Old 09-02-2010, 08:28 PM   #1
HyeWarrior
My Ride: '03 325i --> '13 GTI
Problem with factory HID's
So my passenger side headlight has been giving me problems over the past couple of months. Sometimes it wouldn't turn on, so I would either restart the car or toggle the switch back and forth until they came on. Over time, it's gotten gradually worse and I've had to do this technique more often.
Yesterday afternoon, I tried turning them on and they wouldn't no matter how much I tried. Later that night, I tried again and nothing. This afternoon, I tried and it worked flawlessly, and I tried many times but it worked every time.
I was convinced that its the bulb, and I was gonna try to swap em to see if the problem carries to the other side, but now that its working fine, I'm having second thoughts... Is there a sure fire way to check if its the ballasts?
I tried searching, but I couldn't find a clear answer... Oh, and I stopped by an Autozone to see how much a bulb would be... $130 for just one. I literally laughed out loud and left. $25 for a pair on Khoalty ftw
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 09-05-2010, 12:39 PM   #2
mujjuman
My Ride: not an E46
you have the right idea, start with the bulbs first, then move to theballast.
you can also buy an aftermarket HID kit to replace your stock ballasts and ignitors
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 09-05-2010, 12:45 PM   #3
ChasCan
My Ride: 2001 330xi
At my shop I've never found an HID bulb bad. Just igniters & balasts. From what I've been told, there is no test that can be performed on them. I would try swapping the bulbs first before you condem the igniters & balast though. Chas
ChasCan is offline   Reply With Quote
Old 09-05-2010, 12:54 PM   #4
jerseyfresh
My Ride: is schwartzed out
Like the other guys are saying, swap the bulb to check that it's working first...
...but chances are it's most likely the igniter.
They seem to last around 8-10 years, then go kaput...
...you can find replacements on Ebay for around $50
Originally Posted by trhine View Post
FYI you look like a over weight fortune cookie.
^^^Directed @Kpeng^^^
jerseyfresh is offline   Reply With Quote
