Old 02-09-2013, 11:13 AM   #81
paraklas
My Ride: ESS TS2 320ci
I like the wavetrac feature that allows torque to be transmitted to 1 wheel if the other one has no traction at all (air/ice)
The output flanges of the M54B22 are also different part number than higher-CC E46 so it's another no-go fitting this unit
Old 02-09-2013, 02:41 PM   #82
rkneeshaw
My Ride: 330i ZHP
For me its the fact that the wavetrac will be forever maintenance free (besides fluid changes). You get the advantages of a clutch type differential when one wheel looses traction, but no clutches to wear out.
If I was super serious about building a racecar, I'd probably go with the OS Giken, but this should be great for street and some amatuer track days
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 02-12-2013, 07:50 AM   #83
wertyu78
My Ride: '04 ZHP
I really love the Kaaz 1.5 way. Speedhauz has one installed in their ZHP drift car and I was thoroughly impressed.
What would be similar to the setup in the E46 M3? LS wise - not gearing.
wertyu78 is offline   Reply With Quote
Old 03-21-2013, 01:36 PM   #84
RedTRex
My Ride: 05 330ci ZHP
Output flanges are extremely easy to swap. Pop off your current pig and stick in new one.
RedTRex is offline   Reply With Quote
Old 03-21-2013, 02:10 PM   #85
paraklas
What about the input flange? Wavetrac gives 2 options which essentially is the offset of the flange, going by the VIN, realoem lists my flange as unique for this engine/diff combo (M54B22 + 3.38) which I cannot understand WHY
Old 03-24-2013, 09:58 AM   #86
rkneeshaw
My Ride: 330i ZHP
Looky what I got on my garage floor:
Planning to get it installed in the next month or so when the weather clears, can't wait
2003 BMW 330i ZHP
Old 03-29-2013, 07:06 PM   #87
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Please write a review after install
Timeless Motor Group
Old 06-03-2013, 08:04 AM   #88
ejp2fast
My Ride: ZHP 6MT
+1 on the review for this wavetrac install
2003 ///ZHP 6MT - Silver Gray on Alcantara - 3.46 rear - Style 197's
ejp2fast is offline   Reply With Quote
Old 08-03-2013, 09:45 AM   #89
paraklas
So, my quest continues...
What differentiates a 3.38 of a 330 from a 3.38 of a 320? Apart from the output flanges. Is the ringset different for some reason?
Wavetrac has 2 models, which are for "thicker" and "thinner" ring, <=3.07 and >=3.15 ratios
Not my pic, showing the difference between the 2 rings, solved using a spacer.
Old 08-03-2013, 10:56 AM   #90
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Re: Wavetrac LSD Available for E46 Non-M
Order shims is what they are called. Without them you'll get winning noise and a few broken teeth.
Sent from my SGH-T889 using BimmerApp mobile app
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 08-03-2013, 11:08 AM   #91
Afrodeezyak
My Ride: TiAg ///M
Definitely want to see how this turns out. Let us know how it goes.
Afrodeezyak is offline   Reply With Quote
Old 08-08-2013, 05:49 AM   #92
paraklas
Plan to order the LSD this coming Monday, will come back as soon as it arrives
Old 08-20-2013, 03:28 PM   #93
Sedan Hussein
My Ride: e46
Whats the word? I'm going to start sourcing a 3.38 to build on. I've been eying the Quaife and Wavetrac, as well as an M3 swap. Looking forward to hear what you think of the Wavetrac
Sedan Hussein is offline   Reply With Quote
Old 08-22-2013, 05:39 PM   #94
dfjaws
My Ride: E90 M3 / E86 M Coupe
FWIW, the Wavetrac on my 335i is fantastic. I love it.
dfjaws is offline   Reply With Quote
Old 08-23-2013, 12:18 AM   #95
paraklas
Trying to arrange some things with the payment/shipping to avoid as much import taxes as possible.
I have literally searched every possible forum, and I just didn't find the answer to my question: With 1 wheel off the ground, does it truly lock as per specs?
Old 02-24-2016, 10:27 PM   #96
rkneeshaw
My Ride: 330i ZHP
I've been wanting to do this test for what feels like forever, because I could never find any video online of the wavetrac in action. Check it out and you decide:
I just wish I had a car with an open diff to test out at the same time. I'd bet it wouldn't move forward at all, because my driveway is slighly sloped and the way the car is positioned here it is trying to climb the incline. For what its worth, my F150 with OEM clutch-style LSD behaved EXACTLY the same way on this same patch of ice.
I just found this too:
2003 BMW 330i ZHP
Old 02-24-2016, 10:56 PM   #97
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
It operated Exactly as it should based on those conditions.....
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 02-25-2016, 12:26 AM   #98
jdjg
My Ride: e39, m52tub30
look here
jdjg is offline   Reply With Quote
Old 02-25-2016, 03:04 AM   #99
Rob43
Rob43's Avatar
was zum Teufel ist er sagen ?
Rob43
Old 02-25-2016, 04:09 AM   #100
jd improved
My Ride: charged 330i smg
He says if you have driving skills like a grandma, that the variable M Viscolok is the best diff you can have!
jd improved is offline   Reply With Quote
