E46 Convertible
Old 09-05-2010, 02:26 PM   #1
tooredhots
My Ride: '01 325ci vert
Attention vert gurus! top lid not latching
My lid on the storage compartment for the top is not latching when putting the top down. All seems to be working properly, but the lid does not latch all the way down, and will bounce up when driving.
No lights are on, the top operates properly other than this issue. It just started doing this yesterday after I put the top down.
When the top is up, it seems to latch properly. The drive unit under the rear seat seems to be working properly, it pulls the cables in and out.
Any ideas?
Bone stock, style 68s FTW!
tooredhots is offline   Reply With Quote
Old 09-05-2010, 03:24 PM   #2
Zyaltr
My Ride: 01-325cic,08-750Li
Hope this helps
Zyaltr is offline   Reply With Quote
Old 09-05-2010, 03:39 PM   #3
tooredhots
Thanks for the pdf of the manual. Found that earlier on a search. Everything seems to be functioning fine, according to the manual. All functions seem to work properly, its just the last step of the top lowering process that seems to latch, but does not.
Old 09-05-2010, 03:40 PM   #4
i_ween
My Ride: '02 330Ci Vert
In for info. One side of my top compartment doesn't close tight. Fortunately, one side is tight, so it doesn't raise up while driving. I have been meaning to replace the latch on that side, though it does seem to tighten with the top up. Not sure if maybe a sensor is out somewhere...
btw: the manual is not helpful to me. Though, maybe to someone with a deeper working knowledge of sensors...
-Derek
check out my astrophotography:
www.gil-galad.com
i_ween is offline   Reply With Quote
Old 09-05-2010, 04:37 PM   #5
tooredhots
I can see that there is an adjustment on the cables in the unit under the seat. I wonder if they need to be adjusted tighter? 9 years of the top going up and down could stretch these out to where they would barely grab, or not at all.
Old 09-05-2010, 06:54 PM   #6
i_ween
^^ I noticed that, too. I wonder if maybe a little tightening on those lines might help.
-Derek
www.gil-galad.com
Old 09-05-2010, 08:50 PM   #7
tooredhots
Tried tighten some slack out of these, but nothing changed. I just returned them to the previous setting they were on.
Old 09-05-2010, 09:03 PM   #8
iansanderson
My Ride: 2001 330CiC
sounds like the latching unit is not working properly. best thing you can do is remove the rear seat bottom and check to see if it is releasing/latching when you raise and lower the top. it's the first and last thing to operate during the raise/lowering sequence as it relates to the rear compartment cover. if it's not moving, some people have been able to fix it by manually latching it using the supplied allen wrench. somehow it "reinitialized" the system in their case.
if it is functioning, check the cables and possibly lube the latches on both sides of the top cover.
if all else fails, it will probably need replaced as one of the gears is broken internally or the motor is bad.
Cheat Sheet:
GT1/ISIS/MoDiC = Factory authorized diagnostic system used by BMW dealerships across the world.
NCS Expert = BMW Factory R&D programming tool available on the internet (not intended for the public and not available to the dealership network)
OEM = Genuine BMW part only available from a franchised BMW dealership.
DME = Engine Management Computer
iansanderson is offline   Reply With Quote
Old 09-05-2010, 09:24 PM   #9
jfoj
My Ride: 330CiC, M5, X5
Search on the forums and see if you can find more info on the motor under the rear arm rest. As I recall, there is a gear in the top of the motor that a plastic gear that can break that then will render the rear top storage cover latch inoperable.
If my memory is correct, the top is hydraulic, but the rear cover is operated with the motor and cables that are under the rear center armrest area??
There was a Fanatic that had a broken gear and he rigged something up to make it work. The problem is this motor and gears are only available as a single, expensive unit as I recall?
Good luck and let us know if this info is helpful.
Old 09-05-2010, 09:43 PM   #10
jfoj
Found the post I was thinking about***********:
http://forum.e46fanatics.com/showthr...t=plastic+gear
Hope this is helpful.
Old 09-06-2010, 08:53 PM   #11
tooredhots
I removed the rear seat cushion, and checked the gears. They are turning and moving the cables in and out properly. It only turns the gears one direction.
