eas | E46 M3 Rogue El Diablo Exhausts for your E46 M3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-26-2010, 02:59 PM   #1
david @ eas
Past Site Sponsor
My Ride: E46 M3
Gentlemen,
As you might know we are an authorized STOCKING distributor for Rogue Engineering. This basically means that we have your products in stock ready to go!
Specifically looking at the Rogue El Diablo Exhaust which I just took a picture of yesterday (picture below), you can come by, look at your product before you make a purchase. We have these exhausts just sitting on our shelves ready for you to come on by! Act soon as these will go by quickly!
Rogue Engineering decided to produce our system in 100% full T-304 stainless steel because of its consistent strength characteristics, corrosion resistance, and wide range of materials (important for controlling sound and exhaust flow). At 26 lbs. for our production system, we have reached the weight of some full titanium systems costing twice as much but with the benefits of using stainless steel.
Are all stainless steels the same? Nope. Not even close. Some companies have chosen to build their "stainless steel" exhausts with Grade 409 stainless, because it is less expensive than 304. While Grade 409 will resist atmospheric and exhaust gas corrosion, a light surface rust will form is most all atmospheres.
El Diablo Features:
The RE El Diablo is made to fit exactly like factory. Features of El Diablo include:
Weighs only 26 lbs., 1/2 the weight of the factory muffler! (factory is 56 lbs.)
100% T-304 stainless steel construction and internals
Fully mandrel bent tubing, no crimps or flattened areas
Mil-finished pipes and muffler, mirror polished stainless steel quad 80mm angle cut, staggered tips (with exclusive 3mm wall thickness, not just a piece of stainless steel tubing)
Full TIG welded construction, no lock seams or pinch welds.
Rogue Engineering logo tastefully stamped in the body of the muffler
Optional 80mm Titanium tips
Flow-through design does not create muffler "hot spots" found on chambered mufflers
Optimized tubing sizes and minimized bends maintain exhaust velocity without compromising necessary backpressure
Deep, throaty tone, without the drone. Virtually silent at idle, but appropriate tone at higher RPMs.
Will not change ground clearance
Will not void factory warranty
Will not affect emissions
No permanent modifications required for installation
Here's a quick video of the Rogue El Diablo (Track Edition):
Rogue Engineering - El Diablo Exhaust for e46 M3
http://www.europeanautosource.com/pr...oducts_id=1954
Rogue Engineering - El Diablo Exhaust for e46 M3 (Track Edition)
http://www.europeanautosource.com/pr...oducts_id=2376
Models Supported:
2000-2006 e46 M3
As always, feel free to ask any questions on this thread, via PM, email or simply give us a call.
david @ eas is offline   Reply With Quote
Old 08-26-2010, 03:00 PM   #2
david @ eas
Past Site Sponsor
My Ride: E46 M3
Took some photos of the Exhaust while they were here at the shop
Want forum pricing? Then PM me!
