Replaced my RTAB (DIY with pics) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 3 votes, 4.67 average. Display Modes
Old 05-16-2015, 07:33 PM   #1
crackerlee
My Ride: 2003 325Ci Conv.
I had replaced my front lower control arm bushings about 2000 miles ago, with PowerFlex bushings. I wanted to replace my RTABs too before getting an alignment. I am replacing with Lemfoerder #33322228153.
This is for a 2003 E46 Convertible. Yours may be slightly different.
Tools/materials needed:
18mm socket (with an extension) to remove the three RTAB mounting bolts.
A second 18 mm socket or box wrench to remove the one RTAB center bolt.
10mm socket to remove the one brake line bolt.
17mm socket to remove lug nuts.
Torque wrench.
Floor jack.
Jack stands.
Block of wood, 8" long, 3-5" wide, 3/4" thick. The 3/4" thickness will play a role.
A little anti seize.
Three hours of time.
1. rent yourself this tool. I got mine here: http://forum.e46fanatics.com/showthread.php?t=1071805
2. Jack up and support your car.
3. Before unbolting the RTAB bracket, carefully unclip the wiring that runs along the trailing arm, and unbolt the 10mm brake-line bracket.
4. You'll want an alignment after this job, but try and re-install the bracket as close to aligned as possible.
5.With the arm extended, you're ready to remove the old bushing.
6. old and new bushing
7. install the new bushing
8. re-installing the bracket and finishing the job.
Update: Be sure to position the bracket (search for "RTAB preload") when reinstalling the bracket to the bushing (single 18mm bolt) so the bushings don't twist when attaching the (three 18mm bolts) bracket to the car (the bracket should be about flat against the car body). If it is not, you might be putting tension on the bushing which will greatly reduce the service life.
crackerlee is offline   Reply With Quote
Old 05-16-2015, 08:04 PM   #2
325ragtop
My Ride: needs more HP
Great write up! I really like how you took time to add all your text to the photos... makes for very easy reading. Speaking from experience, I will reiterate that this is a job that is MUCH easier when you have the right tools. I've done a couple of these cars with a combination of the Harbor Freight Heavy Duty Ball Joint Press kit and a combination of home brew tools... i.e: very large 3/4" drive sockets with 1/2" thread rod and double nuts, etc.... Trust me, you really want that tool shown in photo 1.
325ragtop is offline   Reply With Quote
Old 05-16-2015, 09:03 PM   #3
bimmernate
My Ride: 2003 330i ZHP
great DIY! how did you "preload" the bushing when you tightened up the bracket? what was your reference point? different people do it different ways, i've seen some people use 8mm above wheel bearing center line but am just curious. Thanks
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-16-2015, 10:07 PM   #4
325ragtop
Since OP used Lemfoerder, we'll need OP to chime in... I went with poly.
Old 05-16-2015, 11:14 PM   #5
crackerlee
Not sure I understand what you're asking. Can you clarify? Thanks.
Old 05-16-2015, 11:32 PM   #6
bimmernate
when you tighten the bracket on the bushing, it needs to be done with the bracket at a specific angle so when it's bolted back up to the car the bushing has no torsion on it otherwise the bushing will fail pre-maturely. I'm probably not explaining it very well. See this thread.
http://forum.e46fanatics.com/showthread.php?t=927014
2003 330i ZHP 6MT
Old 05-16-2015, 11:53 PM   #7
Megalocnus
My Ride: 05 330i ZHP/MT
The "preload" on the bushing is done by positioning the bracket at a specific angle to the arm. If the angle is wrong, the bracket will twist when bolted to the body, thus exerting pressure on the bushing.
Take a look at the Bentley service manual.
Megalocnus is offline   Reply With Quote
Old 05-17-2015, 12:02 AM   #8
Megalocnus
My home-made preload tool:
Looks ghetto, but is made to position the bracket precisely as specified in the manual.
Old 05-17-2015, 01:22 AM   #9
DEADF15H
My Ride: 2001 325i Auto
I can't get the photo to show on my phone. It might be my phone, if anyone else is having this please chime in, otherwise I'll wait for when I'm on my computer.
