Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 08-20-2010, 08:59 PM   #1
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Shift Style alcantera shift boot & ebrake boot install - DIY
I spiced up the interior of my M3 with an alcantara shift boot and ebrake boot from www.ShiftStyle.com.
Quick tool/supply list -
** Zip ties
** Wire cutters
** Strong hands
** Shift boot and ebrake boot from www.ShiftStyle.com
Shift Boot Instructions
1) Pull the side of your existing boot towards the shifter to pop the plastic frame lose.
2) With the boot bottom loose the shift knob has to come off. The knob is held on but friction and plastic clips inside the boot. I've found it helps if knob is warm. Try parking your car in the sun for an afternoon to heat up the interior. Then put the car in 2nd and pull up, hard. Be VERY careful to pull in such a way that you won't hit yourself in the face, break your rear view mirror or wind shield. Try to pull the knob in such a way that it will go into your stomach if things go badly.
3) You should now be able to remove your boot. In my M3 the knob is lighted so I had to disconnect the wiring plug.
4) The Shift Style boot reuses the stock frame seen here in white.
5) The stock boot is glued to the frame. Start peeling the leather back off the frame. Work your way around slowly peeling the leather off. It takes time but just keep working at it, once you get it started it comes off easier than it seems like when you start.
6) With the frame free of the stock boot put the Shift Style boot on. It comes with an elastic bottom so its a simple matter of slipping it on. You could glue it as well but I don't think its needed. If you ordered a shift boot and ebrake boot be sure not mix them up and put the wrong one on like I did
7) Make sure you line up the stitching to best show it off in your car.
8) Now slip the boot over the shift level and zip tie it in place.
9) Snap the base back into place and reinstall your shift knob. If you're using the stock knob it snaps back on. I replaced the stock knob with a UUC Rob Knob.
Ebrake Boot Instructions
1) With the ebrake up pull the stock boot towards the lever to pop the bottom frame out of the center counsel.
2) Cut the zip tie that holds the boot to the ebrake handle.
3) With the boot and frame free we need to remove the plastic frame from the stock boot as the Shift Style boot reuses the stock frame. Start by finding a lose section of the leather and slowly pealing it off the glue holding it to the frame. Work you way around the boot pulling a bit a at time on each section. It gets easier as you have more leather to hold on to, getting started is the hardest bit.
4) I worked both side first, then had much better luck removing the ends.
5) With the frame free install the Shift Style boot. The boot has an elastic bottom so it slips over the frame. You could glue it as well but I don't think its needed.
6) Line up the stitching with the corners of the frame so it looks great when installed. The top of the frame has the larger plastic tab on it, the bottom has one but is smaller and thinner.
7) Slip the boot over the ebrake handle and zip tie it in place. Notice that the ebrake handle has slight grove in it that the zip tie should go in.
8) With the end zip tied to the handle snap the plastic frame back into place and you're done. Take your whip for a spin and enjoy the new feel to your interior!
tim330i is offline   Reply With Quote
Old 08-20-2010, 09:00 PM   #2
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Nice Tim.
Looks good!
Also, FIRST ON A TIM THREAD.
Gheybe is offline   Reply With Quote
Old 08-20-2010, 09:03 PM   #3
tim330i
E46Fanatics Owner
tim330i's Avatar
Thanks, I'm very pleased with the new look!
Old 08-20-2010, 09:58 PM   #4
rares
My Ride: 02 S54
Send a message via AIM to rares Send a message via Yahoo to rares
thanks Tim... that's awesome...
rares is offline   Reply With Quote
Old 08-21-2010, 09:39 AM   #5
alibusoul
My Ride: 04 330Ci
Looks great! To relieve your interior woes you need to trade your black nappa for cinnamon or imola... worked for me
alibusoul is offline   Reply With Quote
Old 08-21-2010, 03:37 PM   #6
alwaysbored786
My Ride: M3
nice! i like these.
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 08-22-2010, 02:55 PM   #7
02black330ci
My Ride: spaceship
Very nice Tim, it definitely cleans up the interior.
