half. Then I turned down what was left of the perches on the lathe and trued up the cut edge. Could use the lathe on the bottom half of the strut housings because the spindle didn't clear the ways, so I trued those ends by hand. Then I made an aluminum spacer that will keep the halves in line when I go to reweld them. With the welding done the spacer will then be cut down and used to space up the Koni inserts from the bottom of the strut tube (they are shorter than the housings, so they need to be spaced up for the gland nuts to have something to hold on to).
Happy Holidays!
Tinker Engineering - 2014
Mica - 2000 BMW 323i - The one that started it all
Fiona - 1975 BMW 2002 - The Definition of Project Creep
Heidi - 1988 BMW M5 - The piece of BMW history
Silvia - 2013 Subaru WRX - Stock, for now
tinkwithanr is offline   Reply With Quote
Old 12-09-2012, 09:05 AM   #404
tinkwithanr
Got a lot of prototyping done today. First up was to get the strut tubes bead blasted and welded back together:
Here you can see how much shorter they will be compared to a set of stock '02 struts. It turned out to be ~1.75":
Hmmm, what could these be for...
With the housing welded back together I cut a 1" hold in the bottom of them:
Then I went over to the other side of the building to use the large horizontal band saw. First I cut the welding spacer into two pieces 3.15" long (with some left over):
Then I also cut out some 4"x4" billet alum 1.25" long, which will be used for the roll center spacers that go on the bottom of the strut housing:
Everything all cut out and ready to go:
Here's the two strut tube spacers along with the CAD dwg I made up. Took some notes and got one spacer turned out.
Finished Piece:
Then I took some 1/2" stainless bar stock and made this guy:
He fits into the receiver on the bottom of the strut insert for adjusting the compression damping like so:
All the parts for the strut insert spacer laid out:
And assembled outside the strut tube:
And how it looks with everything installed in the strut housing:
This is how the roll center spacer will hold the second gear. Because the steering arms and outer ball joints for the front suspension mount directly underneath the strut housing, access to the compression damping adjustment screw is blocked. The gear assembly will let it be adjusted from the side of the roll center spacer, full external adjustment.
Moving on, I used the fly mill to square up the 4" chunks of aluminum to ensure the top and bottom are parallel and even to each other:
Then I machined a bunch of holes in it.
Parts for the roll center spacer laid out:
Assembled:
Then I added one M3x0.5 set screw for each of the bearings in the assembly:
And this is everything in place:
And how it will be covered with the steering arm installed:
Overall I'm very happy with how the assembly turned out. The weak link right now is definitely the plastic gears. I started with them mostly because of cost, they were $3 each while the equivalent steel gear is $20 per. I wanted to make sure the theory and practicality of the setup would work before spending the extra $80 on gears. Keeping that in mind I designed it around a gear size (d.p. and basic dimensions) that is available in both plastic and steel. The other reason why I wanted to try out the plastic gears first was corrosion resistance. Even though the assembly will be pretty much sealed from the elements, I'm sure water and grit will find it's way in there somehow. The mild steel gears may start to rust, so I'll need to pack the assembly with grease before putting the steering arm on to help prevent the gears from rusting together. All that's left is the drill the mounting holes for the roll center spacer to the housing, and the steering arms to the roll center spacer. Then I just have to rinse and repeat for the other side.
Thanks for looking!
Old 12-09-2012, 11:27 AM   #405
Barbaros
My Ride: 02 TIAG M5
You sir, are something!!! wow! Best build thread ever!
Barbaros is offline   Reply With Quote
Old 12-10-2012, 12:03 AM   #406
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
That's genuis! Should go straight to the pool room
E46 Coupe is offline   Reply With Quote
Old 12-10-2012, 10:57 AM   #407
Gottalovethexi
Gottalovethexi's Avatar
My Ride: 03 xi & 72 Bav
Dude.
Love the tool set organizer and the customized adjusting for the suspension...amazing.
Old 12-10-2012, 09:34 PM   #408
tyusha
My Ride: 2004 325i SilverGrey
There is only one thing i can say... And i repeat it a lot! DUDE!!!
tyusha is offline   Reply With Quote
Old 12-10-2012, 11:10 PM   #409
Grande D
My Ride: E36 M3
Mother of god
It will change your life!
Old 12-11-2012, 12:41 AM   #410
jyerabutar
My Ride: 01" 325iT
respect !
http://forum.e46fanatics.com/picture.php?albumid=2578&pictureid=24900
jyerabutar is offline   Reply With Quote
Old 01-01-2013, 07:28 PM   #411
Brevik
My Ride: Tiag M3
Bump for 2013 updates
Brevik is offline   Reply With Quote
Old 01-05-2013, 12:21 PM   #412
Tate325xi
My Ride: 325xi 5MT
Simply incredible. I am so jealous of your design and fabrication skills! Keep it up
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 01-06-2013, 12:24 AM   #413
Hermes
My Ride: cars older than you
Dude, I think I'm turning into you... My "not a project" has turned into one. I just bought a new M10 to build on a stand before I put it in and sell the current one (block is from a 74, inferior quality metal that year). Car will soon be coming apart for paint since I want the engine bay painted before I put a new motor in. Still not decided on color but I don't really want Chamonix.
Also, my dog doesn't like my progress vs yours...
Respect Your Elders
Hermes is offline   Reply With Quote
Old 01-06-2013, 10:58 AM   #414
darksideracer69
My Ride: 01 325ci
I would love to have your skill set
Sent from my PC36100 using Bimmer App
IMAG02051
Old 01-07-2013, 07:30 PM   #415
allan1
My Ride: Lexus IS
There better be some huge update soon... cant wait
allan1 is offline   Reply With Quote
Old 01-07-2013, 10:18 PM   #416
E46 Coupe
E46 Coupe's Avatar
I agree. But should leave the mad scientist to his flux capacitor work.
Old 01-07-2013, 10:47 PM   #417
Barbaros
My Ride: 02 TIAG M5
I can't wait to see this car on the road!
Old 01-08-2013, 04:16 AM   #418
330i ZHP
330i ZHP's Avatar
moar
/_________\
O==[][]==O
Old 01-15-2013, 11:51 AM   #419
BMW_Knight
My Ride: STG2 ZHP,E70 X5(DD)
Send a message via ICQ to BMW_Knight Send a message via AIM to BMW_Knight
Updates!
Thanks to: www.getbmwparts.com www.aatuning.com www.toyotires.com
Eurowerkz Mid-Atlantic Regional Director
Join the Eurowerkz Facebook Fan Site : Click Here
Need your car coded with Euro Options? (Remote Windows up, Corner delete, DRL off, etc.) PM Me
BMW_Knight is offline   Reply With Quote
Old 01-15-2013, 12:40 PM   #420
Hornung418
My Ride: '04 MB ZHP
C'mon, man.
Sent from my SCH-I535 using Bimmer App
Hornung418 is offline   Reply With Quote