DEADF15H is offline   Reply With Quote
Old 05-17-2015, 01:51 AM   #10
bimmernate
i can see the photo. Can you describe exactly how the manual describes the positioning to be at? how thick is the green part on the end?
2003 330i ZHP 6MT
Old 05-17-2015, 03:06 AM   #11
Megalocnus
I'll try, but please take a look at the scheme on page 330-9.
The bottom (flat) surface of the bracket is oriented parallel to a plane 8 mm below, which passes through the center of the wheel.
Old 05-17-2015, 03:29 AM   #12
BaliDawg
Ombak besar hari ini!
My Ride: E24 E32 E39 E46 E84
OP probably didn't know about the preload requirement. Glad folks chimed in mentioning that as this DIY thread, though very good, would be incomplete without it.
///Mmmmmm...
Old 05-17-2015, 08:11 AM   #13
crackerlee
I should read my manual more often
I tightened the bracket to the bushing with the wood wedged (pic in step 8) between the arm and the bracket. This resulted in almost no tension when I mounted the bracket back onto the frame. The result of aligning it 8mm below hub bore is to have no tension on the bushing when reinstalled right? Thanks guys.
Sent from my iPad using Tapatalk
Old 05-17-2015, 09:28 AM   #14
BaliDawg
Correct. The idea here, as with some other BMW bushings, is to have no tension on the bushing when the suspension is normally loaded - the car is sitting with wheels on the ground at normal ride height. This helps the bushing last longer since the majority of its time it is under no strain.
It will work if you don't preload the bushing during installation, but the bushing will prematurely fail.
///Mmmmmm...
Old 05-17-2015, 09:54 AM   #15
hitbyastick
My Ride: 2002 325i
Regarding the bushing. OP's replacement bushing has a flange on one side. The original bushing did not have this flange. I have bought replacement Lem RTABs and they do not have this flange on one side. They look more like the original bushing. Somebody explain.
Erryboddy got a plan till they get punched in the mouf - Mike Tyson
hitbyastick is offline   Reply With Quote
Old 05-17-2015, 10:10 AM   #16
cvx5832
My Ride: 325Ci, 325Cic, C300
Update: Be sure to position the bracket when reinstalling the bracket to the bushing (single 18mm bolt) (search for RTAB preload) so the bushings don't twist when attaching the (three 18mm bolts) bracket to the car (the bracket should be about flat against the car body). If it is not, you might be putting tension on the bushing which will greatly reduce the service life.
Great write-up. However the above should be flat against the body under load. Which means while you're installing it, as the pictures shared above show, it won't be flush against the body. The bushing only returns to "neutral" after the car is back on the ground. This is why lowered cars rip through RTABs if they've original.
Of course with poly, none of this applies. That's just a footnote. I'm a Lemfoerder kinda dude.
cvx5832 is offline   Reply With Quote
Old 05-17-2015, 08:53 PM   #17
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Those new RTABs will be toast in very little time without the proper preload. Should have just gone with polys which allow the bolt and sleeve to rotate freely in the bushing making preloading completely unnecessary. I believe, but, am not 100% sure, that a lowered suspension will require a slightly different preload setting even though the Bentley makes no mention of any difference for sport, non-sport and M3. For this reason I just said the hell with it and went with polyurethane bushings when I installed the Bilstein coilovers.
scottjoh is online now   Reply With Quote
Old 05-22-2015, 06:45 PM   #18
crackerlee
I re-did my RTABS with urethane bushings so I didn't have to deal with preloading. Created a new thread.
Admins - you can delete this one
Old 05-29-2015, 12:45 AM   #19
bimmernate
How thick is that wood wedge?
Usually, i see people just use a straight edge from just below the carrier housing to a point 8mm ABOVE the center of the hub (which is actually shown in the photo that I posted above). But then i have seen posts by mango and a few others which state 8mm below the hub. I'm inclined to go below the hub since i'm lowered. thoughts?
2003 330i ZHP 6MT
Old 06-01-2015, 06:36 AM   #20
crackerlee
I actually replaced my RTABs again with poly's. So I didnt have to deal with preloading, and renting an rtab tool if I needed to do this again in the future. I wrote up another thread on that.
