Sponsored by BAVSOUND
Old 08-21-2010, 08:13 PM   #1
Mulatto325
My Ride: 325ci convertible
I'm about to route new speaker wire from the doors to my trunk. I got some ????
I have searched for about an hour and can't really find what I'm looking for. How hard would it me be for me to remove the bottom parts of my dash so i can route new speaker wire through the loom connecting the door and the(front fender) car?? Any answers or links would be helpful. Thanks? I'm removing my glove box to route RCA's but have not done that yet I'm sure that will give me some answers but what about the drivers side.
Note
The whole reason I'm doing this is I'm installing the Dynavin next week so i was checking out the previous install form a horrible audio shop. They used a LOC but kept my stock speaker wiring and i noticed only 3 channels of my 4 channel amp are connected all the speakers work but something a muss and I'm starking from scratch fresh speaker wire from my 4 crossovers to my amp. My guess is that they used one set of my stock wires for the LOC and just rewired one whole side to one channel. Unacceptable!! I check the BSW web site no luck. Just want to know what I'm in for before i start pulling the door panels off again. I could leave it and just plug and play the new HU but that's not what i want.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 08-22-2010, 08:49 AM   #2
Mulatto325
I know someone has done this. I pulling my radio and glove box today. Just looking for some insight. I would hate to bother Jeff with this.
Old 08-22-2010, 09:06 AM   #3
Arty
My Ride: 1999 328i
The driver's kick panel is no more tricky to remove than the glove box. Routing cables behind the centre console from on side of the car to the other is less easy.
Arty is offline   Reply With Quote
Old 08-23-2010, 08:15 PM   #4
Mulatto325
Yea i found that out today. Seems like i would have to take the whole dash apart. I just spliced into the factory cables for the front and ran fresh wire from my rear crossovers to the amp. I Moved my amps too what a pain in the ass. No way to test everything cause i pulled my stock radio out Sunday. Think i did. I know its gonna get hot under there. I'm gonna add a fan if they start going into thermal overload. Hope i don't get a flat. Have to call roadside assatance. I was gonna take out the spare but i had enough room with it in
ID:	372885   Click image for larger version
Old 08-25-2010, 02:49 PM   #5
Mulatto325
a couple new pics of my reroute first i just used electrical tape. well i could hardly sleep until i did it right. One before and two after pics. My unit and relocation kit should be here tomorrow. Hope it all works. Got all weekend to tweak it then to the body shop Monday
ID:	373093   Click image for larger version
ID:	373094   Click image for larger version
Old 09-24-2010, 07:35 PM   #6
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
cant believe a shop did that to you
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 09-25-2010, 02:11 PM   #7
CountOfNowhere
My Ride: 2001 330Ci
Send a message via AIM to CountOfNowhere
The stock stereo wiring in the E46 is quality twisted pair wire. You did yourself a disservice replacing it.
2001 BMW 330Ci - Bilstein PSS10 coilovers, PowerFlex and UUC poly bushings all over, Ground Control camber plates and rear shock mounts, adjustable rear camber arms, Dinan chip, K&N cold air intake, UUC Ultimate Short Shifter and double-sheer selector rod, ZHP shift knob, replica M3 front bumper and mirrors, fresh-to-death paint, OEM M3 door trim, reinforced rear subframe
1995 Jeep Grand Cherokee V8 - Quadradrive is awesome - Stock
CountOfNowhere is offline   Reply With Quote
Old 09-25-2010, 08:40 PM   #8
Mulatto325
I ended up not replacing the stock wires for the doors. But i did run fresh wires to the rear speakers
