Sponsored by BAVSOUND
Old 08-27-2010, 01:40 AM   #1
BIGCU
My Ride: ///M3 Cab
help with indash dvd install
I got an 01 M3 and I can't get my harness and rca's tucked away properly....any suggestions?
thanks
BIGCU is offline   Reply With Quote
Old 08-27-2010, 08:52 AM   #2
Ashhong
My Ride: 2002 325i
are you still using the black plastic harness thing? im not sure how you mounted yours, but i noticed that the top part of that black plastic piece was utterly useless, so i cut it off. after doing that, there is a lot of space on top of the radio for wires and such.
Ashhong is offline   Reply With Quote
Old 08-27-2010, 09:45 AM   #3
Steve330ci
My Ride: 2006 325ci vert
To get some more room
With the radio removed, you can remove the A/C control panel by pushing it out from the back, then unscrew the four screws that hold in the carrier frame that supports the radio and the A/C control panel. Pop out the A/C duct on the dash and pull the carrier frame out. You can then route the audio cables and connections so they are behind the carrier which will give you more room. Then re-install everything in reverse order. I recently installed a single DIN in-dash NAVI/DVD and doing it this way gives much more room.
Hope this helps.
Steve330ci
2006 325ci vert
Steve330ci is offline   Reply With Quote
Old 08-27-2010, 10:40 AM   #4
Arty
My Ride: 1999 328i
For me, I remove the glovebox and pushed the BMW radio connector back through the hole from whence it came. It fits - just - after all, it was installed in that manor. Then I ziptie the RCS's to the aftermarket headunit power harness, and as I slide the HU back, I draw the harness and RCAs into the glovebox area. This is a RHD car.
Arty is offline   Reply With Quote
Old 08-27-2010, 07:08 PM   #5
BIGCU
My Ride: ///M3 Cab
Thanks guys, I'll try your suggestions and remove the climate control.
Cheers
