Old 08-28-2010, 08:58 AM   #1
captainsatch
My Ride: 2000 BMW 316i
DSC and brake warning lights come on and go
hi guys! here is my problem
DSC and brake warning lights come on after few miles of driving after first engine start, it remains on all thoughout the day. After parking it overnight, and starting the engines the following day, I DON'T get the lights to come on! but goes ON again after few miles of driving! and so on and on and on! i had the codes red! "pressure sensor" is what came out! my mechanic told me that you have to buy the whole module because they don't sell pressure sensors alone.
I just have few questions.....
1. what is the problem?
2. do i need to have these fixed right away? i mean these are just added features or percs of owning a bimmer but in a normal car these features aren't available right? i mean the car would still function and run normally even if these DSC and brake warning lights are on right?
3. what is the danger ? my DSC and traction controls are inoperative?
THANKS A LOT E46 FANATICS! you guys ROCK! hope you can help me! THANKS AND GOD BLESS!
captainsatch is offline   Reply With Quote
Old 08-28-2010, 09:01 AM   #2
alwaysbored786
My Ride: M3
when those lights are on, your dsc is totally disabled, meaning you have full control of the car...drive carefully.
I had this same exact issue, and it went away by its self (dont ask me how). I got the codes read, and it said steering wheel position sensor was off, and i figured it went bad.
Read the codes on your car, it could be same sensor as mine, or a wheel speed sensor, or something else.
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 08-28-2010, 09:13 AM   #3
captainsatch
I had the codes read! I got a an error of " pressure sensor."
Old 08-28-2010, 10:16 AM   #4
alwaysbored786
My Ride: M3
yea i dont know wtf that is. Research it up a bit, hopefully you dont need a new module, if you do, your gonna be shelling out a lot of money.
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
2002 330CI - SOLD
1988 325E - SOLD
Old 08-28-2010, 10:18 AM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
What was the code number
Old 08-28-2010, 12:28 PM   #6
Levim9
My Ride: S54 325i & LSB M3
Have you had an alignment in a while? My traction system acted just like yours until I got an alignment done. I'm not saying that will fix it but it's worth looking into.
What was the code number you got?
Levim9 is offline   Reply With Quote
Old 08-28-2010, 03:12 PM   #7
motormadness
My Ride: 330CI
I had/have this issue. I didn't have the DSC codes read. I have found that if i turn the wheel full deflection to the left and then right, then let the car sit for a while, then the lights don't come on for about 50 to several hundred miles. I don't know what it is. Most of my driving lately has been less than 10 miles, so it hasn't really come on at all.
motormadness is offline   Reply With Quote
Old 08-28-2010, 05:27 PM   #8
captainsatch
thanks guys for all your replies!
i can't remember the code number, will have it checked again! my question is if I just leave the way it is, would it result in any damage in my car? I mean it's just the DSC traction control that wouldn't work right? but i'd still be able to drive and run my car normally. Thanks guys thanks! really appreciate it!
Old 08-29-2010, 01:34 AM   #9
Levim9
It probably won't hurt anything but you should find out what is causing it to not work. If your alignment is off and causing your traction control to not work like in my experience, you should get it taken care of.
Old 08-29-2010, 09:10 AM   #10
bAby norAA
My Ride: 01 BMW 330i
there is a lot of potential problems that could cause ur dsc control module not to work properly. easiest thing would be to bring it to someone who can read the values of your speed sensors/check for other hidden codes that normal obd II code readers can not see.
it may be as simple as getting a proper 4 wheel alignment. but without a proper scan you will be stabbing in the dark.
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 08-29-2010, 09:17 AM   #11
c5ry
My Ride: 2002 M3
IM having about the same problem, dsc, brake and tire light are orange. they all come on after i had a back tire blow out on me.
c5ry is offline   Reply With Quote
Old 08-29-2010, 10:03 AM   #12
Adam330i
My Ride: 03 M3
I called the dealership about this problem in the past they told me it was more than likely the wheel speed sensor. I never fixed the issue because it would come and go. The dealership said it wasn't something to be to concerned about they said my DSC was still enabled. How true that is I'm not sure!! It is the stealership!!!
Adam330i is offline   Reply With Quote
Old 08-29-2010, 07:45 PM   #13
captainsatch
thanks guys for your replies! really appreciate it, my only concern is is it gonna affect my car's basic role, I mean would i still be able to drive my car normally even if i dont have the DSC fixed? it's just an added feature in BMWs right? a lot of cars dont have this feature. of course i'd lose all those cornering braking control and traction, Dynamic Stability Control feature!
thanks guys!
Old 09-12-2010, 12:59 AM   #14
captainsatch
it went on again after a few weeks of driving! lights came back after driving it for weeks. total miles i added in my odometer was around 300miles. it went away again after i turned the engine off and drove the next day! guys what's gonna be the danger with my car if i don't have this fixed? i mean i'd still be able to drive my car under NORMAL conditions even if the DSC and brake lights are on right? I'd just lose the traction control features but when it comes to driving it it would nott really give me a headache right? had the codes read and i got a PRESSURE SENSOR error, my mechanic told me it might be a faulty dsc module, thanks guys! would i still be able to use my car and drive it normally? i understand the DSC is an added feature of bmw for tight cornering turns and traction controls. my other japanese car doesnt have this feature so i dont really mind if i would not have this in my e46. thanks for the help guys!
Old 09-12-2010, 12:29 PM   #15
hawk99
My Ride: 323ci
Take the time to take your wheel speed sensors out and clean them, and reinstall. Very easy, and may clear up you problem with no $$$$.
hawk99 is offline   Reply With Quote
Old 09-12-2010, 06:04 PM   #16
captainsatch
how do i clean those sensors sir? thank you
Old 09-15-2010, 05:29 AM   #17
captainsatch
had the codes read! got 5e21 pressure sensor! its the sensor in the brake master cylinder! 34521164458 is the part number! shop is charging me $200 just for the sensor! labor excluded !
