Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 08-27-2010, 02:29 AM   #1
crazyafghanguy
My Ride: E46 M3
e36 turning off while driving
i recently installed a CAI in my e36, today i was on the freeway and i hit 95 then put it in neutral to coast until i hit the exit and my oil and battery light comes on and my car is off ! i pull off to the side to see if maybe i broke a belt or anything but everything seemed fine and this happened again on the way back home, i was going 80. is it my CAI fault that my car turned off?
Thanks E46Fanatics!!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
Street Edge Coilovers
ZCP Brake Upgrade
LED Tail Lights
crazyafghanguy is offline   Reply With Quote
Old 08-27-2010, 12:30 PM   #2
edco
My Ride: 2004 325cic 2011 X5
By any chance do you have a bunch of keys on the ring with your ignition key..? It's been known to happen where the weight of the keyring under certain circumstances,can cause the connection with the immoblizer to be lost, and cut the power. Your ignition key should be all by it's lonesome..
ed
edco is offline   Reply With Quote
Old 08-27-2010, 04:16 PM   #3
crazyafghanguy
My Ride: E46 M3
ed
i probably have 4 small keys plus my bmw key plus a bmw key chain, i dont think it would be that heavy but this is the first time my car has died on my while i was driving fast
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 08-27-2010, 08:52 PM   #4
crazyafghanguy
My Ride: E46 M3
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 08-28-2010, 06:44 PM   #5
TRUEDIABLO
My Ride: T100,323it,325xit,Z3
Is you A/C on when you do this? Is it an auto? It's not really a good practice to coast like that, popping it into neutral while coming to stop is nothing, but at highway speeds it's not a good idea.
TRUEDIABLO is offline   Reply With Quote
Old 08-28-2010, 09:19 PM   #6
crazyafghanguy
My Ride: E46 M3
its a manual and i did have my a/c on, its not good to put the car in neutral during high speeds??
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 08-29-2010, 04:41 PM   #7
TRUEDIABLO
The A/C might do it- what mods do you have? In my e36 sometimes when I would pop it into neutral while coasting to a stop with the A/C on the revs would drop so much that it would stall too, I think it's a common problem, lots of drag on the motor (A/C) and a sudden loss of the momentum keeping it going- or something like that. I don't know if it's related to CAI, maybe the freer flowing motor is kind of 'looser' so to speak and has more of a tendency to do it? My car always had a CAI so I don't know.
As for coasting at high speeds in neutral, it's just a lack of control issue, not horrible just not as safe.
I would just stop doing whatever causes the problem, in this case coasting in neutral
Old 10-11-2010, 02:42 AM   #8
crazyafghanguy
My Ride: E46 M3
the problem was the MAF getting crazy and shutting off car, moved the CAI up more
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 11-30-2010, 02:36 PM   #9
M1992
My Ride: 02' E46 330i
My buddy had the same probably and it wa sbecause his hoses were loose, you may want to try tightening them
Originally Posted by captjones
my dad used to pat me on the head when i had very short hair & said:
"son, u'd make a fine toilet brush"
M1992 is offline   Reply With Quote
Old 11-30-2010, 03:09 PM   #10
crazyafghanguy
My Ride: E46 M3
the problem was that i had air forcing into the intake while i was idling and moving so the MAF was misreading it and would cause the car to shut off, thanks tho!
01 M3
Black/Black 6 Speed
Style 95
Amber All Around
ZCP Brake Upgrade
LED Tail Lights
Old 12-01-2010, 09:04 AM   #11
M1992
no problem!
