Old 09-13-2012, 08:33 AM   #61
paraklas
My Ride: ESS TS2 320ci
Any sponsor here carrying this LSD?
Old 09-14-2012, 12:49 AM   #62
paraklas
Wavetrac from AWD_Motorsports - Ebay
Replied within seconds and ships overseas at reasonable rates so I'm getting the unit from them.
Question:
Do I need the aluminum-finned differential cover or the stock is fine?
Old 09-14-2012, 01:11 AM   #63
TiAg2247
My Ride: E39 M5 | E55 AMG
The finned differential cover helps with heat dissipation. If you plan on tracking your car or just drive it very aggressively anyways, it's a worthy investment to prolong the life of your unit. Oh, and it looks badass from behind
Imola Red M5 | Imola Red Interior
GT Exhaust, Custom BC Coilovers, 19x10 + 19x11 Rial Dayonta Race, Michelin PSS
Daily: 335i M-Sport Alpine White / Coral Red
Too many mods
Past:
'04 E55 AMG
'01 330Ci Titanium Silver / Coral Red
'96 328i Jet Black / Black
TiAg2247 is offline   Reply With Quote
Old 09-15-2012, 03:48 AM   #64
paraklas
Thanks! I will start an LSD assembly thread at some point after gathering all parts.
Next. Differential bushings already changed, thinking of differential seals too. Anything else that I will need?
Old 09-20-2012, 09:11 AM   #65
Cruzader
My Ride: Alpinweiß facelift
which diff bushings are you running? have you changed the subframe bushings as well? how do you like them?
I'm looking forward to seeing how this will come out, to potentially do the same in my car. Thanks
Cruzader is offline   Reply With Quote
Old 09-20-2012, 09:17 AM   #66
paraklas
Differential/subframe mount bushings all replaced with genuine BMW. I don't like poly or solid versions due to increased noise, vibrations. I will order the LSD as soon as I verify that the part is indeed the correct one, and order any additional parts that may be required, hence asking about seals etc. Realoem lists my car as having a 3.38 diff. Is this marked anywhere on the actual differential? Just in case the previous owner replaced it for some reason
Old 09-20-2012, 10:18 AM   #67
jabela
My Ride: 2002 325ci
Here's all of the E46 gear ratios... unfortunately 320's aren't listed though.
http://www.bokchoys.com/differential/GearRatios.htm
2002 BMW 325ci /// Sport Pkg /// 5 spd
Modern Apothecary
jabela is offline   Reply With Quote
Old 09-20-2012, 04:09 PM   #68
paraklas
As a part number, on realoem, the 3.38 is listed only for the 320, no idea why not on any other models. Still I need to confirm it from somewhere on the actual diff.
For the wavetrac, there are 2 different parts for the E46 non-m, with >3.15 ratio and <3.15.
Wavetrac Differential BMW 188K AXLE r=3.15>
Old 09-20-2012, 07:40 PM   #69
Snik
Snik's Avatar
My Ride: IR M3 Vert.
I may be selling a 338 diff and carrier here soon. Or was it higher. Can't remember. Bought it to swap. Now selling car here soon and won't be needing it.
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 10-04-2012, 03:15 PM   #70
paraklas
Thanks, but I already have the 3.38. I asked about the compatibility with my car and I'm having some issues with the supplier, getting them to understand what I have.
Question 1
Hi, do you have the LSD for the BMW E46 with a 3.38 ratio? I would like to know price and availability of 1 unit, with shipping to Cyprus if possible!
Basically this unit:http://www.autotech.com/product/wave....html?fromcat= but for a 3.38 ratio
Many thanks,
Paris
Paris, what year and model is your car and with what motor in the vehicle, and is the car manual or automatic transmission? Is the 3.38 ratio what you have currently installed from the factory or is it a new ratio that you plan to have installed? With that information I'm sure we can verify which differential would be correct for your car, thanks!
Regards,
Autotech Sales Staff
Me
Hi,
Car is a 2001 BMW E46 320ci. It has the M54B22 engine with 5-Speed gearbox. The 3.38 ratio is the factory installed and comes as standard for the 2.2L engine / manual transmission.
Thanks!
Final reply
Paris, it is difficult to determine from the information available to us about the offset of your existing differential to see which one of our Wavetracs would fit--the only difference between the .175WK and the .176WK is the offset of the flange where the final drive would bolt up. That particular motor/final drive combination is not one we have here in North America, so without having the rear end or the stock diff here to examine, it is difficult to say with 100% certainty if your car would accept one or the other.
If you happen to have access to a spare factory differential or rear end identical to your car we may be able to determine which one would fit your car, but other then that it's almost a 50/50 chance of one diff or the other fitting your car. Thanks for that information, sorry it didn't completely solve the question it hand!
Regards,
Old 10-09-2012, 05:47 AM   #71
mazdero
My Ride: 2003 330ci Turbo
I have one on my 330. Its a very nice unit, works flawlessly.
mazdero is offline   Reply With Quote
Old 10-09-2012, 09:03 AM   #72
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Paraklas, if you remove the differential from the car, there's a sticker on the top of it that states the ratio.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 10-12-2012, 12:44 AM   #73
paraklas
I already know my ratio, 3.38, my issue is that autotech don't know if this ratio will accept their LSD unit
It is difficult to determine from the information available to us about the offset of your existing differential to see which one of our Wavetracs would fit--the only difference between the .175WK and the .176WK is the offset of the flange where the final drive would bolt up.
Old 10-12-2012, 11:03 AM   #74
Jesse M
My Ride: 05' ZHP
Originally Posted by bluejeansonfire View Post
This prices similarly to a kaaz, but hopefully it wont make the owner's ass as bloody
Jesse M is offline   Reply With Quote
Old 02-05-2013, 03:48 AM   #75
paraklas
--the only difference between the .175WK and the .176WK is the offset of the flange where the final drive would bolt up. [/b]
As I have not given up (yet) on this project, can anyone here point me to the part number that relates to the above - "flange where the final drive bolts"
I would like to compare on realoem agains other models to see compatibility
From here:
http://www.realoem.com/bmw/showparts...85&hg=33&fg=05
Old 02-05-2013, 09:49 PM   #76
rkneeshaw
My Ride: 330i ZHP
I dont understand the confusion, wavetrac lists the wavetrac part numbers based on either >3.15 or <=3.15. You have a 3.38 so why not order the >3.15 part number?
By the way, I just ordered the wavetrac for my 3.07 this last weekend :happydance:
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 02-05-2013, 11:42 PM   #77
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
someone buy my LSD
/_________\
O==[][]==O
Old 02-06-2013, 01:34 AM   #78
paraklas
Well I was thinking about that, theoretically I would get the >3.15, but on the other hand, the supplier cannot verify compatibility for 3.38 because they are not aware of such ratio in USA.
Originally Posted by 330i ZHP View Post
someone buy my LSD
good luck!!!
Old 02-06-2013, 05:03 AM   #79
MSportBMW
My Ride: E46 325, EVO8 MR
Paraklas save yourself the trouble and get a Drexler LSD
MSportBMW is offline   Reply With Quote
Old 02-07-2013, 11:13 AM   #80
wertyu78
My Ride: '04 ZHP
Whats wrong with the Kaaz LSD units?
wertyu78 is offline   Reply With Quote