To me it seems like the latches are working, but only half the time. It secures the lid whenever the top is closing. It just does not grab when the lid shuts on the end of the opening sequence.
I am going to try to lube the latches, what kind of lube should I use? I have white lithium grease, would that be appropriate?
Old 09-06-2010, 08:55 PM   #12
tooredhots
This was helpful, my plastic looks to be in good shape. It looks to be in good condition. It does not look like any of the pics in the thread you provided.
I fear I may be on my way to the dealer soon.
Old 09-06-2010, 09:47 PM   #13
iansanderson
how are you sure it's latching the top cover if the convertible top is pressing on it? do you stop the top and check it before the rear part is lowered?
Did you try pressing the emergency release button on the motor?
Cheat Sheet:
Old 09-06-2010, 10:29 PM   #14
i_ween
This is exactly what is happening to my passenger side latch. Mine are pretty well lubed. I didn't lube them; they were lubed when I got the car. I think the issue was noticed before I got the car, and someone tried to fix it. I came to the conclusion that I should replace the latch itself, about $50USD used. It is called the "top lid latch."
-Derek
www.gil-galad.com
Old 09-06-2010, 11:04 PM   #15
tooredhots
I did press on the emergency release button, then released and cycled the top to try to latch, no success.
I found out this evening, that you are correct. The top is pressing down on the lid, it is not latching. I stopped the top operation at various times. The motor under the seat is operating, but the latches are not working at any point in time during the operation.
I wonder if 2 $50 latches will fix my issue, or if a microswitch is keeping them from latching.
Does anyone know how to troubleshoot the microswitches?
Old 09-06-2010, 11:38 PM   #16
jfoj
But it is possible that the motor under the armrest is working, but the gear is popped like the link I posted or maybe the cable(s) may not be attached??
What you may want to try is open the top, push the emergency release and use the hex wrench to cycle the motor to see if the latches work?? Not sure, but you should be able to do this??
If the latches do not work when manually operating the system, then the cable(s) or gears must have a problem?
This is just a guess, but it is probably worth a try?
Old 09-06-2010, 11:44 PM   #17
jfoj
From page 28 of the manual supplied in the first link:
Emergency Operation
Emergency locking/unlocking of the top storage
cover is carried out at the motor assembly.
The motor assembly is accessed by removing
the center arm rest and lifting the seat upholstery
below the ski bag.
Pressing the button on the motor assembly will
release the motor from the gear linkage.
The linkage assembly can then be turned,
through the access hole in the motor assembly
cover, using the hand crank stored on the
assembly cover. This will unlock/lock the storage
cover locks for manually raising the top
Sounds like you should be able to manually lock or unlock the storage compartment lid manually. If this works, then you have a gear or sensor issue?
Old 09-08-2010, 05:25 PM   #18
tooredhots
Fixed!
Fixed! Your post made me really look at the link with pictures and compare in detail how the gears and cabling should look. I head back out one last time to see if I could do anything before taking it in to the dealership.
Turns out the crimped connector was catching on the arm that draws the cables into the motor unit under the seat cushion.
The picture shows the right cable how it should be, and the left is how they both were incorrectly routed.
I thought everything was ok, because they were both caught on the arm in the same way. I did not notice that they were curved to hinge on the arm.
Old 09-08-2010, 07:15 PM   #19
i_ween
Fixed!
Is that inside the box under the back seat? If so, I want to check mine...
-Derek
www.gil-galad.com
Old 09-08-2010, 08:42 PM   #20
jfoj
So the question is did something come loose, break or just get out of alignment?
In your picture, it looks like there may be a nut in the inside of the box that was removed and the cable entry nut may be backed out on one side?
Do you think the cable entry nuts are for cable length/latch adjustment.
Glad you found the issue. I think all us Vert owners need to share our issues as I really do not think the dealers understand these cars at all. I had to go round and round with my dealer to reset the window pinch senors, after the dealer changed the battery. I was told I needed both window motors replaced, I said hell no!! Adjust the window pinch sensors. In the long run the car did not need parts or taken apart!
