Old 08-24-2010, 11:23 PM   #1
Don-Faheezy
My Ride: 2001 330i
really quick electrical wiring question.
I am tapping into the cigarette lighter power and ground, to hardwire a usb charger
( http://www.canadiantire.ca/AST/brows....jsp?locale=en )
and the wire they give looks like a 16 / 18 gauge wire but its only a few inches long.
the only wire i have laying around is a 22 gauge wire. if i solder and heatshrink the cables together and run it near the back of my center console maybe around 2 feet away, will i have any electrical problems?
22 gauge is pretty thin. im kind of scared of fires, heat, ect.
Don-Faheezy is offline   Reply With Quote
Old 08-25-2010, 11:20 AM   #2
WTCCe46
My Ride: '04 325
From my experience, you should get the same sized wire. The bigger the wire the more transfer of electricity. Since the Usb charger does not carry a huge ohm load you don't want to go with a bigger cable because that cable will get VERY HOT and could potentially cause a fire. Also, be careful the cables are not pinched when you install them.
Sent from my DROID2 using BimmerApp
WTCCe46 is offline   Reply With Quote
Old 08-25-2010, 01:04 PM   #3
Arty
My Ride: 1999 328i
You should not use a thinner cable. You could use two runs of 22AWG for each line. Doubling up to halve the current flowing in each.
Arty is offline   Reply With Quote
Old 08-27-2010, 01:21 PM   #4
Don-Faheezy
My Ride: 2001 330i
thanks for the responses, i'll use the same wire
charger, electrical, hardwire, usb