02black330ci is offline   Reply With Quote
Old 08-23-2010, 10:46 PM   #8
turbo911cm
My Ride: 05 E46 M3
nice, might put that on the list of future mods...
turbo911cm is offline   Reply With Quote
Old 08-23-2010, 10:49 PM   #9
SalM
My Ride: Shhh
+1
SalMPhotography
SalM is offline   Reply With Quote
Old 08-25-2010, 10:18 AM   #10
blackout26
My Ride: 2005 AW M3 6SPD
yea nice tutorial ...i noticed that the new knob you put on only had 5 gears?? do they not make that knob with 6??
blackout26 is offline   Reply With Quote
Old 08-25-2010, 10:25 AM   #11
tim330i
E46Fanatics Owner
tim330i's Avatar
It was from my 330i that was only a 5 speed pattern on the knob. I'll get a new cap for it from UUC soon.
Tim
Old 08-25-2010, 10:28 AM   #12
jackkyzer
My Ride: 2002 325i
That looks nice. You could talk to coby1 about getting one of his alcantara M3 wheels. I think he sells them for your old wheel plus some cash. They look awesome and feel amazing.
jackkyzer is offline   Reply With Quote
Old 08-25-2010, 01:04 PM   #13
djbg726
My Ride: 2004 330Ci
Nice Tim, I had the exact same shift boot and ebrake boot in my car. So much easier than others I have seen.
Gone, but not forgotten
djbg726 is offline   Reply With Quote
Old 08-26-2010, 05:17 PM   #14
SG333
My Ride: E46
Does this material look and feel like alcantara? or is it alcantara?
SG333 is offline   Reply With Quote
Old 10-13-2010, 05:24 PM   #15
bimmer11
My Ride: 00 323ci
Thanks for the walk through! just got done with mine looks great
bimmer11 is offline   Reply With Quote
Old 11-05-2010, 06:47 PM   #16
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
I'm ordering one right now. On the list for future mods.. thanks for the writeup tim
G-Hots is offline   Reply With Quote
Old 11-07-2010, 11:24 PM   #17
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
Just ordered a set. $64 shipped is cheap!
Can't wait for it to get here.
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 11-18-2010, 12:56 PM   #18
peteyM3
My Ride: 04 JB M3 Vert
can I get a DIY for SMG shift boot thanks,
peteyM3 is offline   Reply With Quote
Old 11-25-2010, 04:47 PM   #19
Cabrio freak
My Ride: 3.25Ci Cabrio
Nice upgrade of the interior, Did the same in my previous E46,and loved it.Before I traded the vert for a 5 series.
http://forum.e46fanatics.com/showthr...039&highlight=
Cabrio freak is offline   Reply With Quote
Old 08-16-2011, 02:11 PM   #20
mbgt72
My Ride: 2002 325ci
First off, nice DIY and addition to the site. I'm sure it's been helpful to many.
I'm sorry to bump an old thread, but I've been trying to get in touch with Shift Style for over a month now with no response, and in another week's time, my parts will have been missing for two months time. I have received no return email since June 23rd, and shipped my product via USPS on June 28th. I have tried NUMEROUS times to contact them both via email and their contact form on their site. At this time I don't even care if they send me the alcantra boot, I just want my oem parts back as the cost to replace each part with new oem parts is going to be very pricy!
I sent my Shift Boot, Shift Knob & Shift Surround (oem carbon fiber) all to them so that I could have a alcantra Shift Boot Free (a program they do if they do not have your model in their database, which they didn't have one for my 2005 S4). I also shipped my E-Brake handle to have it wrapped and was expecting a bill for this to be done, which would be no problem as it was extra labor. But at this point, I have received NO response to any form of contact I have tried, and feel as a last resort I must track them down through forum posts. If nothing else, let this serve as a warning for anyone else looking to purchase through them or send their parts in as I did.
Thank you for your time and any help on the matter.
mbgt72 is offline   Reply With Quote
